Author Topic: Andy’s, nothing like a Stevn's arctic build!  (Read 150865 times)
Taranis
  • Balne Moor MBC
Re: Andy’s, nothing like a Stevn's arctic build!
« Reply #525 on: January 25, 2021, 02:05:27 pm »
Thank you Tassie
ANDY
Taranis
  • Balne Moor MBC
« Reply #526 on: January 25, 2021, 07:55:49 pm »
Whist waiting for paint to dry I turned my attention to the internal stairs to the wheelhouse
ANDY
Taranis
  • Balne Moor MBC
« Reply #527 on: January 25, 2021, 10:31:01 pm »
First go at a Nav light using the acrylic tube purchased way back in the thread.
May have to paint a black line mid height or use black pin stripe lining tape.
More images in the gallery of the parts etc
ANDY
Taranis
  • Balne Moor MBC
« Reply #528 on: January 26, 2021, 07:27:00 pm »
Various bits of progress and I'm focusing on window frames just now.
Lots more pictures in the gallery.
ANDY
Taranis
  • Balne Moor MBC
« Reply #529 on: January 27, 2021, 09:32:31 am »
Thanks to a Facebook contact I now know the make of the Davit. A clear image of the name has always eluded me.
Welin Lambie
All electric slewing crane 1,400kg SARBE 8C
http://welinlambie.com/commercial/slewing.asp
ANDY
Taranis
  • Balne Moor MBC
« Reply #530 on: January 27, 2021, 05:30:54 pm »
Window frame production in progress. I don't think there is an easy way to do this it's just time consuming.
11 of 36 completed. Many more pictures in the gallery.
ANDY
Taranis
  • Balne Moor MBC
« Reply #531 on: January 28, 2021, 10:05:17 pm »
I'm waiting for another delivery from CMB now as I ran out of 0.5x2.5mm styrene strip.
I made the handrail for around the wheelhouse and some more window frame templates.
The first floor cabin is now ready for gloss white if it ever stops raining.
I also fitted too many window wiper boxes so the side ones are now discarded.
This is picture number 1,625 in the gallery
ANDY
Taranis
  • Balne Moor MBC
« Reply #532 on: January 28, 2021, 11:18:43 pm »
Whilst I feel I am on the correct course for producing the window frames it also gives the opportunity to fine tune the original openings
ANDY
Nordlys
« Reply #533 on: January 29, 2021, 08:37:59 am »
How do you fit these window frames.? Could you post a few more detailed pics please.
Thanks Andy.
Nordlys.
Taranis
  • Balne Moor MBC
« Reply #534 on: January 29, 2021, 09:17:08 am »
Do my best  :-))
In consultation with the pictures in the gallery (start at picture 1611)I first make a template 1mm smaller than the opening, then wrap 0.5mm styrene around it to get the exact length required. Glue the ends together and when secure fit the frame in the opening along with the template to keep it tight to the outside edges.
Some adjustment with files and sandpaper may be required.
It helps to place a bigger piece of styrene on the inside to ensure the frame is flush internally.
Whilst in position draw some plastic solvent cement around the edge with a fine application brush which will seep into the joint.
The adhesive (delux materials) is also in the pictures
The same templates will assist with making the glazing too. I plan to use 1.5mm acrylic for the windows that will fit IN the frames not oversized thin stuff glued across the back.
ANDY
Taranis
  • Balne Moor MBC
« Reply #535 on: January 29, 2021, 06:32:19 pm »
ANDY
RST
« Reply #536 on: January 30, 2021, 12:57:51 am »
No and very sad but no more probably due to ingredients no longer permitted.
Model Shop Leeds no longer stock it in the new guise as customers report it is crap
Not sure if you're still interested in an alternative to the good old Squadron filler or had it sorted since, but I'm using "MR HOBBY Mr. White Putty" recently with great success and recommendation (no direct replacement but quite workable).  Thought it might be worth mentioning.
Taranis
  • Balne Moor MBC
« Reply #537 on: January 30, 2021, 09:15:59 am »
Thanks Rich
Me too  :-))   I agree it's not a replacement but better than the new Squadron rubbish.
https://www.modelboatmayhem.co.uk/forum/index.php/topic,64887.msg690181.html#msg690181
ANDY
Taranis
  • Balne Moor MBC
« Reply #538 on: January 30, 2021, 11:24:46 am »
The first time in my life that I've had to pay for conduit {-) the cost of retirement and lockdown.
ANDY
Taranis
  • Balne Moor MBC
« Reply #539 on: January 31, 2021, 10:44:16 pm »
Scratching around a bit today while still awaiting a delivery.
I made more templates for the windows, only a few left to do now.
I've begun fitting pillars between the windows inside.
Dismantled the wheelhouse roof to make work easier, hopefully the next reassemble will be the last.
Might start on the furniture this week.
More pics in the gallery
ANDY
Taranis
  • Balne Moor MBC
« Reply #540 on: February 01, 2021, 09:48:38 am »
Trial fit of the combined fendering. I'm quite satisfied with the look and the effectiveness. Orion's mouldings are so strong I think this could demolish anything afloat  %%
The centre pipe is also fitted for the transporter ready for the detachable handle that will be shared between this and the Portgarth cart. Located with an R clip when needed.
ANDY
Taranis
  • Balne Moor MBC
« Reply #541 on: February 01, 2021, 08:11:58 pm »
My delivery arrived from CMB  :-))  However I started work on the stand/transport cart. This involves 2 coats of finishing resin then painting then rubber strips for the contact surfaces (ebay delivery Wednesday)
So no construction for a couple of days and I've had to borrow the wife's craft room chair as Brutus is sitting on mine  {-)
Pictures later.... much later  {-)
https://www.ebay.co.uk/itm/Rubber-U-Channel-Square-Edging-Trim-Seal-Fits-12mm/123384686133?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
The cart will be submersible for launching at Carnaby as they have a ramp  O0
ANDY
Taranis
  • Balne Moor MBC
« Reply #542 on: February 02, 2021, 04:15:03 pm »
Thunderbird 2 awaiting the rubber channel
ANDY
tassie48
  • bikes birds and burnups
« Reply #543 on: February 02, 2021, 07:05:07 pm »
Andy great looking tow cart going to copy your idea for my Metinda lll model was going to get a alloy one made 2.meters long this looks better and a lot cheaper great idea tassie48
Big Ada
« Reply #544 on: February 03, 2021, 04:34:07 pm »
Hi Andy, I have been watching this great build.
Just a thought about your Trolley, you say you will launch it down a ramp ( into the water? ) if so wont those wheels make it very buoyant and difficult for the Tug to sail off of it. and to get back on it after sailing.
Kind Regards,
Len.
Taranis
  • Balne Moor MBC
« Reply #545 on: February 03, 2021, 04:38:52 pm »
They are solid foam tyres Len (no air) however they would have no effect on 34kg even with inner tubes. That's 75lb in old money.
The cart in this mode would launch stern first and should be easy to hold down with the handle alone.
Thank you both for your comments  :-))
I hope you will show us what you come up with Tassie  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #546 on: February 03, 2021, 05:25:10 pm »
Let down by Royal Mail today so no progress on the stand.
These stern bollard deflector guard rails bugged me from the start so I altered them. They now locate with the gunwale as they should. I first reinforced before fitting a locating stud.
ANDY
Hande
  • Dream being fulfilled after 47 years.
« Reply #547 on: February 03, 2021, 08:08:52 pm »
Sorry for spam - I don't seem to find a way to delete my post, which became obsolete.
I was looking for your gallery, and now I found the link among your early posts...
Your's is amazing craftmanship..!
Hande
Trial-and-error doesn't spell failure - right?
Taranis
  • Balne Moor MBC
« Reply #548 on: February 03, 2021, 09:00:54 pm »
No problem it's only obvious to those following in recent weeks.
For anyone else, where you find text in red it is a link to what is relevant at the time.
This is page one of many https://techno.smugmug.com/Stevns-Arctic/
Thank you Hande
ANDY
Taranis
  • Balne Moor MBC
« Reply #549 on: February 04, 2021, 04:03:50 pm »
So the bollard guards prevent a slack towline getting fouled on them.
Now these additional fittings prevent the towline fouling the superstructure and other deck fittings, effectively limit stops for extreme manoeuvres.
More pictures
https://techno.smugmug.com/Stevns-Arctic/i-5H8D5fw
ANDY
Pages: 1 ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31   Go Up
Page created in 0.269 seconds with 22 queries.
