Pages: 1 ... 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31]   Go Down
Author Topic: Andy’s, nothing like a Stevn's arctic build!  (Read 160549 times)
Taranis
  • Balne Moor MBC
Re: Andy’s, nothing like a Stevn's arctic build!
« Reply #750 on: June 07, 2021, 09:58:43 pm »
Some, more aggressive clips.
Bear in mind that the throttle output is limited to 40% and the port/starboard power output is not balanced at this time.
Very stable platform.
https://photos.smugmug.com/Stevns-Arctic/i-pzPGdxZ/0/06ceca1e/1920/IMG_0191-1920.mp4
https://photos.smugmug.com/Stevns-Arctic/i-QfSXZm7/0/31767760/1920/IMG_0197-1920.mp4
ANDY
« Reply #751 on: June 07, 2021, 10:55:31 pm »
Barras
« Reply #752 on: June 08, 2021, 10:03:44 am »
wow such clean lines and it sounds great well done.  :-))
Taranis
  • Balne Moor MBC
« Reply #753 on: June 08, 2021, 10:00:04 pm »
Thanks Ian  :-)
Some pictures of the RIB. I've been a bit sloppy with the paint but only in close up  %%
My Chrome spray
ANDY
CarlC
« Reply #754 on: June 09, 2021, 07:45:02 pm »
Love the rib, makes my nostalgic for the one I sold.......
Taranis
  • Balne Moor MBC
« Reply #755 on: June 10, 2021, 08:10:34 am »
Mark T take a look at this blog  8)
https://www.modelbouwforum.nl/threads/union-wrestler-1-50.269195/
Lots of videos on this page.
Makes mine look very tame  <:(
 :kiss:
https://www.modelbouwforum.nl/threads/union-wrestler-1-50.269195/page-39
I'm happy that Jan likes my work but I could never go to his level
ANDY
marco
« Reply #756 on: June 10, 2021, 09:12:05 am »
Hello Andy ,
   You have done a great job on your model tug . I am not as advanced on mine but I don't despair to finish it in few months . The blog which is in reference is very interesting .
Marco
Taranis
  • Balne Moor MBC
« Reply #757 on: June 10, 2021, 10:15:26 am »
Thank you Marco
I look forwards to your updates no matter how long you take  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #758 on: June 27, 2021, 07:25:24 am »
Sailing day at Balne Moor today. The weather is ideal without direct Sun and dry.
I'll add some pictures to this tonight  :-)
Crabbing and filming with just one pair of hands
https://photos.smugmug.com/Stevns-Arctic/i-F6MVhBN/0/c4abd0cb/1920/IMG_0709-1920.mp4
ANDY
« Reply #759 on: June 27, 2021, 09:36:03 am »
  O0
Taranis
  • Balne Moor MBC
« Reply #760 on: June 27, 2021, 08:43:39 pm »
After a good 3 hrs knocking about my NiMh transmitter battery was gasping  :((
I found a spare here for Taranis X9D
https://www.modelshopleeds.co.uk/catalog/product_info.php?products_id=34559
On arrival home I checked the lead batteries to find them still close to 13 volts
One at 12.99 lowest at 12.96
The 2s LiPo for bow thruster and my 3s Lipo for receiver were barely touched.
ANDY
Taranis
  • Balne Moor MBC
« Reply #761 on: June 28, 2021, 09:47:10 pm »
I forgot to add feedback following removal of the constantly on ESC cooling fans ( see post 742 )
Proved to be the correct decision without an issue  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #762 on: July 03, 2021, 04:17:17 pm »
So for the benefit of many hours of uninterrupted sailing, this is the next addition. Fed from the receiver aux channel for simple on when required.
ANDY
Taranis
  • Balne Moor MBC
« Reply #763 on: July 24, 2021, 07:06:06 pm »
Filled an hour or so watching paint dry by fitting the pump.
Oops
https://photos.smugmug.com/photos/i-JkrTQH5/0/1920/i-JkrTQH5-1920.mp4
ANDY
Taranis
  • Balne Moor MBC
« Reply #764 on: August 05, 2021, 10:46:22 pm »
All being well, weather dependent will be at Carnaby this weekend. Sunday is looking favourite at this minute.
Bridlington Model Boat Society open day.
ANDY
Taranis
  • Balne Moor MBC
« Reply #765 on: September 02, 2021, 09:26:47 pm »
Now then, that receiver operated switch has proven unreliable on the Taranis radio and will not work at all on the new Paladin no matter how hard you persevere with end point settings. In fact it currently won't turn off! so its removed and a receiver operated relay is on order for the bilge pump. Relay of choice https://www.ebay.co.uk/itm/265293100099?var=565152517070 Because the pump draws only milliamps I'm going to use the receiver red wire as the supply.
While playing with this I decided to fix the male connector in place to make disconnecting the battery easier.
I fitted a couple of crew to better translate the scale of things too.
Fail
Pump will now be switched through a relay
Connector mounted.
Billy Bob
Probie
ANDY
Taranis
  • Balne Moor MBC
« Reply #766 on: September 03, 2021, 12:02:58 pm »
Great UK seller, ordered Wed evening and just arrived. No calibration required just plug it in and it works  O0
ANDY
chum444
« Reply #767 on: September 05, 2021, 03:47:53 pm »
Outstanding build Andy. It looks terrific in the water.
Bill
Taranis
  • Balne Moor MBC
« Reply #768 on: September 05, 2021, 04:00:08 pm »
Thank you Bill.
Just back from a club meet and sailed constantly for easily four hours and the batteries are at 12.99volts  8)
Throttle output is set at 25% max and this gives a good realistic scale speed.
The new radio was down to about 30% battery having been on constant for 5 hrs with the screen at 90% brightness and a 3 min time out setting.
All is good  O0
I might remove the bilge pump as now the power is limited it's actually very difficult to swamp the deck.
ANDY
Taranis
  • Balne Moor MBC
« Reply #769 on: September 10, 2021, 11:53:56 am »
I've decided to keep the bilge pump but only switch it on in the event of a leak.
I've reverted back to the previous pump but decided it's better served with 12 volts so using this adapter I'm taking the feed off the 3s controls battery rather than the 7.4volts I feed to my receiver and servos.
In place and a 3 amp auto blade fuse inline
ANDY
6705russell
« Reply #770 on: September 10, 2021, 12:40:09 pm »
Andy, there are 12volt water detection units you can buy, use one of these and the bilge pump will operate automatically, fitted one in the last lifeboat I built..
Taranis
  • Balne Moor MBC
« Reply #771 on: September 10, 2021, 12:45:10 pm »
Easier to just flick it on if the waterline looks compromised or just to see if there is any water ejected.
There is room for a few pints in the keel under the battery tray.
ANDY
Pages: 1 ... 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31]   Go Up
Page created in 0.026 seconds with 22 queries.
