Author Topic: Neat trick  (Read 4381 times)
cgbillb
Neat trick
« on: January 06, 2019, 12:05:40 am »
 Every need a heat shrink tubing at 10 pm and Amazon wont deliver till in the morning???
 Try this neat trick make your own.
Bill
Athens Ga
ChrisF
  • What's my favourite cake!
Re: Neat trick
« Reply #1 on: January 06, 2019, 05:52:51 pm »
Am I missing something?
Re: Neat trick
« Reply #2 on: January 06, 2019, 06:02:43 pm »
.... same here.  {:-{
TheLongBuild
  • Build em, and play hard..
Re: Neat trick
« Reply #3 on: January 06, 2019, 07:08:36 pm »
My thoughts were that the flexi tape will shrink when heated up.
cgbillb
Re: Neat trick
« Reply #4 on: January 06, 2019, 07:42:54 pm »
We will see once in the water, but has not on my work bench,
I will put the heat gun to it later this afternoon and see what happen.
Bill
cgbillb
Re: Neat trick
« Reply #5 on: January 07, 2019, 12:37:02 am »
Put the heat gun to it for 5 min, on high no problem.
Sorry what do you mean  Am I missing something??
Bill
Athens Ga
johnv
Re: Neat trick
« Reply #6 on: January 07, 2019, 01:02:25 am »
Hi nobody knows what you are on about .You have not explained what you do .You have just put up two pictures .But like the outhers said we must be missing something Cheers John V
cgbillb
Re: Neat trick
« Reply #7 on: January 07, 2019, 01:10:42 am »
I was thinking the title says it all and I have it install into my WTC so no more photos till I charge the battery
but what I did was take the printed circuit board out of the case, so as to gain room in the WTC
I wanted to cover the PCB but all my heat shrink tubing was too small, so I came up with the neat trick
will take more photos when I take it apart again , the WTC
Hope this helps.
Bill
Athens Ga.
Re: Neat trick
« Reply #8 on: January 07, 2019, 09:17:58 am »
In the OP, there is no mention of a WTC and no view of a PCB, so, really, it is just two random pictures without any explanation other than the title saying that it is a "neat trick".
I've been using sticky plastic tape to wrap PCBs and battery packs and provide a water barrier* for the last twenty years, so the novelty escaped me along with everybody else.
* the stuff on larger rolls also makes good deck patches for yachts, as does Duct tape (sometimes "Duck Tape", sometimes "Gaffer of Gaffa Tape)
cgbillb
Re: Neat trick
« Reply #9 on: January 07, 2019, 01:48:16 pm »
OK this is the first time I have used it as a heat shrink tube,
Bill
Athens
GA.
Re: Neat trick
« Reply #10 on: January 07, 2019, 07:57:16 pm »
Is this the same stuff?
coch y bonddu
Re: Neat trick
« Reply #11 on: January 07, 2019, 08:04:38 pm »
WoW that looks too good to be true would YOU Martin get into that  boat MMM dont think I would
cgbillb
Re: Neat trick
« Reply #12 on: January 07, 2019, 08:34:22 pm »
yes that is it    but there are more bands out there  that is what I happen to have
Bill
Re: Neat trick
« Reply #13 on: January 08, 2019, 11:52:04 am »
 We understand now.  :-))
cgbillb
Re: Neat trick
« Reply #14 on: January 08, 2019, 11:54:39 am »
I will do better in the future
Bill
Athens Ga.
Re: Neat trick
« Reply #15 on: January 08, 2019, 03:25:43 pm »
Assume 'we know nothing... We are from Barcelona.'    ok2
( From 'Fawlty Towers' a BBC TV comedy from 1970's! )
Page created in 0.151 seconds with 21 queries.
