Pages: 1 [2] 3   Go Down
Author Topic: floating crane "Greif"  (Read 17116 times)
Re: floating crane "Greif"
« Reply #25 on: July 02, 2019, 12:00:21 am »
Yes Ralph, images are here....
We see about 2.2:1 straight cut gear ratio [16/36?] in your manufactured reducer, but the coding for the Gearbox motor CCH2230 does not confirm the actual reduction ratio
I imagine the luffing of the crane boom would be very slow?.....
What speed do you plan?....or is the threaded bar the worm drive?
[I have seen these drives in old Dockyard cranes......the mechanism is called Bottle Jacks and they usually work in pairs]
taucher
« Reply #26 on: July 02, 2019, 06:19:30 pm »
itīs simply a motor and my gearbox ratio 1:3 . I even  tjink 6V be enough, should not whip.
the best Image I have
Ralph
« Reply #27 on: July 02, 2019, 11:20:02 pm »
This is the casing tube that the Bottle Jack 'worm rod' rotates in......
Depending on the arrangement, many Dock Yard crane luffing mechanism is controlled by this Bottle Jack
The axis of the casing tube is dependent on the angle of luff from the lower to the upped extensions, hence the angle of arc shown
So either the gearbox with the worm rod is pivoted, or the worm wheel is pivoted and the casing stays fixed etc
Southern Sailor
  • Southern Sailor
« Reply #28 on: July 03, 2019, 07:34:35 am »
Ralph, when designing a gearbox like that, how do you know what centres to use for the gears? Regards. Brian
taucher
« Reply #29 on: July 03, 2019, 05:09:28 pm »
everything pivotet, yes . The gearbox at the boom and the treaded rod at the structure.
@ Brian
oure german dealer  has anny tables to calculate this [size=78%]https://www.maedler.de/product/1643/1618/1034/2739/stirnzahnraeder-aus-polyketon-modul-1[/size]
here "d" half, of both gears. if you like learn about gears
https://www.youtube.com/watch?v=F-vcdvqg-zk
https://www.youtube.com/watch?v=qVN2jrn4Kuo
this guys experts  :-))
Ralph
Southern Sailor
  • Southern Sailor
« Reply #30 on: July 04, 2019, 07:31:28 am »
Thank you Ralph. The tables will come in handy.  By the way I have often thought about how to drive the rotation movement of a crane.  A worm drive would be ideal from a speed point of view but otherwise not at all appropriate.  Rather normal gearing for this function.  Haven't looked through your blog yet so it may have been considered here already. Cheers for now. Brian
Southern Sailor
  • Southern Sailor
« Reply #31 on: July 04, 2019, 08:31:25 am »
Also really useful videos.  Thanks.  :-))
taucher
« Reply #32 on: July 12, 2019, 09:02:12 pm »
now you kan see al the pivotes. I use a geared motor now, make 300 rpm
https://youtu.be/GSYFcDeSt4I
Ralph
taucher
« Reply #33 on: April 17, 2020, 06:47:30 pm »
oh the time is running  %)  but itīs done. I finished the boom.
The counterweights are made of thins 0,5mm brass. from photos.
the weights are empty I filled later.
Ralph
steve mahoney
« Reply #34 on: April 17, 2020, 10:19:38 pm »
Excellent, Ralph. A masterclass in brasswork.
« Reply #35 on: April 17, 2020, 10:37:26 pm »
Following on Ralph.....  :-))  ......are the counterweight buckets filled with water on the full sized machine?...... Derek
taucher
« Reply #36 on: April 18, 2020, 07:06:28 am »
if I know how many weight, much later. lead pellets an seal with plaster. so I  calculate.
Ralph
« Reply #37 on: April 18, 2020, 03:14:12 pm »
Award worthy model engineering there Ralph!
awvs
« Reply #38 on: April 18, 2020, 03:48:13 pm »
Simply amazing  :-)) :-)) :-))
Wilhelm
taucher
« Reply #39 on: January 23, 2021, 06:54:17 pm »
Hello again
After the boom, I needed a change. That's how I built a mooring boat. Belongs to the Schramm company which also had the crane.
Now you can continue with the construction. for this I built I-beams 20x8mm. Unfortunately not to sale
Ralph
taucher
« Reply #40 on: May 27, 2022, 09:11:31 pm »
One year break is over
[/size]rope disc cast and machined
[/size]
[/size]
[/size]The slewing ring was not easy
[/size]
[/size]
[/size]
[/size]The structure is standing
[/size][size=78%]ngpostimg.cc/tnhYtTCh]
and move [/font]
[/size]
[/size]https://www.youtube.com/watch?v=6MTUbk_u4jw
[/size]
[/size]Ralph
« Reply #41 on: June 01, 2022, 11:15:56 pm »
Welcome back after your years sabbatical. The ring gear is excellent with a smooth operation. I like the boat :-))
taucher
« Reply #42 on: July 17, 2022, 09:18:28 pm »
Hello again. I have finished the second beam.  Was tricky because my folding bench is too small for it
Now assembling with superstructure
Ralph
« Reply #43 on: July 17, 2022, 10:34:07 pm »
WoW!  Awesome!   :o :o :o
Dreadnought
« Reply #44 on: July 18, 2022, 12:14:31 pm »
That’s amazing  :-))
taucher
« Reply #45 on: January 06, 2024, 06:07:08 pm »
all half jear I can report :embarrassed:
The Kran has function, has a Bucket and is going to floating. It's not the original hull, test only
All so I had buildhave 1m ladder
At last the video
https://youtu.be/opkSTv49BlA
Ralph
taucher
« Reply #46 on: January 20, 2024, 08:49:51 pm »
A little carpentry and I have a hull
Ralph
« Reply #47 on: January 21, 2024, 12:53:30 am »
Ralph......
Many of these 2 jaw Clamshell crane buckets have a secondary trip wire to open the jaws
Details in the following link may assist
https://www.rctruckandconstruction.com/showthread.php?t=13646
taucher
« Reply #48 on: January 21, 2024, 07:12:41 pm »
These too. Not shown in the film because the winch is still being worked on.
https://youtu.be/YDcBxJMJwF4
Ralph
« Reply #49 on: January 21, 2024, 08:15:38 pm »
Super mechanism Ralph & working well  :-))  even in real life, the tripping mechanism is a delicate design function  :o
Pages: 1 [2] 3   Go Up
