Author Topic: typhoon engine  (Read 3055 times)
pipercub1772
typhoon engine
« on: February 07, 2019, 07:16:29 pm »
Hi , I have a single cylinder typhoon engine and boiler but do not know bore and stroke looks about 3/8" ,its self starting in revers with a simple idea and i am wondering what size steam prop it would run and or boat , It looks lovely quality but do not know much about the manufacturer or if they are still in production ,any information would be helpful ,kind regards Allan .
rhavrane
  • Steam passionate collector
Re: typhoon engine
« Reply #1 on: February 07, 2019, 08:00:07 pm »
Bonjour,
I have a TM2 which is a 4,5 cm3 in my TID tug https://www.youtube.com/watch?v=SdVcGuQ-3bg and it is coupled to a 4 blades 70 mm Protean design steam propeller.
My tug Jan de Sterke with a 2cm3 twin JMC https://www.youtube.com/watch?v=0sj-lYo7-z0  is coupled to a 4 blades 60 mm Prophop
steam [propeller.
I generally navigate under a stem pressure of 2 bars to save autonomy and keep a wet steam to complete the lubrication of the cylindeAs the TM1 has only one cylinder, I would ki,ndly suggest you a 4 blades 50 mm steam pitch propeller.
Typhoon is supervised by Anton (Fabrice BRETAGNE, http://www.anton-vapeur.fr/) one of the last French manufacturers. I have more than 10 of his steam machines and I confirm his reputation of quality (prices in consequence).
Raphaël
pipercub1772
Re: typhoon engine
« Reply #2 on: February 07, 2019, 08:07:47 pm »
Bonjour , Rhavrane thanks for that information it was kind of you to reply so promptly kind regards Allan
southsteyne2
Re: typhoon engine
« Reply #3 on: February 07, 2019, 09:23:03 pm »
Hi pipercub1772 your single cylinder engine description is very interesting do you have a pic particularly the reverse mechanism.
pipercub1772
Re: typhoon engine
« Reply #4 on: February 07, 2019, 11:49:55 pm »
Hi i am afraid i am not good at uploading pictures but basically the rear of the crankshaft  has what i can only describe  as a small flywheel with 2 pins protruding and as the regulator moves from forward to-revers the regulator catches on one of the pins and moves the crankshaft of tdc therefore the pins are timed to always admit steam at a point off tdc ,hope this makes sense and i will try and upload a picture if possible,regards Allan
pipercub1772
Re: typhoon engine
« Reply #5 on: February 08, 2019, 12:15:24 am »
Hi just found this on this forum if you put typhoon engine in the search bar and look for the heading  (avoiding tdc  faiure to restart ) it may give you a better description read the 1st post and there is a video posted on the 16 april 2014 if you scrol down the page hope this helps in the video it just shows one of the pins on the rear at the start of the vidio rigards Allan
pipercub1772
Re: typhoon engine
« Reply #6 on: February 08, 2019, 12:25:58 am »
sorry should say in the search bar typhoon steam engine ,Allan
southsteyne2
Re: typhoon engine
« Reply #7 on: February 08, 2019, 12:54:32 am »
Hi Allan ,thanks for your reply , watched the video but did not get a clear view of the mechanism most of the footage was at the pop end ,however I think it must have a slip eccentric to change the valve position otherwise the servo would be pushing or pulling against steam pressure.I can see it would solve the stopping on tdc problem .Cheers
hopeitfloats
Re: typhoon engine
« Reply #8 on: February 08, 2019, 10:33:18 am »
this link may or may not be any use but its here.  https://www.youtube.com/watch?feature=player_embedded&v=LG8fiJMXzhg
frazer heslop
Re: typhoon engine
« Reply #9 on: February 08, 2019, 06:35:57 pm »
It maybe a piston valved engine so simply swapping inlet to exhaust will reverse it as per Bogs Paddleduck engine
The control arm moves the crank over dead centre by pushing the pins
There is an oscillating version in the Model Engineer from the 1950s I think
I did start making one but lost interest
rhavrane
Re: typhoon engine
« Reply #10 on: February 08, 2019, 07:46:27 pm »
This machine has a cylindrical valve and the reverse is ensured by the friction of the rod of the inverter on the crankshaft as we can guess by looking at 0'12" then at 0'37".
Easy to conceive, but hard to machine  ok2
Raphaël
Page created in 0.125 seconds with 22 queries.
