Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22   Go Down
Author Topic: Midwest Boothbay Lobster boat 30" build  (Read 172148 times)
Taranis
  • Balne Moor MBC
Re: Midwest Boothbay Lobster boat 30" build
« Reply #225 on: June 08, 2019, 07:02:04 pm »
No.1 took 3hrs  <:(
no.2 done in a fashion, the stand templates are rubbish  {-)  will make a better one down river.
no.3 done after identifying water line
no.4 in progress.
ANDY
Taranis
  • Balne Moor MBC
« Reply #226 on: June 08, 2019, 07:46:02 pm »
ANDY
DaveM
  • Why on earth do I do this?
« Reply #227 on: June 08, 2019, 08:14:22 pm »
Oh, Andy! Are you going to have some fun masking those six short mahogany strips? Yup - I've been there and I did it (twice). Good fun!!  O0
DaveM
Taranis
  • Balne Moor MBC
« Reply #228 on: June 08, 2019, 08:41:37 pm »
I'm not masking them Dave
I didn't like the idea of CA ing them to finished paint work  %%
My plan is to apply resin and when painting is finished sand back to the mahogany. not bothered about the edges
ANDY
DaveM
« Reply #229 on: June 08, 2019, 11:10:23 pm »
Yep - that's certainly a plan. Stan and I would err towards using cyano onto finished paintwork, but only because we've both done it that way before and had no trouble with it (mine on another subsequent build). I've also used so-called 'canopy glue' for the same purpose with no adverse results.
Wouldn't life be dull if we all thought and acted the same way?  8)
DaveM
Taranis
  • Balne Moor MBC
« Reply #230 on: June 09, 2019, 12:33:16 am »
Alternatively I may mask the whole rectangle off and hand paint the spaces.
I have already used CA on the cabin.
Ignore the black line on the hull it's nothing to do with the water line but was to aid shaping the chines  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #231 on: June 09, 2019, 10:56:23 am »
Before retiring last night I soaked the working deck halves with rubbing alcohol (£6.75 litre delivered) and clamped them down to the sub deck to make them set to the shape
This morning they now sit very snug with no fixings at all
ANDY
« Reply #232 on: June 09, 2019, 11:18:02 am »
"alcohol (£6.75 litre delivered)"........thats good value Andy %) ............did you purchase a truckload?..............
Not sure the planking spacing around the fore & aft lines for the lift out section is/are correct   >>:-( .........Derek
Taranis
  • Balne Moor MBC
« Reply #233 on: June 09, 2019, 11:19:58 am »
It’s as the plan Derek
ANDY
Taranis
  • Balne Moor MBC
« Reply #234 on: June 09, 2019, 12:26:55 pm »
Tip time, take it or leave it  :-)
I don't have years of experience but I have done a LOT of brass.
Etching primer does not perform on brass and car primer is too thick.
I use this chemical for all flux removal and cleaning.
I use exclusively Tamiya FINE primer for plastic & metal in grey or white.
Tamiya also dries fast and I top coat this in less than an hour.
For the crane to cabin fixing I've used a brass split pin and once formed around a same size steel rod I have soldered the split.
Once set up on the model at the right height and angle I've CA'd the pin to crane.
The instructions show brass nail through the top of the crane arm then bent to carry the pulley hanger.
I found this impossible and used brass wire instead and soldered a nut on top then filed to shape
ANDY
Mark T
« Reply #235 on: June 09, 2019, 01:27:06 pm »
Its coming along beautifully mate - I'll give that Tamiya primer a go as I agree with you etch primer just does not quite bite into brass deep enough and comes off quite easily
Taranis
  • Balne Moor MBC
« Reply #236 on: June 09, 2019, 02:49:07 pm »
Thanks Mark. Yes Etch is meant for ferrous and aluminium. Just apply thinly nothing to gain from applying more than a covering and its expensive
The Pot winch was not to my liking and despite missing parts I was supplied with two cabin hatches.
The spindly legs were a fail too for me.
So I made it my way
ANDY
Taranis
  • Balne Moor MBC
« Reply #237 on: June 09, 2019, 03:06:37 pm »
I've now fitted a brass washer to the exhaust base and piped it for a smoke unit. Painted helm and throttles
Cab hatch and winch frame painted
He loves it so far but he's keeping a close watch
One for luck
The inner hull sides and ribs will be white. The cabin bulked will likely be white to. The coaming below the mahogany kicker will be cabin colour.
For now I'm thinking white for the hull exterior but all may change when I colour the deck silver grey with OSMO oil (in the post)
ANDY
Taranis
  • Balne Moor MBC
« Reply #238 on: June 09, 2019, 04:10:38 pm »
Lightbulb moment!
Hatch handle
Screws way up the legs past the weak points
PS please check your kits have the winch pulley!! if you have 2 by any chance I want it
ANDY
chum444
« Reply #239 on: June 09, 2019, 04:55:57 pm »
Just found this presumably for scratch builders  :-))  £10.12 delivered
https://www.ebay.co.uk/itm/233024452632
I have this excellent book. Instructions are geared to a display model but with a lot of effort it probably could be converted to RC. In the 2010 Sep/Oct issue of Ships in Scale R.Royer adapted the plans to a miniature (24 cm) version which I constructed. Rather than impinge further on Andy’s thread I will post some photos of it on my lobster boats thread.
chum444
« Reply #240 on: June 09, 2019, 05:21:37 pm »
So I made it my way
Andy,
 Your installation of the pot hauler is more typical. For the snatch block that hangs from the davit you might want to consider the one sold by BlueJacket. Very realistic and the correct scale. Your boat is looking very good..excellent work.
Bill
Taranis
  • Balne Moor MBC
« Reply #241 on: June 09, 2019, 05:45:33 pm »
Thanks Bill  :-))  Bluejacket are expensive to UK unfortunately. Still live in hope someone will make me one  %%
The BJ lobster boat is $430 dollars plus shipping plus import duty etc . A quite ridiculous price
My calculation makes it £450 to UK buyers after taxes and shipping.
P.S. thanks for the correct terminology! I do struggle you may have noticed  :embarrassed:
ANDY
chum444
« Reply #242 on: June 09, 2019, 08:08:02 pm »
Andy,
I was suggesting their snatch block might work for you. Depending on size, they range in price from 1.45 to 2.94 BP. Shipping costs probably more than the part.  Yeah, their lb kit is expensive.
Apologies for sounding like I was issuing a correction. After all many things in the UK are termed differently than in the US. Those terms are just second nature to one who has been around lobstering. I hate to think of what words I might use to describe components of a puffer.
Bill
Taranis
  • Balne Moor MBC
« Reply #243 on: June 09, 2019, 08:39:30 pm »
Andy,
Bill
It didn't sound like a correction Bill thanks
ANDY
Taranis
  • Balne Moor MBC
« Reply #244 on: June 09, 2019, 09:40:25 pm »
I've just addressed a problem that Stan pointed out to me.
The cabin roof warps in Sunshine and needs magnets.
So much easier to do with a detachable superstructure  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #245 on: June 09, 2019, 10:38:38 pm »
Last one today
ANDY
Taranis
  • Balne Moor MBC
« Reply #246 on: June 10, 2019, 12:10:36 am »
Good morning  {-)
The provided white metal cleats are just not good enough for me infact there are no white metal fittings that I like at all  :((
I found these in my parts drawer as a better solution.
Brass sticks very well to the plastic with CA
Pictures say more
ANDY
Taranis
  • Balne Moor MBC
« Reply #247 on: June 10, 2019, 12:20:54 pm »
ANDY
Taranis
  • Balne Moor MBC
« Reply #248 on: June 10, 2019, 01:56:11 pm »
Decision time. One coat of cloth applied OSMO oil stain silver grey. a trial of a second coat will happen tonight.
The longer I look the more I like.
ANDY
chum444
« Reply #249 on: June 10, 2019, 03:10:30 pm »
I’m liking it! Will be interesting to see what a second application looks like on the trial panel.
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22   Go Up
