Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... 101   Go Down
Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 562173 times)
Rob47
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #125 on: July 28, 2019, 09:02:43 pm »
Can do later tonight also the real ship showing the armour
I will finish this model
frogman3
« Reply #126 on: July 28, 2019, 09:17:40 pm »
OK Bob youre a star cheers i'll have look in the morning  as soon be time to hit the sack as my missus went up at 8pm as we are up every morn at 4-30 to take her to work
chris
Rob47
« Reply #127 on: July 28, 2019, 10:36:59 pm »
Chris looking at the ship and remembering from close up at water level, and looking at my plans I have never seen that rectangular piece before, mine looks shorter at the green tap forward marked edge of main armour belt, it then reduces in height till it would agree with your plans.  aft does the same and ends just by second cutout.
Some images I hope might help  The model shots is the official model of Tiger.. I have two editions of Jecobin plans and neither show it, it could be armour to be added but never was,  the drawings for Victorious are like that, heaps of lets add this but in the end never added.  My belt nearly covers the whole length and the other bit on your plans would be visible on waterline
frogman3
« Reply #128 on: July 29, 2019, 10:09:47 am »
 HI again Bob it looks like my plans are wrong  <*< >>:-( an you are right  :-)) NOT GOOD CONSIDERING THE AMOUNT OF MONEY I PAID FOR THE PLANS   well you live an learn normaly the hard way >:-o .  But  many thanks  :-)) on that again you are a star  :-)) well that's a relief  as I don't now have to build an fit the bloomin armour belt in them postions on the hull.So what I can see of it the A-belt  starts at front on hull just below the start of the bridge an finishes just before the second aperture or cutout  judgein by your green tape marks  so that's what  I will do an build it like that .Just as well I jionded this forum an met you as you've been really helpful an saved me a lot of work regards that A-belt an I cannot thank you enough for you help regards that radar as well an the execlent  tiger badge great stuff cheers I know I wont need them for a fair while but ive found out that in this model  building game from  building my past models  get as much info as possible while you can as it might not be there later an I should think you are the same Bob many thanks
chris
frogman3
« Reply #129 on: July 29, 2019, 10:31:40 am »
Another question Bob while I think of it why is there so many hand rails around the stern ?
chris
Rob47
« Reply #130 on: July 29, 2019, 10:44:17 am »
Flight deck or quarter deck?
frogman3
« Reply #131 on: July 29, 2019, 10:58:53 am »
chris
WELL on the stern hull sides  nr 1/4 deck an flight deck ? or are these hand rails fitted for the hull painters ? but if that's the case why no hand rails on the rest of the length of the hull ?
chris
Rob47
« Reply #132 on: July 29, 2019, 01:35:04 pm »
Chris ah I see what you mean now I can look at images, assuming you mean the verticals, to be honest I have no idea and have tried for years to discover but to no avail so far.
frogman3
« Reply #133 on: July 29, 2019, 03:02:08 pm »
Well Bob I think the vertical hand rails are for the hull painters as if you think about it  as the hull curves outward as it goes upward   ive seen pics of sailors hangin over the hull edge in tiny chairs from ropes paintin the hull  an they can use the handrails to pull themselves closer to the hull when not much to do like a punishment put onto jankers I think the term is as that the punishment terms in the RAF don't know about navy though an when I worked as a civvie up at RAF COLTISHALL it was  unless anyone eles knows different ?
chris
frogman3
« Reply #134 on: August 09, 2019, 09:50:34 am »
HI all well the tiger build continues
an here a couple shots of the bow  as I wanted to make the bow very strong in case she hits the concrete sides of our pond so I fitted light wheigth balsa wood in the openins an then I pourded resin in to make it strong
linkpic
https://ibb.co/3hFfbXn
frogman3
« Reply #135 on: August 09, 2019, 09:52:42 am »
Taranis
  • Balne Moor MBC
« Reply #136 on: August 09, 2019, 09:54:46 am »
an here a couple shots of the bow  as I wanted to make the bow very strong in case she hits the concrete sides of our pond so I fitted light wheigth balsa wood in the openins an then I poured resin in to make it strong
linkpic
ANDY
frogman3
« Reply #137 on: August 09, 2019, 10:00:13 am »
Here in this pic  im nr finished firber glassin inside  the bow section  an oh how I hated doin that F/G as its a horrible smelly job >>:-( but all F/G done now thank goodness just the last bit of matin to fit
https://ibb.co/CbVqMQv
frogman3
« Reply #138 on: August 09, 2019, 10:02:43 am »
HI Andy nice to see you are on the ball cheers
chris
Taranis
  • Balne Moor MBC
« Reply #139 on: August 09, 2019, 10:05:58 am »
ANDY
Taranis
  • Balne Moor MBC
« Reply #140 on: August 09, 2019, 10:07:07 am »
chris
Sometimes I never log out so it sometimes only looks like I'm here when I'm not  {-)
ANDY
frogman3
« Reply #141 on: August 09, 2019, 10:09:49 am »
Here a couple of pics of the stern section bein F/G
https://ibb.co/w0HfPq5
https://ibb.co/3CXbnWR
frogman3
« Reply #142 on: August 09, 2019, 10:20:36 am »
An bow section finished regards F/G an matin all trimed off
https://ibb.co/Vwpx9TN
an rear section done
https://ibb.co/rpKNQ33
frogman3
« Reply #143 on: August 09, 2019, 10:28:09 am »
Shes now begining to look like a ship as she is now all sanded down now ive got to do the tedious bit of findin an fillin any low aera's in hull
 an dimples then more sandin but she's comin on
https://ibb.co/Vm3hhPC
Taranis
  • Balne Moor MBC
« Reply #144 on: August 09, 2019, 10:30:45 am »
ANDY
Taranis
  • Balne Moor MBC
« Reply #145 on: August 09, 2019, 10:31:42 am »
ANDY
frogman3
« Reply #146 on: August 09, 2019, 10:32:16 am »
An jumpin the gun a bit while I had the hull togeather I thought that I draw around it an mark out the deck so its ready to be cut out when im that far ahead
well that all for now
chris
https://ibb.co/VMYMGBL
Taranis
  • Balne Moor MBC
« Reply #147 on: August 09, 2019, 10:32:22 am »
ANDY
Taranis
  • Balne Moor MBC
« Reply #148 on: August 09, 2019, 10:32:50 am »
chris
ANDY
frogman3
« Reply #149 on: August 09, 2019, 10:43:54 am »
OH BOY cheers Andy very nice of you to post pics for me much appreciated :-)) all best till the nxt time
chris
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... 101   Go Up
Page created in 0.257 seconds with 22 queries.
