Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 592079 times)
frogman3
Re: Chris' HMS TIGER (C20) - 1:72 SCALE
« Reply #1575 on: June 14, 2022, 06:57:25 am »
HI all well ive been pondering over these gears to get some to turn that big 1/16th turret gear ring that will turn the big main 6 inch gun turret an thankfully so far ive got succsses as the SAIL WINCH SERVO works the the turret left an right like a dream an nice an slow as ive set the servo morph at just the right speed  an to self centre as as i had it working from a stick on my T/X but it wont stay there when i let go of the stick it just self centres so to get over this ive fitted it in a different channal in the R/X an this one is worked by a flick on off on switch an this idea works lovley so when i flick the switch up or down the big gearing turns what would be the gun turret shaft an when at the end of travel the wouldbe turret (when built) will stay in that postion till i activate the switch an then it goes back to self centreing so im pleased
https://ibb.co/qCf0s8T
frogman3
« Reply #1576 on: June 14, 2022, 07:09:16 am »
AN while i was doin  this  i dint give no thought to how i will get the wires up the shaft to work the small blue micro servo to work the guns barrells to elevate so had a think an thought well i need a centre bolt that has a hole up the centre to take the wires up to the micro servo an i thought right that steel bolt has got to go an the idea ive come up with is a plastic rudder bolt an where the rudder shaft would have gone in the centre hole i can run me wires up that to said servo so that will be done today just got to drill the hole out bigger on my upright drill
https://ibb.co/XJQ4vjh
frogman3
« Reply #1577 on: June 14, 2022, 07:24:16 am »
here a close up shot of the sailwinch servo gear an the big turret gear an they fit like a glove an works well from left an right to back to self centre an go nice an slow like a big heavy gun turret would turn from my servo morph an its set just right an i was very lucky to get that big turret  gear ring  to fit my gears as it was just a guess off ebay so next up to build the gun turrets them selves so i can fit in that blue micro sevo as they will both work off a double fly lead from one channel on the T/X so so far it all seems to be workin unless muphy law strikes
chris
https://ibb.co/zrxcj8L
frogman3
« Reply #1578 on: June 14, 2022, 07:37:15 am »
An i have sent off for a gun fire unit that also flashes leds so it looks like its fireing
so see how i get on wireing this all up as its the blind leading the blind here as ive never had had one before so that should be fun wirein it all in
chris  :-))
Rob47
« Reply #1579 on: June 14, 2022, 09:23:20 am »
Chris wharts the open box of electronics?
I will finish this model
Sealord
« Reply #1580 on: June 14, 2022, 03:17:29 pm »
    Well done mate, I wasn't sure when you showed all those gears in the model room ,but i must admit you've done it. :-))
frogman3
« Reply #1581 on: June 14, 2022, 07:31:39 pm »
HI Bob its a servo morph by action an servo exstender
chris
Rob47
« Reply #1582 on: June 14, 2022, 08:18:15 pm »
Cheers Chris, wow thats huge
Rob47
« Reply #1583 on: June 14, 2022, 08:21:26 pm »
Navy Gets 'tiger' (1959) - Bing video
Chris dont know if did get to see this, watch the 3" turret.
frogman3
« Reply #1584 on: June 15, 2022, 08:02:40 am »
HI Bob well what am i suppoced to watch for on the 3inch gun turret ?
chris :embarrassed:
Rob47
« Reply #1585 on: June 15, 2022, 07:15:20 pm »
Chris
Speed and rate of fire and the 6" is no slouch either
frogman3
« Reply #1586 on: June 15, 2022, 07:50:17 pm »
Chris
HI Bob well i like turrets to turn slowy like the big battle ships turrets did an i have achevied that but got a problem with that micro servo when i treid it all out it worked ok but now that little b+gger is playin up by goin into revese when i go just one way on the other way its good so i cant understand why it wont behave itself an yes ive treid other servo an still the same outcome
chris
frogman3
« Reply #1587 on: June 16, 2022, 04:35:24 pm »
HI ALL well with some help from the guys in the black arts section ive now got over that sevo prolem as the trouble was that i had set the servo morph to too long a train but now i shorten the train to 90 degrees on left an right an volay it all works ok an im very pleased so now i can start to build the main 6 inch gun turret an fit on the knockon switches that should work the gun fire an gun flash unit an that should be exciting as i love my wireing  :-))
ATB ALL
 CHRIS
frogman3
« Reply #1588 on: July 17, 2022, 08:17:44 pm »
HI ALL WELL the build is still goin as im building the big 6 inch gun turret an got it to work from R/C LEFT AN RIGHT an sent for a gun fire sound unit but its not right so im sending it it back but was very good for a machine gun firen but not for a 6 inch gun  <:(  more when i got something to show
chris
frogman3
« Reply #1589 on: July 19, 2022, 09:15:31 am »
HI ALL well heat or no heat im still pushin on with the 6 inch gun  turret build an here at the moment its all just fitted togeather  to see if im on the right track an yes i think i am today im goin to try an build the sides where there will be holes drilled out to accept the main axel bar that allows the guns to elevate up an down
https://ibb.co/VvTgygm
frogman3
« Reply #1590 on: July 19, 2022, 09:22:47 am »
AN A side veiw of said unit but its all got to come to bits again as ive sent off for a hundred white ultra bright leds two will be fitted in the gun barrels an painted  tamyia clear orange to simulate gun flash if i can get the gunfire unit that im hopein for an the blue servo will be fitted in place to elevate the guns barrles up an down from my servo morph
but cant do no more till the  3mm 3v leds turn up
chris
 https://ibb.co/cvMmcCQ :-))
Dan
« Reply #1591 on: July 19, 2022, 07:21:41 pm »
This turret is going to be pretty magnificent when your done with it Chris, good to see your soldiering on through the heat!
And how's Jen doing? I hope she's on the mend!
frogman3
« Reply #1592 on: July 19, 2022, 07:52:47 pm »
HI Dan nice to hear from you an yes the turret is comin on as this afternoon i fitted a 3mm led in just one gun barrel to see the affect an im pleased to say its looks great all i need now is the gun fire sound unit an then i can really get stuck in on the gun turrets but im not gonna make the 3 inch gun s elevate as not enough room as too small an jen well many thanks for thinking of her Dan but a fair way to go yet im a fraid as in another two wks hopefully she will have her plaster removed an the big stiches out then have xrays to see if its all healing corretly if not then maybe more surgury but i hope not if ok then she will have more plaster an a boot on an then will see from there
CHEERS Dan atb
chris :-))
frogman3
« Reply #1593 on: July 28, 2022, 06:20:45 pm »
HI ALL well that gun turret is comin on but its a very awkward shape to build but im gettin there an here in this pic ive just fitted the side walls to get that weird shape
https://ibb.co/nMrQ6QC
frogman3
« Reply #1594 on: July 28, 2022, 06:23:02 pm »
an strenghtin gussets fitted to the side walls
https://ibb.co/x6R1L5P
frogman3
« Reply #1595 on: July 28, 2022, 06:24:20 pm »
now fittin on the out sides of the turret
https://ibb.co/Sw8VygT
frogman3
« Reply #1596 on: July 28, 2022, 06:26:28 pm »
an ive fitted the front part of the turret an cor this is a devil to make but still a lot more to go on
https://ibb.co/QF6fbbc
frogman3
« Reply #1597 on: July 28, 2022, 06:29:01 pm »
an here ive fitted in some hard wood so i can screw down the top of turret as i will need access sometime
https://ibb.co/Y78BnDN
frogman3
« Reply #1598 on: July 28, 2022, 06:29:55 pm »
frogman3
« Reply #1599 on: July 28, 2022, 06:35:07 pm »
an ive just fitted a wire to pull the guns to the elevated postion but it wont work the other way as the servo trys to push the guns down so i'll still be happy to have the guns straight out on the port side
https://ibb.co/k30Zc31
