Hi all
Just a thought, or a bad memory, if you use Dicky's method or HS93's method of rudder construction it is adviseable that the slot you cut in the rudder post is at least half the length of the rudder blade. This being for strength. Its a bit embarrassing when you pick your model out from the back of the car to find you have snapped the rudder off, its only then that you wish you had cut the slot a little bit deeper
Now to the other end of the rudder, the part that turns it; here's a little trick that I use and have used for many a time now. You know your 13 amp flat pin plugs in the house, well, dont throw them away. Remove the earth pin and you can make a tiller arm out of it. Two ways do do this:-
Method OneFile the actual pin down in width, so its about 1/8" thick and then drill a hole in the appropriate place on the blade end to take your linkage rod to your servo. Open up the hole with a drill (that was used to feed the electrical cable through) and either use the cable clamp screw to locate it on to the end of the rudder post, or, do as I do, replace that with a 4mm Aln bolt.
Method TwoThis is my preferred method :) Cut the end of the earth pin off as in B of my scraggy drawing and solder that to a bit of 1/16" flat brass as in C on the drawing. Then mark out and drill two holes equally spaced from the centre of the rudder post hole. I normally make dimension X the same distance apart as the holes in the servo arm. (approx 34mm apart).
Hope this is of some help.
aye
John E
Bluebird
