Author Topic: motor suppression capacitor  (Read 3439 times)
ollychap85
« on: July 21, 2019, 01:21:41 pm »
Can anyone tell me what capacitors I need for a 540 brushed motor .
if anyone can provide an eBay link where I can buy some that would be most helpful
DaveM
  • Why on earth do I do this?
Re: motor suppression capacitor
« Reply #1 on: July 21, 2019, 01:35:51 pm »
Fit one 0.1uF - 0.47uF across the motor terminals. Ceramic disc types are cheapest, but don't use an electrolytic type because they are polarity-sensitive. You can also fit a 0.01uF capacitor between each motor terminal and the motor case. A suitable kit is here https://www.componentshop.co.uk/small-rfi-kit.html
DaveM
roycv
« Reply #2 on: July 21, 2019, 02:41:51 pm »
Hi, sometimes marked 104 for value, you need 50 volt working or greater, most are 50volt+.  They are incredibly cheap if you have a component shop nearby, I used to buy in units of 100 and they were 2p each cap.
Some of the more expensive 540's have internal suppression capacitors already fitted.  I have found that if it all works at 30 odd feet but then there is stuttering at further distances then fitting the caps from motor terminal to motor body will sort this out.
As far as I know you do not have to worry for 2.4 Ghtz, but you might cause problems for someone closeby who isn't.
I have also come across a Graupner 540 size motor with the speed controller built in so there is a servo lead coming from the motor as well.
regards
 Roy
ollychap85
« Reply #3 on: July 21, 2019, 04:32:34 pm »
its just a cheep 540 from hobbyking so dont think it has the capacitors fitted inside I cant see any .
just to be clear would these do the job ? https://www.ebay.co.uk/itm/50-x-10nF-Ceramic-Disc-Capacitor-103-50V-UK-1st-CLASS-POST/300695073517?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
thanks everyone for you help
oliver
coch y bonddu
« Reply #4 on: July 21, 2019, 04:54:25 pm »
yes they will do
ollychap85
« Reply #5 on: July 21, 2019, 06:14:02 pm »
Thanks 👍
roycv
« Reply #6 on: July 21, 2019, 07:21:18 pm »
Hi I agree but it is a lot of money to pay for a cheap capacitor!
Just checked my spares boxes.  I have more than enough for me.  Cap, 0,01 micro farad 50 volt working.
If you send me a self addressed envelope I will send you half a dozen, no charge.
If this OK  I will PM my address to you.  Anyway today is my birthday!
all the best
Roy
ollychap85
« Reply #7 on: July 21, 2019, 10:36:31 pm »
Thanks very much for your kind offer but I have already bought the ones from eBay
I will give a lot of them away next time I go to the boat club if anyone wants any
Hope you had a great birthday
Oliver
canabus
« Reply #8 on: July 22, 2019, 06:36:30 am »
Hi All
The HPI rock crawler motor have them built in.
Canabus
