Author Topic: Seaplane Tender 41 inch  (Read 3261 times)
Nordlys
« on: August 12, 2019, 03:21:47 pm »
Just completed this Launch  7 months work. I have posted elsewhere about the build but cant find the post,
anyway thought someone might like to see the finish result.
Re: Seaplane Tender 41 inch
« Reply #1 on: August 12, 2019, 03:35:27 pm »
Excellent!  Wonderful planking!
Nordlys
« Reply #2 on: August 12, 2019, 03:44:21 pm »
Thanks Martin, I found planking the most relaxing part of the build really. I think around 18metres of 8mm mahogany strip from CMB!
Nord.
Popeye
  • I see no ships!
« Reply #3 on: August 12, 2019, 05:13:36 pm »
Beautiful model/
What motor/s did you use and what was the prop size?
Confucius he say, 'if all else fails.......reach for the  Red Top-Stop'.
Nordlys
« Reply #4 on: August 12, 2019, 07:25:17 pm »
I fitted  two Brushless Mtroniks 28 x 38 1100kv outrunners from Howes Models. Propellers from Component shop were  35mm brass 3 blade.
Component now have a slightly larger motor  35 x 36 1520kv which would be a good deal faster (not in stock when I needed them).
Thats all.
N
skierdive
« Reply #5 on: August 12, 2019, 07:26:46 pm »
Absolutely beautiful model.
Is it based on a kit or scratch built?
Superb work.
Ian.
Nordlys
« Reply #6 on: August 12, 2019, 07:47:23 pm »
Its scratch built. Not a great plan tbh had a few puzzling moments. Its double diagonal planked with plystrips (256 of them!)
N.
coch y bonddu
« Reply #7 on: August 12, 2019, 09:26:52 pm »
Let me guess you had trouble with bulkhead 5 or was it the split bulkhead towards the stern
Nordlys
« Reply #8 on: August 13, 2019, 07:52:59 am »
Ah! Dave you've obviously been there, none of the bulkheads were drawn with clear marking for the notches for the chines etc and both bulkheads forming
the cabin front and rear were - split!  With the top half not shown.
Fortunately I had the experience from making the smaller Seaplane ST 206 to get to grips with the plan/build, being quite similar.
N
Daleb
« Reply #9 on: August 31, 2019, 10:57:02 pm »
That looks brilliant Nordlys, great job indeed  :-))
Page created in 0.015 seconds with 22 queries.
