Author Topic: Couplings & 540 motors- what your Favourite?  (Read 3305 times)
« on: October 03, 2007, 05:04:03 pm »
With the Huco Red coupling now at silly prices,  >:(
..... what your preferred coupling, supplier or method?
Just expanding this a bit .....
What is your favourite 540 / 550 size motor or motor or reduction setup?
(As this is such a wide area, lets just limit this to "slow" or "scale" type boats ie. not fast electrics please.)
Peterm
  • Inactive
Re: Couplings - what your favourite?
« Reply #1 on: October 03, 2007, 05:08:42 pm »
I now use Mobile Marine models couplings.
Pete M
I`m not just old, I`m ancient
Re: Couplings & 540 motors- what your Favourite?
« Reply #2 on: October 03, 2007, 05:16:46 pm »
I still use Huco or Dyco couplings.
The QA is getting worse, but still use them as I KNOW they will transmit the power and are easy to use.
Faraday's Cage
  • Change is inevitable, except from a drinks machine
« Reply #3 on: October 03, 2007, 05:41:59 pm »
I prefer Deans couplings. Even use them on my fast electric boat without any problems.
« Reply #4 on: October 03, 2007, 05:43:31 pm »
Pulleys & belts. See the other thread http://www.modelboatmayhem.co.uk/forum/index.php?topic=6302.0
Nothing like Band Aid!
« Reply #5 on: October 03, 2007, 06:24:48 pm »
I used Deans Marine Nychrome couplings and a Deans Kestral 5, 5pole 9.6v motor in my PT boat. Smooooooooooth  O0
meridian
« Reply #6 on: October 03, 2007, 06:33:57 pm »
Currently using Raboesch couplings - excellent quality.
boatmadman
« Reply #7 on: October 03, 2007, 08:30:35 pm »
found an old 540 motor to use in my springer, measured the free running load - 4amps!!
Found an electronize 540 -23 type jobby, free running load - 0.75 amps!  O0
I use dyco couplings.
portside II
  • tugs at rest
« Reply #8 on: October 03, 2007, 09:00:21 pm »
motors ,any available thats what i use
as for couplings i have started using a piece of threaded /drilled brass and a piece of petrol pipe from halfords, about £2.00 a meter, for the flexable joint and a couple of pins (copper wire)just like Bryan does for his drive lines  at M.M.M.
Also the splined connectors are a realy tight fit in the petrol pipe
Bluebird v2
« Reply #9 on: October 03, 2007, 09:48:03 pm »
Hi there,
I personally like to use the MFA 540 Motors - low drain ones - and also, I like to use, when I am driving props over 40 mm diameter I tend to use the MFA Olympus belt drives originally used by the fly lads - got a 2.3 : 1 reduction driving much larger props - I use the Dyco Couplings unit as well.  However, before I take the couplings out of the shop & BEFORE PAYING FOR THEM  :laugh: I ask if I can try the brass inserts on a prop shaft and also a motor shaft to ensure that they are running true, because, I have had several of these where the hole is not drilled true in the centre
Aye  :D
John E
Bluebird
Page created in 0.613 seconds with 22 queries.
