Technical, Techniques, Hints, and Tips > Radio Equipment
6 Volts or 4.8 Volts
<< < (3/3)
malcolmfrary:
--- Quote from: Howard H on May 16, 2021, 10:11:07 am ---Hi there,
Coming in on the end of this thread, I have a Futaba R304SB receiver and its instructions state that a 4.8 to 7.2v power source is required but NOT dry cell batteries which has confused me a bit. It's for an IOM yacht running a Kingmax sailwinch rated at 6v max, so I'm using a 6v NimH pack at present - switching to LiPo at 7.4v rating could, I suppose, be ambitious?
Howard
--- End quote ---
The thread started with a query about transmitter batteries, and for a low drain application reputable Alkaline batteries are good.  Just a question of remembering to switch off at the end of the session.
The receiver battery, on the other hand, does not just power the receiver, but everything plugged into it.  Alkaline batteries will simply not be able to supply the current required, NiMH will.
Switching to a 7.4 volt battery that can easily sustain that voltage at high current will shorten the life of the 6 volt rated electronics, possibly drastically.  If it is one of the standard servo size KingMax's, I would be very wary about using it in an IOM if looking for the performance that an IOM can offer.  Mechanically, they are great, but to fit into the space left by the multi turn pot, the electronics are ultra small, and it is very easy to let the magic smoke out.  Upping the supply voltage will not help.
Navigation
[0] Message Index
[*] Previous page
Go to full version
