Author Topic: My whistle just stopped whistling  (Read 2386 times)
Pragmatist
  • It's a nautical thing
« on: February 18, 2020, 02:04:16 pm »
I just fitted my Forest classic mini steam whistle and the first 6 or 7 times it was fantastic but then suddenly stopped and just produced steam. Any ideas?
rhavrane
  • Steam passionate collector
Re: My whistle just stopped whistling
« Reply #1 on: February 18, 2020, 07:03:09 pm »
Bonjour,
Three possibilities to my opinion :
   - easy to fix : the hat part of the whistle is unscrewed or too screwwed
   - easy to fix : limestone or equivalent before the vibrating membrane
   - problem : the vibrating membrane peeled off
Can you blow it ?
Raphaël
Pragmatist
« Reply #2 on: February 18, 2020, 08:40:35 pm »
Bonjour,
I think it’s the first one as it’s brand new. Will unscrew and gradually tighten till whistle blows again. My suspicion is that it came loose. It’s an amazing sounding whistle.
rhavrane
« Reply #3 on: February 19, 2020, 08:12:24 am »
Bonjour,
Video welcome  ok2
Raphaël
Pragmatist
« Reply #4 on: February 20, 2020, 07:12:31 pm »
https://youtu.be/61ADY2SSL7I
Before it stopped working.
rhavrane
« Reply #5 on: February 20, 2020, 08:10:43 pm »
Bonjour Matt,
You are right, great steam plant  :-)) and this whistle can effectively be un/screwed
Raphaël
KNO3
« Reply #6 on: February 20, 2020, 08:47:12 pm »
You will find that mouth of the whistle, that is the gap between the base where the steam comes out and the "hat" is critical for sounding good and at a certain pressure. The rule is large gap = high pressure needed to sound. And in the case of your whistle type you also need check that the hat is perfectly concentric with the base.
Pragmatist
« Reply #7 on: February 20, 2020, 08:49:14 pm »
Thanks, yes I’ll have a play and see if I can work out the sweet spot. It’s a lovely whistle for sure
Pragmatist
« Reply #8 on: February 27, 2020, 11:53:36 am »
Still no joy with the steam whistle. Blows out plenty of steam but no whistling. Tightened the hat, unscrewed the hat, tried everything. Brand new whistle. Worked twice when first fitted then nothing.
KNO3
« Reply #9 on: February 27, 2020, 06:24:54 pm »
What steam pressure are you using?
Pragmatist
« Reply #10 on: February 29, 2020, 02:07:51 pm »
Normally 40 but have tried at 60 and also 30. Just lots of steam despite adjustment.
KNO3
« Reply #11 on: February 29, 2020, 02:22:07 pm »
I suspect either a foreign object inside he steam passages or a misaligned bell. Try it on air while adjusting, makes things much easier if you don't burn your fingers.
Page created in 1.446 seconds with 23 queries.
