Author Topic: connectors  (Read 2314 times)
Trucker
connectors
« on: March 17, 2020, 06:51:36 pm »
hi, all
im a bit uncomfortable with trying to squeeze two 14awg size wires into one clamp connector of my action fuse board, ive looked on the web including component shop for some thing that would be neater but not found any thing, so, thinking of making my own with a a strip of brass and soldering the wires,
what method do others use.... when all seems too tight.
i think one connector will need to be a spade/straight  with one wire soldered, another connector would be stepped with wire number 2 soldered, then both brass strips fit neatly into the same clamp..
trucker
coch y bonddu
Re: connectors
« Reply #1 on: March 17, 2020, 07:43:55 pm »
solder a wire to them both heat shrink and then use a single into the action thingy simples
Trucker
Re: connectors
« Reply #2 on: March 17, 2020, 08:31:23 pm »
thanks, thats a neat idea, :}
CGAux26
Re: connectors
« Reply #3 on: March 17, 2020, 10:05:40 pm »
I used these on my latest build, where twin screw with all its extra wiring was required.  They are available with 2 to 5 holes each.  I found it best to strip the wire ½" and solder it before pushing it into the connector.
https://www.lowes.com/pd/IDEAL-In-Sure-100-Pack-Yellow-Push-In-Wire-Connectors/50101800
Page created in 0.016 seconds with 22 queries.
