Author Topic: Single Cylinder Stem Engine - Identification  (Read 1829 times)
DBS88
« on: June 04, 2020, 03:35:25 pm »
Hi This single cylinder steam engine had not been used for years and was seized, it now rotates freely, the bore is cast iron and is immaculate, so I am renovating it and would like to know more about the engine, your thoughts about its manufacturer and construction are most welcome. It is 4 inches tall with a 5/8 inch bore and stroke. Thank you
ooyah/2
Re: Single Cylinder Stem Engine - Identification
« Reply #1 on: June 04, 2020, 04:23:38 pm »
It's an A.J.Reeves TROJAN with a home designed boiler water feed pump.
George.
frazer heslop
« Reply #2 on: June 04, 2020, 05:59:46 pm »
DBS88
« Reply #3 on: June 05, 2020, 06:38:34 pm »
George and Frazer, thank you for identifying this engine and for the additional information, your assistance is very much appreciated.
Theres a few bits and pieces to tidy up on the engine, before I run it. I am looking forward to running it so that I can learn from the pump set up. The pump set up is similar to what I am going to install in my new build, so it will be good to gain some practical experience of it and setting the bypass valve to achieve reasonable run times.
KNO3
« Reply #4 on: June 28, 2020, 01:14:12 pm »
It looks like the Trojan but is not identical: the base is different, it only has 3 columns instead of 4 etc.
Page created in 0.126 seconds with 21 queries.
