Pages: 1 2 [3] 4   Go Down
Author Topic: 1/96 Sandown Class on the way  (Read 19247 times)
midori gaoka
  • Location: On the french coast , in front of channel island
Re: 1/96 Sandown Class on the way
« Reply #50 on: December 30, 2020, 01:32:56 pm »
thank you T888 for your help.
I would like to have the same knowledge as you about some good web sites. As you can see, i did not display chain anchor because I'm not very sure about the size of a link. Research continues
T888
« Reply #51 on: December 30, 2020, 05:03:07 pm »
Regards David
midori gaoka
« Reply #52 on: January 02, 2021, 01:02:01 pm »
Thank you for for help T888.
I'm nearly close to to finish the mast. I've used a 0.02 mm elastic thread to represent shrouds. I'd like to represent my sandown class mine hunter in operation on french coast with another NATO boats. So, I would like to add the NATO and French courtesy pavilion in the mast. But which size? Is there any particular label (with balls and triangle) when they hunt mine ? And in a same time, I would like to order the white british royal navy flag for the back of the boat, but which size ?
T888
« Reply #53 on: January 02, 2021, 01:17:50 pm »
Use BECC flag size calculator http://www.becc.co.uk/contents/en-uk/d50.html you then order the correct flag from Cornwall models.
She looking a good build. :-))
Regards David
midori gaoka
« Reply #54 on: January 06, 2021, 10:06:36 pm »
hello,
So, I've ordered flags at cornwall model. So, the choice is made....The model will be ... HMS Blyth
midori gaoka
« Reply #55 on: January 10, 2021, 08:19:10 am »
Hello,
Theses are my latest photos. For the moment, I try to give the best diection for electric and servo wires, but it is not so easy in a smal boat.
midori gaoka
« Reply #56 on: January 14, 2021, 09:07:22 pm »
Hello,
After checking a part of electric wires, it's time to see if light in the front ship is working.
hama
« Reply #57 on: January 15, 2021, 11:50:08 am »
Very nice!
Hama
midori gaoka
« Reply #58 on: January 18, 2021, 08:59:45 pm »
Thank you Hama for your coments,
I've just checked the light system at back of the model. It looks OK. So 15 LED's  light the boat as real as it could
« Reply #59 on: January 18, 2021, 11:28:09 pm »
Looking really sharp & clear, and whilst it's of no consequence now, you appear to be getting bleed thru of the navigation light [possibility light colour plastic?] to areas 22.5 degrees more than aft of the lights axis....which is a no-no
For the future, you may want to check the Rules, but is a bulkhead wall mounted downward facing flood light [facing @ 90 degrees to FWD] allowed to be illunimated if so close to a navigation light?
Aerodecked
« Reply #60 on: January 19, 2021, 12:23:23 am »
Looking very nice.
If you are still wondering, the day shape for minesweeping ops is 3 black balls in a triangle = 3 green lights in a triangle at night (If memory serves me correctly)
midori gaoka
« Reply #61 on: January 24, 2021, 06:42:53 pm »
Thank you for your help,
A small shop not so far away from my house, made my letters and insign for 4£50, which is not so expensive.
After putting the boat vinyl  letters, I've added few varnish edges with an air spray.
T888
« Reply #62 on: January 24, 2021, 06:48:19 pm »
They came out alright  :-))
Regards David
midori gaoka
« Reply #63 on: January 29, 2021, 09:10:28 pm »
Hello,
As you can see, I'll use an F14 futaba  but with an 2.4 ghz system.
2 channels for each  inclinations of blades, one for forward speed (backward would destroyed blade inclination mechanism), one for smoke generator, one for crane rotation and one for the rise of the cable.
On second photo, you can see servo footprint and hole for cable
midori gaoka
« Reply #64 on: February 03, 2021, 08:39:07 pm »
Hello,
So, the crane trials are completed and it works. I'm looking for divers. I'm painting some sailors in order to represent a mine hunting scene.
Umi_Ryuzuki
    • Models and Miniatures
« Reply #65 on: February 04, 2021, 04:27:56 am »
So many wonderful details.  8) 8) 8)
T888
« Reply #66 on: February 04, 2021, 03:52:56 pm »
Regards David
midori gaoka
« Reply #67 on: February 08, 2021, 08:21:11 pm »
Hello,
It's time to add details at the back. With you help, T888, the blue cylinder is made with a hook in order to be carryed. With the aerodecked advice, I have put 3 balls in a triangle for the mast.
The other rails are missing, they will be there in few days
midori gaoka
« Reply #68 on: February 13, 2021, 03:00:25 pm »
Hello,
Second "sea" trial is made. This one was made to check if weight was correct or not. I was a little bit afraid about the 700 g weight, but hull was in its  lines.
Before, I've had some light yellow pigment to represent shell.
T888
« Reply #69 on: February 13, 2021, 04:00:27 pm »
Very nice you must be pleased, I do like these ships hence why I’d built HMS Penzance
FYI ive attached the link to my model club video when it went to sea for her first sea trails.
http://srcmbc.org.uk/2016/01/02/hms-penzance/
Regards David
« Reply #70 on: February 13, 2021, 05:36:37 pm »
Dave,
Is yours voith powered?
T888
« Reply #71 on: February 13, 2021, 07:15:02 pm »
Yes Bob, and has bow thruster
Regards David
midori gaoka
« Reply #72 on: February 19, 2021, 08:05:03 pm »
Hello,
On the first photo, you can see big gear are linked to a servo. So, when the servo move, big gear move and so the small one as well. The small one is connected to blades. Arrows on small gear help me to see how blades will react. With many trials, I've found how remote control will operate on blades.
midori gaoka
« Reply #73 on: February 24, 2021, 08:05:44 pm »
Hello ,
Aerodecked an T888, with your precious help, I 've completed the mast. After that, I've also finish the dinghy trials. I 've added some piece in lead, about 1g, in order to correct its tilt.
« Reply #74 on: February 25, 2021, 05:02:55 pm »
Super work Midori!
Pages: 1 2 [3] 4   Go Up
Page created in 0.021 seconds with 22 queries.
