Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17]   Go Down
Author Topic: Andy's Amati Riva Aquarama build  (Read 86318 times)
Taranis
  • Balne Moor MBC
Re: Andy's Amati Riva Aquarama build
« Reply #400 on: April 19, 2021, 05:56:42 pm »
Well worth all your effort as it sets her apart and what a beauty  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #401 on: April 19, 2021, 07:28:26 pm »
All set up again along with P40e
I've set voltage alarm at 3.3volts and the ESC low voltage cut off at 3.2volts
ANDY
Taranis
  • Balne Moor MBC
« Reply #402 on: May 02, 2021, 11:52:14 am »
A maiden voyage today was a complete success. The Action Electronics unit played a major part in reducing any wake splash over.
Unfortunately too risky to try capturing on video or at speed. Hopefully Stan might have gotten a picture.
ANDY
DJW
« Reply #403 on: May 02, 2021, 01:43:21 pm »
Hi Andy
Great to see her afloat and sitting well on the water..! Sounds like the hardware is working well too.
Best regards
David.
Taranis
  • Balne Moor MBC
« Reply #404 on: May 02, 2021, 02:04:09 pm »
Yeah thanks David
My chines work great too,I couldn’t ask for better handling. On the plane almost straight away and I have transmitter throttle output set at minus 100  %%  full stick gives a realistic speed.
Reverse steering is also excellent but I need to reduce max throttle on this
ANDY
Mark T
« Reply #405 on: May 02, 2021, 03:28:25 pm »
Congratulations bud the Riva looks fantastic on the water  :-))   It would be great to see a video of her up on the plane  O0
Taranis
  • Balne Moor MBC
« Reply #406 on: May 02, 2021, 03:30:17 pm »
Yes I’d love to share but I don’t want to damage her for lack of hands  :kiss:
ANDY
Mark T
« Reply #407 on: May 02, 2021, 03:34:15 pm »
I don't blame you as the effort that has gone into that finish.  I've always liked the way you can see the reflected water in the varnished wood .....just beautiful
Taranis
  • Balne Moor MBC
« Reply #408 on: May 02, 2021, 03:47:50 pm »
She’s a few coats short yet. To be honest I wish I had used resin and polyurethane in hindsight.
I know I could have achieved as good a finish in 3 coats max.
I might finish it next year or the one after  {-)
Thank you Mark  :-)
ANDY
Merlin
« Reply #409 on: November 26, 2022, 09:31:04 am »
Hi Andy, were did you source the 0.59mm stainless steel pins from as this seems to be a good solution for the trim.
Taranis
  • Balne Moor MBC
« Reply #410 on: November 26, 2022, 04:04:31 pm »
If I didn’t give any clue at the time I’ve absolutely no idea given how long ago it was.🤔
ANDY
Taranis
  • Balne Moor MBC
« Reply #411 on: November 26, 2022, 06:15:12 pm »
ANDY
Merlin
« Reply #412 on: November 26, 2022, 07:45:06 pm »
Thanks for the reply would never have guessed they would be insect mounting pins ....
Mark T
« Reply #413 on: November 26, 2022, 08:35:04 pm »
When there's a will there's a way :)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17]   Go Up
