Author Topic: Hafenschlepper-tug Hein Peba kits summer 2020  (Read 5957 times)
Moller62
« on: July 05, 2020, 04:08:24 pm »
The summer project for 2020 will be the tug Hein scale 1/50 from Peba kits.
The content of the kit is outlined in the thread:
https://www.modelboatmayhem.co.uk/forum/index.php/topic,63380.0.html
by SJG001.
As a headstart I’ve painted the main parts.
Moller62
Re: Hafenschlepper-tug Hein Peba kits summer 2020
« Reply #1 on: July 05, 2020, 04:11:16 pm »
All paints are spray paints from Motip.
The red color is RAL 3002.
The yellow is RAL 1021.
The parts are primed with motip primer 10420.
The paint-scheme is inspired by ‘Maria’ from Mcloughlin & Son and Sturla most likely from Island.
Moller62
« Reply #2 on: July 05, 2020, 04:21:20 pm »
Next step will be the driveline.
Drive line with 130 motors, ø4 mm brass sterntubes, brass bearings ø4/2 mm and steel propeller shafts ø2 mm.
Moller62
« Reply #3 on: July 08, 2020, 10:43:40 pm »
A too tight fit.
The propeller shafts are a very thight fit into the bearings. In fact too thight. The shafts are machined flat in each end, and that has properly left small edges preventing the shafts from entering the bearings.
The shafts were treated with a small file, in order to fit in the bearings.
Moller62
« Reply #4 on: July 08, 2020, 10:45:30 pm »
The bearings was soft soldered to the stern-tubes.
While soldering the shafts were inserted to the bearings to prevent miss-alignment.
Moller62
« Reply #5 on: July 08, 2020, 10:46:43 pm »
The finished sterntubes.
Moller62
« Reply #6 on: July 08, 2020, 10:49:30 pm »
Expanding.
The hole in the stern-tube support(s) had to be expanded with a 4mm drill.
Moller62
« Reply #7 on: July 08, 2020, 10:53:05 pm »
3D-print.
To my understanding most of the parts are 3D printed.
The print appears to be very precise. The deck fits smoothly on the lower hull.
Another example is the stern-tube supports that fits perfectly into the hull.
Moller62
« Reply #8 on: July 24, 2020, 09:30:30 pm »
Aperol SpritzFinally we had a summer-day in CPH and it was possible to move the 'wharf' outside.
This included a highly appriciated possibility to have the inevitable glass of Aperol Spritz.
Moller62
« Reply #9 on: July 24, 2020, 09:32:45 pm »
It was time to install the steerable kort-nozzle's.As a nice feature the fitting for the link between the servo and the rudder-arm includes a lock-nut.
Moller62
« Reply #10 on: July 24, 2020, 09:35:43 pm »
In order to prevent clutter in the steering mechanism, I had to bend the link-shaft.
Moller62
« Reply #11 on: August 29, 2020, 07:02:28 pm »
Motors
In order for Hein to be able to go real slow, I've opted to use Mabuchi FF-130SH-11340 motors, instead of the supplied noname 130 motors.
The Mabuchi motors of this are running with a significant lower RPM, than the nonames, given the same voltage.
The specs are available here, https://product.mabuchi-motor.com/detail.html?id=26 , they are rated at 5700 rpm at 7V.
Moller62
« Reply #12 on: August 29, 2020, 08:38:19 pm »
Propellers
The supplied propellers were very hard to fit. Each propeller has a 'printed hole' on the side.
You are expected to cut a M2 thread in the 'side' of the propellers perpendicular to the shaft-line.
At least that's what I assumed, there are no instructions regarding the fixture of the propellers.
I succeeded in cutting the thread(s) but when inserting the supplied Allan key pinol screw I ruined the thread(s).
Moller62
« Reply #13 on: August 29, 2020, 09:02:00 pm »
Propellers continued
What to do? :o Luckily I had a spare pair of counter rotating Billing propellers.The Billings has a diameter of ø 20mm, that's a little bit smaller than the supplied propellers,
so they will fit in the kort nozzles.
Moller62
« Reply #14 on: August 29, 2020, 09:07:27 pm »
The Billings has an internal M2 threading so I had to thread the shafts with external M2 threads.
Moller62
« Reply #15 on: August 29, 2020, 09:13:15 pm »
A final photo-shot of the Billings inside the Kort nozzles, as seen they are not to big, but hopefully it will work out fine.
Moller62
« Reply #16 on: August 29, 2020, 09:29:56 pm »
Another replacement
The supplied couplings seemed rather stiff so they were replaced by Robbe rubber couplings.http://www.hobby-lobby-modellbau.com/onlineshop/product_info.php/info/p1525_Robbe-Coupling-Tube----1-1386.html
« Reply #17 on: August 30, 2020, 01:59:41 pm »
Don't forget the M2 nut between the end of the shaft and the propeller, so they are 'Locked' in place
Moller62
« Reply #18 on: August 30, 2020, 10:25:53 pm »
Thx. for the hint regarding the locknuts.  :-))
I think I have some M2 nuts somewhere.....
Today was time for the first 'on the water' test.
The rubber fender has just has been glued to the lower hull,
hence the klingfilm preventing surplus glue from gluing upper and lower hull together.
Moller62
« Reply #19 on: August 30, 2020, 10:27:12 pm »
The test included temporary assembly of the RC gear with esc. and v-tail mixer.
Moller62
« Reply #20 on: December 28, 2020, 10:32:17 pm »
Rommel
It looks as if we have a Rommel look-alike onboard.
Moller62
« Reply #21 on: December 28, 2020, 10:33:46 pm »
Rommel
Moller62
« Reply #22 on: December 28, 2020, 10:38:01 pm »
The Rommel figure originates from Tamiya | No. 32557 | 1:48.
https://www.scalemates.com/kits/tamiya-32557-wwii-famous-general-set--105908#
Moller62
« Reply #23 on: December 28, 2020, 10:40:18 pm »
Rommel
Moller62
« Reply #24 on: December 28, 2020, 11:10:37 pm »
The Tow-hook-post
I had a minor issue assembling the tow-hook-post.
It consists of:
the post - 3d print
the holder - a photo-etched part
the hook - 3d print
The post had a recess for the holder but it was too narrow.
After a file had been applied everything was ok.
Page created in 0.02 seconds with 22 queries.
