Thanks all of you for your kind comments!
Derek, you are correct. The ramp is the WT part, the visor can let some water pass but it passes out again when the speed goes down. This is a very small boat, only 62cm at a scale of 1:200, that gives tolerance at a fraction of a millimetre when the ramp closes and that's enough to keep the water out. I didn't know how it would work when I first sailed her but no seals are necessary, I think the visor keeps most the water away. When the visor is raised, some drops of water comes out that's been trapped inside despite the drainage hole in the bottom of the visor.
When working as a 2:and off many years ago I handled ramps, visors, quarter stern ramps and such so I appreciate your work experience
All the best to you all.
Hama
