Author Topic: RCBM  (Read 2493 times)
Rob47
RCBM
« on: August 06, 2020, 04:14:44 pm »
Are the plans from the old Radio Control Boat Modeller, still available, and if so any details ?
I will finish this model
Re: RCBM
« Reply #1 on: August 06, 2020, 04:52:33 pm »
Some of the RCBM feature plans made their way into the Model Boats Plans range now marketed by Sarik Hobbies. They are usually prefixed BM while the plans that appeared in Model Boats are prefixed MM.
Unless you know what you are looking for the best way to track them down online is to vistit the Magazine Exchange website and trawl through the RCBM section where the contents of each issue are listed. Then try to find anything you flag up by doing a search on the Sarik Hobbies site.
Rob47
Re: RCBM
« Reply #2 on: August 06, 2020, 10:53:19 pm »
Sadly no luck, found the magazines ok which i have anyhow, but the plans were ones you had to send for, not the ones given free.
Looking for the ones of HMS Victorious, in the 1988 magazine.  I only need the sheet with the hull lines and frames.
Rob47
Re: RCBM
« Reply #4 on: August 07, 2020, 10:00:49 am »
Martin yes that's it, I have both issues but the plans are not included, there is just the small images of the plan and then details on how tov get the full size version.
Re: RCBM
« Reply #5 on: August 07, 2020, 10:22:35 am »
Not all plans were taken into the Plans Service, and some that were have been subsequently dropped so the chances of finding a set now would seem to be pretty remote.
Rob47
Re: RCBM
« Reply #6 on: August 07, 2020, 10:56:44 am »
sadly I think you are probably correct.  Worth a try though
TheLongBuild
  • Build em, and play hard..
Re: RCBM
« Reply #7 on: August 07, 2020, 12:58:41 pm »
??  This Link  Martin has provided
Is this the one?  https://magazineexchange.co.uk/cw/radio-control-boat-modeller-magazine-july-august-1988-issue.html[/size]
Says the Plan is included,
If not available from Sarik then this is the better option, also probably would be cheaper, or am I missing something ?
Dave_S.
  • Member of Oxford Model Boat Club
Re: RCBM
« Reply #8 on: August 07, 2020, 01:15:55 pm »
I've got a copy of that issue upstairs, I'll check whether it has a plan in it.
Ruining perfectly good kits since 1969.
Dave_S.
Re: RCBM
« Reply #9 on: August 07, 2020, 01:26:54 pm »
I have the article in front of me now. HMS Victorious was a feature plan, not a full size pull out. The plan should still be available, the article gives the plan number as MM1415. The model is 47" long and was designed by Peter Holland, who I remember better as a designer of often unconventional switches to  model aircraft and novelties such as radio controlled robot. The articles includes details of a speed control system using four micro switches.
Re: RCBM
« Reply #10 on: August 07, 2020, 01:49:31 pm »
Like a lot of other plans it is no longer listed. This might have been because there was little demand for it or the original may simply have deteriorated too much to be reproduced.
TheLongBuild
Re: RCBM
« Reply #11 on: August 07, 2020, 02:16:19 pm »
Yes, had missed the bit that it was HMS Victorious he was after, I just saw the Dingy Plan..
Rob47
Re: RCBM
« Reply #12 on: August 07, 2020, 03:02:25 pm »
Thanks one and all for the help and replies.  found both drawings but as they just fit on an A4 page i have no idea what it scales out at.  The drawing would have been 1/200 and I was going to take it to 1/96.  Now me and scales just done mix.  Tried to upload but constant internal server error.
Dave_S.
Re: RCBM
« Reply #13 on: August 07, 2020, 03:07:15 pm »
The original model was stated to be 47" long and was scaled up from an Airfix kit. I don't think it made any claims to be an accurate scale model, so it might not be the best one to scale up from if that is your aim. I got the impression from the article that it was more a demonstration of Peter Holland's mechanical switching and other devices.
tonyH
Re: RCBM
« Reply #14 on: August 07, 2020, 04:02:05 pm »
One inexpensive option you could try is a free card model download. I've tried http://www.shipmodell.com/index_files/0PLAN7B2.html and Victorious comes up as a 2meg dowload of zip.file for her on roughly 20 pages. Includes full hull profiles BUT how accurate I've no idea.Yes, I did scan first and it seems clean but "caveat emptor"!
Tony
Rob47
Re: RCBM
« Reply #15 on: August 07, 2020, 04:37:13 pm »
Tony
Found it but its wrong period, its Vic in WW2 and not 1960, I have the card 1/200 for her so might use that to create the lines and frames
tonyH
Re: RCBM
« Reply #16 on: August 07, 2020, 04:48:35 pm »
Ahh! Didn't check that but I've used one from Marcle in the past and it's quite good fun converting to wood & metal!
Tony
gingyer
Re: RCBM
« Reply #17 on: August 07, 2020, 04:56:32 pm »
Bob,
Sent you a message  :-))
Page created in 0.101 seconds with 22 queries.
