Pages: 1 [2] 3   Go Down
Author Topic: Shannon class lifeboat  (Read 15470 times)
dpbarry
  • If it ain't broke, break it and curse fixing it!
    • Newcastle Lifeboat Station
Re: Shannon class lifeboat
« Reply #25 on: August 28, 2020, 12:16:17 pm »
Hi Taranis.
What is recommended voltage to use on Shannon?
Declan
[/size]
That would give you over 18,000 rpm which is more than adequate on 1:12 but I have no experience of 1:16
I would say they are physically oversize. Normally on 1:12 we use 3542
Taranis
  • Balne Moor MBC
« Reply #26 on: August 28, 2020, 12:31:32 pm »
There isn't one.
You need to achieve circa 18,000 rpm. With brushless the voltage required is dependent on the KV rating of the motor.
A 1250KV motor at 6volts is 7,500 rpm
    1250 at 12 volts is 15,000 rpm
    1250  on 4s 16.8 volts charged is  21,000 rpm on no load (my choice)
Others use only 7.2 volt nicads and 3000kv inrunners
ANDY
dpbarry
« Reply #27 on: August 28, 2020, 02:36:31 pm »
Cheers  :-))
Getting the hang of it now in terms of the RPM/V
Declan
There isn't one.
Taranis
  • Balne Moor MBC
« Reply #28 on: August 28, 2020, 03:32:02 pm »
KV = RPM per volt supplied
ANDY
marco
« Reply #29 on: August 28, 2020, 04:07:50 pm »
In the early afternoon , I received the 2water jets ordered 2 weeks ago . the reference of the enginees delivered with the water jets is A2217 1750kv 5T . I don't know the power in watt . With a3S battery the RPM will be 19425 .
marco
Taranis
  • Balne Moor MBC
« Reply #30 on: August 28, 2020, 04:13:49 pm »
They look fine  :-))
ANDY
marco
« Reply #31 on: September 03, 2020, 10:11:08 am »
Hello ,
    Does anyone know what type of resin is used to make the shannon model hull . polyester or epoxy?
marco
Taranis
  • Balne Moor MBC
« Reply #32 on: September 03, 2020, 10:42:29 am »
I’m not sure but I used Zpoxy products.
Best person to ask is the eBay seller who makes them
ANDY
marco
« Reply #33 on: September 03, 2020, 01:29:11 pm »
Thank you Andy ,
     For the seller I have his email address I will contact him . I want to know the type of résine because I will modify the undersideof the hull to make it flat .
     marco
Taranis
  • Balne Moor MBC
« Reply #34 on: September 03, 2020, 01:31:24 pm »
Pretty sure it is epoxy resin but no harm in asking  :-))
You could also ask in the Shannon Facebook group if you tag Tony there.
EDIT I've posted the question
ANDY
Taranis
  • Balne Moor MBC
« Reply #35 on: September 03, 2020, 02:03:48 pm »
For anyone interested Tony replied it's Polyester resin  :embarrassed:
ANDY
marco
« Reply #36 on: September 06, 2020, 04:18:20 pm »
    I started modifying the underside of the hull to make it flat .this will make it easier for me to set up the "ocean works " water jet .
marco
Taranis
  • Balne Moor MBC
« Reply #37 on: September 06, 2020, 04:19:40 pm »
Thank you for sharing.
Many will be interested in this  :-))
ANDY
marco
« Reply #38 on: September 08, 2020, 05:13:30 pm »
So I started to fill in the 2 openings in the hull with plasticard polished for demouldering later . Then I passed gelcoat inside .
marco
Taranis
  • Balne Moor MBC
« Reply #39 on: September 08, 2020, 05:25:12 pm »
Tres bien  :-)
ANDY
marco
« Reply #40 on: September 10, 2020, 04:01:14 pm »
Bonjour ,
   Fiberglass is now fitted in . When the resin will be dry , light sanding to erase the tracing .
marco
Taranis
  • Balne Moor MBC
« Reply #41 on: September 10, 2020, 04:27:54 pm »
Bravo I like your method  :-)
ANDY
marco
« Reply #42 on: September 11, 2020, 03:06:46 pm »
Bonjour ,
   The underside of the hull now is flat .
marco
marco
« Reply #43 on: September 16, 2020, 09:37:01 am »
Bonjour ,
    start of the assembly of the lifeboat with the positionning of the hydrojets .
marco
Flundle (Speedline Models)
« Reply #44 on: October 06, 2020, 11:25:07 am »
Lifeboat colours are:
Oxford Blue 105
VW Brilliant Orange.
Rail Red
Light aircraft grey.
For both 1/12 and 1/16th scales, aim for 20,000 rpm and you will get around 16,000 in the water flat out. 12,000 is with the boatheld baxk (Max stall)
« Reply #45 on: October 06, 2020, 11:29:05 am »
Use Upol body filler. Spot on stuff to fill everything and of course perfect glue.
« Reply #46 on: October 06, 2020, 11:38:14 am »
Be carefull when fitting jet drives. The reason mine had the suction intakes almost at the stern was because that's were they should be, as per the real thing. That's why my jet drives were there. Being as far aft as possible prevents the boat from exposing the intakes to the air when it rides up under power. As soon as that happens, thrust is lost, instantly and down comes the bow. Porpoising.
The Owner of Hamilton Jet Drive in New Zealand tld me that.
marco
« Reply #47 on: October 06, 2020, 01:46:00 pm »
Thank you for this information and advice . For the speed of rotation I use a 1750 Kv brushless with 3S lipo which should give about 19400 RPM .
In the past I have already built a speedline model , the LCM3 .
marco
« Reply #48 on: October 06, 2020, 02:33:11 pm »
Thanks for the photos. Glad you are enjoying your model, looks really good.
Taranis
  • Balne Moor MBC
« Reply #49 on: October 06, 2020, 06:57:39 pm »
Rest assured Marco there is no dolphin activity with these drives. This was the first worldwide test of the prototype at Wilton Park. I had the trim tabs set too low at speed or it would be planing much better. As these were developed with my help from an existing jet drive the intake position had already been dictated. So yes not in the correct position but not a handicap.  :-))  Nice work
Video
https://youtu.be/FtUBJRC0G50
The original pictured in my hand with the developed ones fitted on the Shannon. I had these made for the MBD Shannon as an alternative to the KMB drives but everyone is using them now. They were never intended to be fitted to a Speedline hull.
ANDY
Pages: 1 [2] 3   Go Up
