Author Topic: robbe esc  (Read 1977 times)
john44
robbe esc
« on: October 17, 2020, 02:10:28 pm »
Hi guys, does anyone know how to set up a robbe Roxxy BL-Control 950-6 to go both ways.
tonyH
Re: robbe esc
« Reply #1 on: October 17, 2020, 03:42:00 pm »
john44
Re: robbe esc
« Reply #2 on: October 17, 2020, 06:10:45 pm »
Thanks for that Tony, tried as stated in the manual 3 times but there are no beeps when the throttle
is moved to full reverse position. {:-{
Thanks anyway
tonyH
Re: robbe esc
« Reply #3 on: October 17, 2020, 09:30:59 pm »
Does it actually do anything? I know when I got a different esc it was a "xxxxx" and in my case the channel was reversed.
john44
Re: robbe esc
« Reply #4 on: October 18, 2020, 03:56:51 pm »
Hi Tony, yes it does work, but only one way.
Re: robbe esc
« Reply #5 on: October 18, 2020, 05:51:49 pm »
Many ESCs want you to start with neutral, let it figure out that neutral has been found, then be offered forward, agree about that, then go for reverse.  If, however, the transmitter has its control logic reversed, it never sees the second limit.  The result is a "non-reverse" ESC.
The usual cure is to operate the transmitter channel reverse before setting up.  Futaba were very fond of doing things that little bit differently.  An ESC designed with Futaba in mind struggles with "others", one designed for "others" will struggle with the Futaba standard.  "Robbe Futaba" seems a well used phrase, they might work to the same standards.
john44
Re: robbe esc
« Reply #6 on: October 18, 2020, 08:49:37 pm »
Tried that Malcolm,Did not recognise neutral setting at mid way.
Have now used another speed controller.
Thanks,
Page created in 0.035 seconds with 21 queries.
