Author Topic: Kort Nozzle  (Read 1344 times)
rickles23
    • Royal Navy Commandos
Kort Nozzle
« on: October 24, 2020, 12:16:50 pm »
I am setting up a Kort nozzle drive.
How far into the nozzle should the prop go?
What about the clearance needed to turn the Kort?
roycv
Re: Kort Nozzle
« Reply #1 on: October 24, 2020, 01:44:38 pm »
Hi, the prop should be shrouded by the Kort so that there is no water thrown off the tips of the blades.
 If the Kort is also a rudder then the prop should be under the rotating shaft of the Kort nozzle.
The clearance is as minimal as you can make it.
 Originally the Mississippi towboats had cut off blades that were a good fit, however experience showed that the not infrequent logs in the river could jam up the prop in the Kort.  They reverted to conventional round tipped blades and these could often chew through the logs.
Roy
rickles23
Re: Kort Nozzle
« Reply #2 on: October 24, 2020, 05:22:14 pm »
Hi roycv,
That is the best description of how to set up a kort nozzle.
I can see it clearly in my mind.
I have just tried a trial set up and I can now see what to do.
Thank you for the reply.
Page created in 0.164 seconds with 22 queries.
