Author Topic: RC  (Read 2116 times)
BOMER
RC
« on: October 26, 2020, 02:13:31 pm »
Hi could I please have some advice on which would be a suitable
Hi could I get information on a suitable radio control system for a Victorian steam launch.[size=78%]  [/size]
Re: RC
« Reply #1 on: October 26, 2020, 08:48:24 pm »
Any 2 channel radio equipment should sort you problem, 2.4 Ghz would be best as you will have no problems using your boat with other radio users.
Do you have a steam plant installed or electric, if electric you will need a speed controller
 Cornwall model boats (see their website will be able to help with the RC equipment)
hope this helps, greater minds than mine will fill in the blanks
SailorGreg
Re: RC
« Reply #2 on: October 27, 2020, 01:57:40 pm »
The details are a little sparse.  Is this a steam launch with a live steam engine, or is it electric driven?
If live steam, can you both control engine speed and select forward/reverse with a single movement?  If not, you will need an additional channel to change from forward to reverse, so 3 channels is the minimum you need (steering, speed and fwd/rev).  If you have any other working features (a whistle for example) you will need another channel. Fortunately, there are some quite cheap multi-channel sets available, such as this one.
If electric, then you will only need two channels, unless again you have other features (lights?) you want to control.
That's the best I can do without some more information.
Greg
radiojoe
Re: RC
« Reply #3 on: October 28, 2020, 09:09:07 am »
Yeah what Greg said and if I were you I would get a 2.4g multi channel set just like the one in Greg's link You don't have too use all the channels but if you are any thing like me you'll need them eventually.  :-))
Joe.
Page created in 0.669 seconds with 21 queries.
