Author Topic: Railing  (Read 1807 times)
Mike M
Railing
« on: January 22, 2021, 06:23:07 pm »
Hi,I'm having some challenges installing my railings on the Fairmount Alpine.My idea was to temp glue the stanchions in place and then pull the small copper wire through them.Then I would solder the wire in place.After I would remove the complete pice and spray paint then re install the railing.Problem I am having is I can not keep the copper tubing from bending as I feed it through the small stanchions holes.Is there another method to do this? Enclosed is a pic of the work so far.Keep in mind everything is mostly temp.Suppose I could attempt to straighten the wire before I paint. ;)
Regards Mike  fourth attempt to download not working. >:-o
Re: Railing
« Reply #1 on: January 22, 2021, 06:32:33 pm »
You might be better using brass wire and solder paint.
https://www.phoenix-paints.co.uk/products/carrs/soldering/soldercreams/c1040
The solder paint isn't cheap but it makes things a heck of a lot easier.
cos918
Re: Railing
« Reply #2 on: January 22, 2021, 07:06:43 pm »
Hi Mike
The copper wire a nighmare to get stright. Like Colin said get your self some 1 meter lengths of brass rod. You can get 0.3mm
 and bigger sizes.
Use flux my self I prefer decent flux I use plumbing flux. Then I use solder paste. This means you can very easily control how much solder each joint gets.
Then solder them up. Afterwards a wash the hand rails in bole of boiling water a a drop or two of washing up liquid. This will remove flux resadue. If you dont the brass will corride.
Done several 1:100 ferries this way.
number-1
Re: Railing
« Reply #3 on: January 22, 2021, 07:56:27 pm »
You could try to stretch the copper wire slightly, this straightens it, works for brass wire anyway.
Re: Railing
« Reply #4 on: January 22, 2021, 08:08:02 pm »
Brass wire stays straight and stiff (un-annealed), copper wire just wants to go bendy.
Page created in 0.014 seconds with 23 queries.
