Pages: 1 2 [3]   Go Down
Author Topic: Amerigo Vespucci Panart 1/84 by Kevin started 2008  (Read 13847 times)
Re: Amerigo Vespucci Panart 1/84 by Kevin started 2008
« Reply #50 on: June 06, 2021, 07:35:33 pm »
Hiya Kevin, with the skills you've shown so far the davits shouldn't give you too much of a problem.
Hope they go well anyway  :-)
kevin547n
« Reply #51 on: June 06, 2021, 08:28:42 pm »
good evening Ray
i made one for the other side,  but shortened the chain since then
Amerigo Vespucci -  Panart - 1/84
https://www.modelboatmayhem.co.uk/forum/index.php/topic,66456.0.html
I tend to do a lot of building at the weekends, then ponder what i have achieved during the week, then adapt, redo or accept the following weekend
« Reply #52 on: June 06, 2021, 08:38:38 pm »
That's very impressive - thanks for sharing  :-))
I've often wondered whether I could have a go at a man-of-war.... or maybe a picket boat or similar. Hmm.... Wonder if something may appear at Christmas  %)
dlancast
« Reply #53 on: June 06, 2021, 09:04:44 pm »
Your model is going to be stunning when completed.  Almost makes me want to buy the kit and give it a go.  Are you going to add sails?
Regards, Dennis
kevin547n
« Reply #54 on: June 07, 2021, 06:05:00 am »
Regards, Dennis
Morning Dennis,
Intentions are for all sails and hand made rope, but will be using crappy kit blocks, although the ones i just bought are far better than the ones supplied in this kit
i need over 400 of them and did not want to pay nearly 30 pence each
i am following another build and looks like this
kevin547n
« Reply #55 on: June 07, 2021, 06:11:54 am »
i have completed one 1st rate 1/72
the Amerigo will be compile with 18 months at 1/84
i have the CAF HMS Enterprise to do next
but would love to do a large 4 masted clipper
dlancast
« Reply #56 on: June 07, 2021, 02:28:15 pm »
Nice, Kevin.... I have done sails like that using "silkspan", wife did the sewing, aged sails with wood stain, etc.  As for blocks, I do understand, the good ones are very expensive.  Kit supplied wood blocks can be "softened" or edge rounded by making a small drum sander out of a tin can, using a drill motor with find sandpaper and lightly tumbling the blocks to "round" the edges.  Or, you can make your own of course.  A mixture of furled and unfurled sails helps, as a full suite of sails  does hide a ton of detail in the rigging, etc.  Choices, choices... no matter which way you go, your model will be and is already, a stunner.  thanks for sharing the build.   I did build one clipper ship model, Makay's "Flying Cloud".... took me 3 and a half years. A challenge.  Cheers :-))   Dennis
kevin547n
« Reply #57 on: June 07, 2021, 08:21:05 pm »
Good evening @dlancast
thank you for the compliments
i now have a decent rigging plan hence the pin rails have increased from the kit 7 belaying pins to 19 or 20
not sure on the material for the sails, i will experiment over the next month or so, paper seams to be an option
losing detail is always going to be an issue with about 30 sails
biggest issue i face meanwhile is making my own rope in upto 8+ different sizes and then what size to put where
kevin547n
« Reply #58 on: June 13, 2021, 08:22:37 pm »
good evening everyone
over the last week i have been ensuring everything fits and works as it is meant to,ie that most of the brackets and blocks etc will be in the right place
so yesterday i salvaged the chains, painted them and set them in place, they look ok to me, time will tell if they are actually where they need to be
over the next week i am going to plan the new display area in the garage and learn to use the Domanoff ropewalk
kevin547n
« Reply #59 on: June 21, 2021, 07:26:36 pm »
i have two weeks left before we possibly have visitors, and all my big builds are taking to much room in the house
the garage used to be the mancave, but once we got the dog, it was better i moved into the conservatory, so the garage is going to be into the display area, the wood arrives tomorrow, and a large cabinet 2.3m x 1m x height is planned
cabinets moved around and top cut down in size
as for the build i am making progress albeit very slowthis morning i made up 6 lengths of rope in two different sizes on the ropewalk, some soldering and shaping some blocks, i wish i knew the names of some of the lines i am putting in but the dropbox info i have is in Geman and all goobygook to me[size=78%]
IMG_0028.JPG[/size]
dlancast
« Reply #60 on: June 22, 2021, 01:26:27 am »
As always, fantastic work sir.  Sure do know about running out of space thing.  After much consideration, I have decided to donate my collection of WW2 aircraft carriers (U.S.) to a nearby Naval Base.  They have responded to my offer and the one handling such things came by last week to view the models and was very impressed.   He said the process has to go through many depts., so it will take a long time before anything happens.  If it does, it will do this old Navy Vet's heart good to know that my models will be viewed and appreciated.  I am always curious what folks do with their models in later years.  They are works of art in my humble opinion.  Built on!  Cheers  ;)  Dennis
kevin547n
« Reply #61 on: June 22, 2021, 05:32:57 am »
my builds are not good enough to sell or give away IMHO but i enjoy what i do and they need somewhere better, the new cabinet will take three or four of them which will be a great help
dlancast
« Reply #62 on: June 22, 2021, 05:51:21 am »
What I have seen of your work sir, your models are very worthy to be admired.  Happy they will be protected.  :-))   Dennis
kevin547n
« Reply #63 on: September 28, 2021, 05:19:32 pm »
to progress the bowsprit i needed to put the lines somewhere, so the formast was made up and put in
IMG_0271.JPG[size=78%]
the bowsprit is fully rigged now, allowing me to get on with the safety nets,
[/size]
Mark T
« Reply #64 on: September 28, 2021, 05:23:33 pm »
That looks great Kevin it’s really nice work you must be very pleased  :-))
dlancast
« Reply #65 on: September 28, 2021, 06:29:15 pm »
Sure gives me inspiration.... wonderful work.   Dennis
kevin547n
« Reply #66 on: September 28, 2021, 06:35:55 pm »
thanks guys
kevin547n
« Reply #67 on: October 07, 2021, 07:12:37 pm »
after completing the bowsprit i did the safety netting 4 of them, card templates then sized the netting which was then stiffened up with wire, then spray panted
Pages: 1 2 [3]   Go Up
