Author Topic: Restoration of a Porsche 934  (Read 3362 times)
kpnuts
« on: March 11, 2021, 09:41:17 pm »
I'm revisiting this build. I'm calling it the restoration of a Porsche 934.
The Eagle eyed among you will notice (apart from a few bits that have fallen off and some spray splatter on the background from its storage in the garage it doesn't need much restoration, well I have a cunning plan, I'm going to age it quite drastically, maybe have it languishing in a yard resting on bricks with the engine on a pallet covered by a tarpaulin, maybe even with a tree or Bush growing out of the car.
Then I am going to do a full restoration of it, that's the plan anyway.
kpnuts
Re: Restoration of a Porsche 934
« Reply #1 on: March 14, 2021, 08:33:07 pm »
OK so made a start on the pallet for the 934 engine, bit more work to make it more realistic but quite pleased with it so far.
kpnuts
« Reply #2 on: March 21, 2021, 09:56:55 pm »
Hi all more work on the 934, first pic is my rendition of the tarpaulin over the engine (its just a bit of printer paper) second pic will be a couple of slabs of concrete when finished.
kpnuts
« Reply #3 on: March 26, 2021, 09:18:11 pm »
Started the rusting on this.
kpnuts
« Reply #4 on: March 27, 2021, 08:52:15 pm »
Started the rusting on this (still a long, long way to go) it a fine line between beliavable and too far quite pleased with the start I know some of the rust looked very granular and there is not enough colour variation but it's definitely a good starting point.
I've decided not to have a tree growing out of it instead it will be a bramble (undecided whether winter spring or summer with nice juicy berries on it) im finding it very difficult to decide on the final setting, I was thinking of having the bonnet chucked on the roof with gouges and scratches or as it is now but I could sling the doors I could sling anywhere in the car or maybe even have one laying on the ground no where near the car almost over grown.
« Reply #5 on: March 28, 2021, 08:12:41 pm »
Your rust effect is brilliant it looks exactly like most of my ford cortina  Mk2  did back in the day  O0 O0 O0
kpnuts
« Reply #6 on: August 07, 2021, 07:59:46 pm »
OK so now the RE20 is done this is back out as you can see the tree is back and  I've started on the tree and dirtied up the car a bit more.
kpnuts
« Reply #7 on: August 08, 2021, 08:41:06 pm »
More work on the 934, started painting the tree and building a porta shed.
kpnuts
« Reply #8 on: August 22, 2021, 07:52:25 pm »
Hi all well I've done away with the tree and I'm calling the destruction of this 934 done, so now onto the restoration.
kpnuts
« Reply #9 on: August 27, 2021, 09:57:09 pm »
OK so the restoration has started
kpnuts
« Reply #10 on: August 28, 2021, 08:45:56 pm »
Work continues on the restoration.
kpnuts
« Reply #11 on: August 30, 2021, 07:56:33 pm »
Hi all more work on this, it's nice to see the engine in the car instead of on the stand.
kpnuts
« Reply #12 on: September 02, 2021, 09:07:20 pm »
Made a start on cleaning up the body panels, gave it a coat of primer to see how bad it looked. Quite pleased, yes it still needs some work but a good start.
Certainly better than this.
kpnuts
« Reply #13 on: September 04, 2021, 09:17:20 pm »
Sprayed some of the restored body panels.
kpnuts
« Reply #14 on: September 09, 2021, 09:00:53 pm »
OK Sprayed the base colour on this quite pleased with the result so far.
kpnuts
« Reply #15 on: September 10, 2021, 08:39:36 pm »
Anyone seen a front engined 934.
No that's not where this is going I just thought it looks beliavable at first glance.
kpnuts
« Reply #16 on: September 23, 2021, 09:13:18 pm »
Got it masked up and made a start on the paint job.
kpnuts
« Reply #17 on: September 26, 2021, 08:02:50 pm »
More work on the restoration
kpnuts
« Reply #18 on: September 29, 2021, 08:47:17 pm »
More work on this.
kpnuts
« Reply #19 on: September 30, 2021, 08:23:59 pm »
Well I've got the wheels on now.
kpnuts
« Reply #20 on: October 02, 2021, 07:35:21 pm »
OK so it's nearing the end now,
I suddenly realised I have it being sponsored by Dunlop and Goodyear.
Easy fix
kpnuts
Re: Restoration of a Porsche 934 finished
« Reply #21 on: October 03, 2021, 04:22:22 pm »
Finished.
