Author Topic: Twin TVR1A  (Read 3098 times)
brassman
Twin TVR1A
« on: March 14, 2021, 04:04:10 pm »
Hi
I have been reading the posts on Mayhem for many years and posted a little about my long term project to build a model Titanic several years ago.  The model is 6ft long - 1:144 scale and  the hull is made of brass plates soldered onto a frame.  I started it [embarrassingly] over 30 years ago and before the wreck was found!
Now I am at the stage of fitting its power plant.  Titanic was triple screw so my idea is a central electric motor and twin steam engines. I have built two TVR1A engines and have  hopefully appropriate clockwise/ anti clockwise propellors.  I have built the TVRA's as identical engines but now I am wondering if I should have built one as a mirror image? Should I just run one in reverse?
Incidentally to make life easier I intend to use the centre propellor with the electric motor  for reverse  which is the opposite set up to the original.
I would be grateful for any comments by the learned members of the forum !
David
DBS88
Re: Twin TVR1A
« Reply #1 on: March 14, 2021, 04:30:12 pm »
That sounds really nice, would love to see some photos, have you decided on a boiler to power the engines? It is crucial to get the boiler size matched to the engine capacity otherwise there is the possibility of running out of steam, I wish you well with your exciting project
brassman
Re: Twin TVR1A
« Reply #2 on: March 14, 2021, 06:21:40 pm »
Thank you for your reply and good wishes.
I have attached some general photos. There is still work to do on the deck fittings, mast and funnels and ongoing repairs as this is already an old model!
With regard to the boiler I have a boiler which was built for me but at a time when my intention was to use twin Marcher engines.  I realise they are smaller  but I anticipate the engines running fairly slowly so I am hoping it will be ok.
Re: Twin TVR1A
« Reply #3 on: March 14, 2021, 06:24:39 pm »
That is certainly some model!
TheLongBuild
  • Build em, and play hard..
Re: Twin TVR1A
« Reply #4 on: March 14, 2021, 06:32:07 pm »
I will agree with Colin, have always found the Vessel of great interest and before it was found or the Cameron film
Love your model and would love to see more pictures, way back zI had plans to build her and did cut the ribs and still have them, think similar size to yours but that was as far as it got.
rhavrane
  • Steam passionate collector
Re: Twin TVR1A
« Reply #5 on: March 14, 2021, 07:04:58 pm »
Bonjour David,
Based on my steam experience, in the steam world, some important things to be taken in account are :
  1 - The size of the propeller regarding the machine (too small, steam consuming, too large, too much effort on the steam machine)
  2 - The size of the boiler (ie its heat surface)
So
 1 - The TVR1A is a 8 cm3, this means that you will need to feed 16 cm3.  For my machines of this size, I use 4 blades 90 mm propellers, so the one I see seem correct. Your boat will not start navigating like an offshore but she will move (I foresee a big inertia for her, helped by the electric additional engine)
 2 - For my 13 - 20 cm3 machines, I like using 125 x 250 mm horizontal boilers with a 40 mm in pipe and 250/300 g/h torch like this one : https://www.youtube.com/watch?v=42a9CLfYG9I and furthermore most of my large steam plants have a coupled pump to reach more than 30 minutes of autonomy because with large machines (> 11 cm3) my "babies" are quite heavy 20 - 40 kilos (certainly less than your one  ok2 )
Have you any idea of the future weight of your boat ?  These are my first ideas, I a sure that other members will have other fruitful  suggestions.
Raphaël
KBIO
Re: Twin TVR1A
« Reply #6 on: March 15, 2021, 10:38:31 am »
Hello Brassman !
To answer to your question : yes, you can set one engine running forward and one running in reverse .
Although, there will be a slight difference in RPM, a well-tuned engine runs the same way , IN or OUT !There is some cases where you can adjust the timing to get more RPM forward than reverse but forget it in your case.Your project is fantastic and I am eager to see the result !Have. good time.Kind regards.
rhavrane
Re: Twin TVR1A
« Reply #7 on: March 15, 2021, 07:07:53 pm »
Bonjour David,
I fully agree with Kbio, you would not feel the difference between the two machines and it is even a great pleasure to have two separate engines for a double propeller boat   https://www.youtube.com/watch?v=ckakDalgPfY and even more on a paddleboat : https://www.youtube.com/watch?v=qLmOZyA-yKQ
Raphaël
brassman
Re: Twin TVR1A
« Reply #8 on: March 16, 2021, 01:30:19 pm »
Hello and thank you everyone for your kind replies.
It is a relief to know I can run one engine in reverse!
Here are some photos of the boiler. It has been stored for many years  [I bought it with the optimistic idea that I could finish the model in a couple of years!]
It is a heavy beast  and has just a couple of water tubes.
I would be grateful for advice regarding finding an appropriate burner  and then my idea is to run a horizontal copper tube  from the boiler flue to connect with upright tubes extending into the ship's funnels.  I am a little concerned about the heat dissipation in this arrangement - The funnels are moulded plastic - perhaps a polyester?
I have a couple of old computer fans that I have in mind to ventilate and cool the interior of the hull .
I will post some more photos later .... [and I will measure the propellors but I bought them as scale replicas]
David
brassman
Re: Twin TVR1A
« Reply #9 on: March 16, 2021, 01:34:20 pm »
oops - forgot the attachments !!
rhavrane
Re: Twin TVR1A
« Reply #10 on: March 16, 2021, 06:53:35 pm »
Bonjour David,
For my boilers which have a 40 mm diameter heat pipe, I like using 250 - 300 g / h torch burners and adapter rings.
On this example https://www.youtube.com/watch?v=DQdXzxUYL4o I have bought these acessories to a French manufacturer who works on demand, JPB
Other example https://www.youtube.com/watch?v=42a9CLfYG9I made by JMC, other French manufacturer.
About your boiler, my concern is its size, quite thichk and too small to my opinion to have some autonomy and even perhaps enough steam for 16 cm3 to be feeded. It is quite far of the 125 x 250 mm I use. How many ml does it content between the two limits of the water level ?
Raphaël
Geoff
Re: Twin TVR1A
« Reply #11 on: March 17, 2021, 11:04:12 am »
On my steam powered destroyer Velox I actually used old black plastic 35mm film pots with the bottoms cut off for the top of the funnels as it gave a nice lip with plastic water pipe for the base of the funnels. Inside I run an alloy inner funnel which gets hot but the plastic is fine.
For wire rigging may I suggest Beadalon - its 7 strand jewelry thread.
Like the model
Geoff
brassman
Re: Twin TVR1A
« Reply #12 on: March 17, 2021, 12:24:28 pm »
Thank you Rahael and Geof  for more help!
I have attached a photo of the propellors  and a bit of the stern arrangement. To me it is a good reminder of the tidying up I should do to many parts of the model  -and to buy some  brass/ copper cleaner!
Am feeling very humble about my abilities when I watch the youtube  videos of your models Raphael - such superb and detailed engineering.
David
brassman
Re: Twin TVR1A
« Reply #13 on: March 17, 2021, 12:25:58 pm »
forgot the attachments again!!
DBS88
Re: Twin TVR1A
« Reply #14 on: March 17, 2021, 12:40:32 pm »
Thank you for the additional info that your are providing, the thing I have learned from this forum is that getting the prop right for steam is probably one of the most effective and cheap improvements that you will make to the boats performance in terms of speed and duration of running, a larger steeper pitch prop will make much better use of the steam. A scale size and style prop is great for show, but for running on the lake a larger prop with steeper pitch will keep the revs down and make the steam last longer. Prop Shop do a nice range of steam props with a pitch of 1:1.5 rather than the scale props pitch of 1:1 I have changed the props on two of my models and the improvement gained is immense
brassman
Re: Twin TVR1A
« Reply #15 on: March 17, 2021, 06:18:24 pm »
After the photos of bits looking a bit grotty I thought I would add a couple  of photos of the lighting ...
rhavrane
Re: Twin TVR1A
« Reply #16 on: March 17, 2021, 08:46:25 pm »
Bonjour David,
I confirm again, the "good" couple propeller / machine is particularly important.
Your propellers are not appropriate for steam at all, especially 8 cm3 machines, sorry.
Your boat deserves high quality propellers, I would kindly suggest you to ask Simon information about his products (these are mines) :  https://www.youtube.com/watch?v=EN0drJGsdDo who has become https://www.youtube.com/watch?v=nGRDus7uIJQ
Example : I saved 30 % to 50 % of autonomy on these boats by changing their propeller :  https://www.youtube.com/watch?v=TVl2NCWmyXA
And as we usually say "one picture is worth 1 000 words"  ok2
Raphaël
xrad
  • Keeper of the Sun Dried Tomato
Re: Twin TVR1A
« Reply #17 on: March 17, 2021, 11:03:37 pm »
WOW! insanely cool model!
for  LED control..maybe check out some C++ programmable microprocessors like Teensy 3.2...can run MANY inputs and outputs ...easy to program...
KNO3
Re: Twin TVR1A
« Reply #18 on: March 19, 2021, 10:56:42 am »
Hi, to answer your question about having two mirrored Graham TVR1A engines: it is actually very easy to build one as a mirror image of the other. Since both are built identical now, you will only need to turn one around, so the reversing levers are on opposite sides. Than on that engine place the flywheel at the other end of the crankshaft, then remove the steam pipes and replace them to face the boiler.
steamboatmodel
Re: Twin TVR1A
« Reply #19 on: March 19, 2021, 11:28:56 pm »
Remember with the funnels only the forward three are used as stacks and would have steam and smoke going up them. The rear funnel was used for ventilation.
Gerald.
Be wary of strong drink. It can make you shoot at tax collectors--and miss. Lazarus Long
Page created in 0.36 seconds with 21 queries.
