Pages: 1 2 [3] 4 5 6 7 8 9   Go Down
Author Topic: Billing Boats Nr 424 Mercantic cargo vessel.  (Read 47315 times)
Taranis
  • Balne Moor MBC
Re: Billing Boats Nr 424 Mercantic cargo vessel.
« Reply #50 on: July 01, 2021, 07:19:22 pm »
They’re both cargo vessels yes
Similar ? No I'd say there are more differences than similarities especially with the construction method and materials besides the appearance.
There’s pictures on page one Stan
ANDY
Taranis
  • Balne Moor MBC
« Reply #51 on: July 01, 2021, 07:35:24 pm »
A bit further.
As this approaches closure I'm of the opinion that the last 20mm or so of the bow tip will be best done with a balsa block. There is nothing to gain by struggling with this.
ANDY
Taranis
  • Balne Moor MBC
« Reply #52 on: July 02, 2021, 08:35:53 pm »
Just one little plank yet to fit before finishing with a block of balsa.
Then the sanding can begin leading to a cover of glass cloth.
I've done the two large wash ports and will probably pilot drill the long ones before the resin coat.
ANDY
Stan
« Reply #53 on: July 02, 2021, 08:41:16 pm »
Andy do you sleep?
Stan.
Taranis
  • Balne Moor MBC
« Reply #54 on: July 02, 2021, 08:49:51 pm »
ANDY
Taranis
  • Balne Moor MBC
« Reply #55 on: July 03, 2021, 08:32:35 am »
Continued last night so now ready for a pencil rub over and course sanding of all the high spots. Then we'll see if any filler is required.
I think if we manage to get this kit back into production I will recommend a taller balsa block at the bow similar to the smit Rotterdam construction.
I should have decided sooner to do this.
Bill mentioned the well deck yesterday and it made me think what is the idea behind the need for one?
ANDY
tassie48
  • bikes birds and burnups
« Reply #56 on: July 03, 2021, 10:03:25 am »
Andy I would put my hand up for a couple of them if they went back into production most differently following your build can't wait to see her on the water do you have a name for her yet tassie48
Taranis
  • Balne Moor MBC
« Reply #57 on: July 03, 2021, 10:28:30 am »
I have the original transfer sheet which looks to be good for 50 years old  %%
So hopefully the name will stick “pun”  O0
ANDY
hama
« Reply #58 on: July 03, 2021, 10:45:25 am »
Hi!
You're doing a great job as usual and I'm following with great interest.
About the well, I'd say it's the designers intention to maximize the cargo capacity on a minimum size given the specific regulations to measure the size of a cargovessel at that time. Size matters when it comes to port fairs, manning and such.
Others may correct me on this, but it's my guess.
All the best!
Hama
nemesis
« Reply #59 on: July 03, 2021, 11:04:53 am »
Hi Andy, going along with Hama. These little cargo boats evolved to the tasks they had to do. Getting into "non- ports", jetties and river that other vessels could not, lying in the mud at low tide and calls that had no facilities at all. Hence the Well deck to make cargo handling easier. bill
nemesis
« Reply #60 on: July 03, 2021, 11:08:18 am »
Andy, If you are serious about a kit make the hull in glass fibre. bill
Taranis
  • Balne Moor MBC
« Reply #61 on: July 03, 2021, 11:10:24 am »
I’m not making a kit Bill
Billing are with my help and it will still be plank on frame.
Thank you both for your thoughts on the well deck, makes sense  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #62 on: July 03, 2021, 04:21:08 pm »
I thought you might like this that is printed in eight languages.
Very true, to be built not assembled.
Even with well cut parts it would still be necessary to adjust to fit.
I've gone to great lengths to get my printer scanner working so it scans to file and I've sent Billing a test email with a scan. If the reply is good I'll be forwarding scans of the keel, frames and deck next week.
Today was intended to be sanding but its rained almost all day so nothing happening.
ANDY
Taranis
  • Balne Moor MBC
« Reply #63 on: July 04, 2021, 11:38:51 am »
Hull sanding day
The pencil aids identifying the low spots
A coat of PT40 then seals and hardens the wood. This will be sanded again and any remaining imperfections filled before a final coat and glass cloth.
ANDY
« Reply #64 on: July 04, 2021, 12:52:03 pm »
It is a really nice hull shape Andy.
Taranis
  • Balne Moor MBC
« Reply #65 on: July 04, 2021, 01:09:37 pm »
Yes thanks Colin. I can understand why a moulded hull would be popular as this definitely requires a great deal
of confidence or advanced modelling skills.
I wonder where Billing will place it in the order of things 🤔 maybe I’ll put this to Jens as a suggestion but I won’t be making a plug myself  %%
I must leave this now until tomorrow and the resin is then easy to sand. Even though dry to the touch it’s very difficult to sand until rock hard.
Hopefully get some cloth on it late on Monday
ANDY
Taranis
  • Balne Moor MBC
« Reply #66 on: July 04, 2021, 02:13:04 pm »
Thanks for the mail Bill  :-))
I've now glued in the correct length rudder tube and trial fitted the rudder where it will be along with rudder shoe. After a bit of re shaping I definitely have room to change from 35 to 40 mm prop. What do you think?
ANDY
Mark T
« Reply #67 on: July 04, 2021, 02:32:03 pm »
Lovely job on the hull Andy it really looks great.  I think I would stay with the smaller prop as I think it will sail like my old Fairmount Alpine.  If I went too fast or if you like over its scale speed it would just get smothered by its own bow wave.
« Reply #68 on: July 04, 2021, 03:31:44 pm »
I agree, stick with the 35mm prop initially, as you say, you can always go a size up if necessary.
Taranis
  • Balne Moor MBC
« Reply #69 on: July 04, 2021, 05:04:25 pm »
Cheers  :-))
Try before I buy  :-)
Here's an example from a Dutch blog of how people have struggled, perfectly demonstrating how inappropriate the original mahogany parts were.
ANDY
Taranis
  • Balne Moor MBC
« Reply #70 on: July 04, 2021, 11:52:19 pm »
Working late I made and fitted one set of hatch coamings, a bit tricky setting them up at the right height and angles.
I also made an oversized bow gunwale to be trimmed to suit later.
Tomorrow I hope to re sand the hull and escape any need for filling before applying glass cloth to one side of the keel and hull.
ANDY
Taranis
  • Balne Moor MBC
« Reply #71 on: July 05, 2021, 05:38:32 pm »
Progress was good today so I didn't sand the hull but continued on deck  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #72 on: July 06, 2021, 06:21:43 pm »
Some ducking and diving but still moving forwards.
I managed to sand the hull. There are some very minor imperfections that will not need filling. The resin and glass finishing coat will cover them.
Finished the bow ribs and gunwale and other bits.
ANDY
nemesis
« Reply #73 on: July 06, 2021, 06:26:03 pm »
Hi Andy, Nice to see the bulb angle going on, a lovely finishing touch, bill
Taranis
  • Balne Moor MBC
« Reply #74 on: July 06, 2021, 06:29:25 pm »
Bulb angle 🤔
Is that the lifting boom support ? 🤭
ANDY
Pages: 1 2 [3] 4 5 6 7 8 9   Go Up
