Pages: 1 2 3 4 [5] 6 7 8   Go Down
Author Topic: Martin's Latest Projects .... fads, whimsy and distractions!  (Read 65528 times)
Re: New Projects ....
« Reply #100 on: September 27, 2021, 04:38:57 pm »
I thought I was being really careful butting up the ends.... seems I need to be even more diligent!
« Reply #101 on: September 28, 2021, 12:17:47 pm »
And if you were modelling a ravine it would look like an excellent rope bridge deck  {-)
fredd
« Reply #102 on: September 30, 2021, 11:59:12 am »
If you are not going to use card former when planking and are proposing using a second layer could I suggest you make mini planks two or three matches wide.
You can then sand chines to best shape for planks
I am well on in building a working matchstick model based on Vic Smeeds "Mistral" details at :-
http://www.lightkeepersjourney.com/hobbies.html#+
Which gives some of the ways I built my model
Fred
« Reply #103 on: October 03, 2021, 06:04:35 pm »
This is weird, This is the update from last week, as you can see, the plate completely covers the template, from end to end ....
Yet this week, when I inspected it, it's now 10mm short???
 No idea!.... But I will do a DNA test on it against the wife!  {-)
Anyway, cut the end off clean, glued in a few extra rows, job done.
« Reply #104 on: October 03, 2021, 06:39:23 pm »
On to the other hull plate side .... don't know which is port or starboard sides as yet.
I know my methodology and double, triple, quadruple checked I had a matching set, left and right,
 .... but if you think about, they ambidextrous!  {-)
Again, gaps in the match butt joints .... and I thought I was being really careful!   <:(
« Reply #105 on: October 03, 2021, 06:52:32 pm »
Next the hull sides ....  no dramas.
Get to listen to great stuff on the radio or documentaries on Utube.
This is about 3 hours worth of matches!
« Reply #106 on: October 23, 2021, 07:07:49 pm »
Carrying on ....
Fitted the lower chines last weekend.... not without snapping them again .... three times!
Not sure, but it may be because I may have used superglue & not waterproof PVA, and it gave up when dampened.
« Reply #107 on: October 23, 2021, 07:14:11 pm »
Fitting the chines was a real tricky clamping job!
 I used 5 minute epoxy.... couldn't figure how to clamp it, so I just held the bow joints, by hand for 10 minutes.
« Reply #108 on: October 23, 2021, 07:17:24 pm »
Getting brave now, cut the chine rails to length at the transom.
« Reply #109 on: October 23, 2021, 07:28:58 pm »
The four hull 'sheets' .... of questionable quality!
I tried really hard but I still managed to leave gaps between some matches, these were filled matches on end and trimmed when dry.
« Reply #110 on: October 23, 2021, 08:47:12 pm »
Hull plates offered up to the framework for a first fitting.
« Reply #111 on: October 24, 2021, 05:01:33 pm »
OK, so hull plates seem to be ready, just need to match everything up to the templates and off we go!
« Reply #112 on: October 24, 2021, 05:12:19 pm »
Now you all saw that the hull plates were short and I fixed them .... then how come they are short again?!???   >:-o
« Reply #113 on: October 24, 2021, 05:24:26 pm »
OK ... sigh... cut the end off and extend... again.
Again gaps at the ends some the matches, still not sure why, but it must be lack of technique ... or patience.  :embarrassed:
I decided to wash the whole new stern extension with a very dilute PVA slurry to help it all bond together and see if there were any gaps.
( Fed up with the mysterious shrinkage.... more next week..... )  >>:-(
JimG
« Reply #114 on: October 24, 2021, 05:51:38 pm »
The shrinkage will be due to two factors. The PVA glue will shrink as it dries and it may take some time to fully dry out. The wood will tend to expand due to absorbing water from the glue, when it dries it will contract again to its original size, the amount is small for each match but over the number you use it all adds up.
Jim
Dundee Model Boat club
« Reply #115 on: October 24, 2021, 05:53:24 pm »
Hmmmm....
TheLongBuild
  • Build em, and play hard..
« Reply #116 on: October 24, 2021, 06:38:37 pm »
Interesting Martin as have just watched yours and also a Vid of someone building the Oil Vessel, interesting to see that they built theirs gluing directly onto the templates ?. Looking at the Trawler myself..
« Reply #117 on: October 24, 2021, 09:08:09 pm »
Yes that the way it was 'designed', ( I use the term loosely! ) but I wanted my build to be all wood, or as much as possible.
 I've hampered myself with a few problems,
 1. I've never built a boat out of matchsticks before,
 2. I've never built an all wood boat before,
 3. I've never built a 'plank on frame' boat before (I'm excluding the Bismarck...),
 4. I've never 'plans' built a model boat before,
 5. I've not used this much wood for anything since building my garden shed 20+ years ago!
     However.... I'm having great fun and loving it!   {-)
TheLongBuild
« Reply #118 on: October 25, 2021, 09:04:27 pm »
Item 5 {-) {-) {-) {-) {-)
« Reply #119 on: November 14, 2021, 03:48:30 pm »
I don't believe it, it's shrunk even more....   >:-o
   ..... and this is after TWO extensions .... a total of about 22mm / 1' longitudinally !    >>:-(   >>:-(
mmartin1980
« Reply #120 on: November 14, 2021, 08:22:05 pm »
looks fun, ive made 100s of matchstick models, and quite a few boats.... sadly where i did this you couldn't exactly use a camera so dont have any pics, looks good so far
« Reply #121 on: November 15, 2021, 08:33:25 am »
What is your glue of choice Martin?   :-)
mmartin1980
« Reply #122 on: November 15, 2021, 11:50:18 am »
Hobby's woodbond pva glue, then a few coats of acrylic clear varnish to seal it
when making long panels i would always double up the layers by doing them at 90 degrees to each other
ChrisF
  • What's my favourite cake!
« Reply #123 on: November 15, 2021, 05:23:59 pm »
Martin - have you thought about turning the central heating off!   :-)
« Reply #124 on: November 15, 2021, 06:02:01 pm »
All the time but wify would turn it on in July if the sun went in!     {:-{
Pages: 1 2 3 4 [5] 6 7 8   Go Up
Page created in 0.287 seconds with 18 queries.
