Im delighted with the interest that's being generated by my small endevour. It may be germaine to point out a couple of things... firstly, this is not my first build though its the first after a rather long absence. I used to sail at Black Park near Slough (in Burnham Beeches). The main thing for me is that there is so much experience here that I would be foolish not to listen to what's being suggested and I can say with certainty that I am not foolish. One part of me wants to pursue this course to SEE IF IT CAN BE DONE...I've not tried building this way before though friends have with varying degrees of success. How did we do it before we had access to CAD? We did it anyway we could, is how. The plans I have and the model indicate a flat bottom anyway which is good for stability and I will be incorporating a drop centre board through the botom of the hull to cope with anything 'sudden'. Displacement is actually the key issue and I plan to tackle that in two ways. Using a kayak type cockpit hidden under the deck superstructure will effectively raise the protected crew area and prevent the ingress of splash water which would compromise both stabilty and the comfort of me. Also a low center of gravity profile will put the crew effectively 70% below the waterline. This should, according to my displacement calculations increase stability by up to 40% on an allready stable platform.
The build will incorporate all available, and size appropriate safety features- I'm NOT going down with the bloody thing if something happens! I have allready spoken to the harbour master's department in Bristol and they do not see a problem (in principal) to what I'm doing. As far as they are concerned, its JUST another boat. To be fair, they said they wouldn't licence it if the guns utilised ANY sort of pyrotechnic device but they didn't turn a hair at my alternative! Finally (for now), I have designed a launching platform that will deliver the ship either stern first or winch/slid laterally into the water... of course, I've got to build that or adapt and existing trailer yet. I figure, lets lay the egg before we build the carton...
Thank you all and PLEASE keep the comments, concerns and advice coming. Its continues to stimulate and helps me to refine the plans.
