Author Topic: Fine wire suitable for 3v lighting  (Read 2773 times)
SimonCornes
  • Member of Potteries Model Boat Club
« on: October 12, 2021, 02:23:47 pm »
Can anyone recommend a source of really fine insulated wire? I need to run 4 pieces down a mast and I want it to be virtually invisible- no thicker than cotton. I had some years ago that looked like rigging rope at 1/32 and that’s what I’m after now. Help!!
Fred Ellis
Re: Fine wire suitable for 3v lighting
« Reply #1 on: October 12, 2021, 02:33:42 pm »
I have used some from an old USB lead
Fred
« Reply #2 on: October 12, 2021, 02:47:35 pm »
Geoff
« Reply #3 on: October 12, 2021, 03:00:53 pm »
As an alternative if you can ensure they are separate you could use very thin plain brass wire as once painted it would almost be invisible.
Geoff
Fred Ellis
« Reply #4 on: October 12, 2021, 03:14:58 pm »
Thinking about this how about some enamelled copper wire, as used in motor windings?
Fred
SimonCornes
« Reply #5 on: October 12, 2021, 03:20:01 pm »
Component Shop sell 30swg (0.25mm) wire.
https://www.componentshop.co.uk/30awg-0-25mm-ultra-thin-insulated-connecting-kynar-wire.html
That’s interesting Colin. That may well do the trick. For LEDs so the current should be minimal. Worth taking a flyer!!
« Reply #6 on: October 12, 2021, 03:26:49 pm »
I've got some for a similar purpose. Should be fine for the few milliamps drawn by LEDs.
SimonCornes
« Reply #7 on: October 12, 2021, 04:38:42 pm »
At 1/32 scale that equals about 3/10” for a 0.25mm wire - maybe an I can go thicker?!!!!
« Reply #8 on: October 12, 2021, 05:24:46 pm »
Simon,
The 30swg is solid  wire. The 29swg is stranded:
https://www.componentshop.co.uk/29awg-0-28mm-7-core-copper-teflon-insulated-connecting-wire.html
Depends on how much flexibility you prefer.
SimonCornes
« Reply #9 on: October 12, 2021, 05:42:12 pm »
Thanks Colin
I’ll go for 29 gauge as I will run it down a mast but also under nav light boxes so I want the flexibility. It’s pretty cheap to! Maybe you get caned on the postage? I’ll probably also look for some twin ribbon wire as I normally end up using Futaba leads - I just like that wire!
Simon
john44
« Reply #10 on: October 12, 2021, 08:53:47 pm »
Hi, I do the same as Fred and use small motor enamelled windings.
SimonCornes
« Reply #11 on: October 12, 2021, 09:17:14 pm »
It’s an interesting idea. I had considered using fine brass rod - 24 gauge or so - and then varnishing or painting it but I’m too married to actually insulated wire and as it’s very small diameter I think it might look right from a scale point of view.
RST
« Reply #12 on: October 12, 2021, 10:46:19 pm »
Correct me if I'm wrong but "Stan" showed how to do good hidden / invisible wire down a solid mast in his Grand Banks cruiser thread.  Afraid I can't remember the post that showed it but no point in him posting the build if it's not referred to after otherwise those of us who know already will still know, and those who don't won't learn.  Am on the phone so links not easy to find, if I can find the exact post I'll share but you have the pointer now.
RST
« Reply #13 on: October 12, 2021, 10:51:12 pm »
Edit, does this work -never too sure on the phone.
https://www.modelboatmayhem.co.uk/forum/index.php/topic,63493.200.html
...It's not an unusual method, been around for many years but Stan shows it here.
SimonCornes
« Reply #14 on: October 13, 2021, 08:48:45 pm »
Blow me, they’re out of stock of 29 gauge black wire. Sod’s law applies of course so I’ve bought brown and may well have to paint it!! I’m
Page created in 0.459 seconds with 22 queries.
