Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16   Go Down
Author Topic: 1/5 Riva Aquarama...  (Read 148676 times)
DJW
Re: 1/5 Riva Aquarama...
« Reply #300 on: January 27, 2025, 01:01:21 pm »
Afternoon All
Next exciting episode...  I've been working on the hatch inlays, started by adding a border of 2x2mm to the hatches, very slightly proud of the frame, then ran them across the disc sander to get the edges in line with the frame, so the hatches still fit basically.
I was careful to clear any excess glue from the inside edge as this would stop the inlay laying correctly.
Then started cutting the inlay strips. My method is to cut the strips a shade long, then sand to an interference fit, including a small chamfer to ease the strip in.  I use the disc sander to ensure I keep the ends at 90 degrees. The strips then hold together without glue at this stage.
Then take them out and spread some glue over the hatch so I can add the strips back in one go.
And the result with the final little mahogany strip (pic below - top left) ready to be pushed into place.
And the hatch in the boat.
I've lightly sanded the hatches but will wait for final sanding once the adjoining deck is all in place.
Next task is to add in the 'slipway'.
Very best regards to all.
David.
1/10th Aquarama Build - https://tinyurl.com/riva-aquarama
1/5th Aquarama Build - https://tinyurl.com/riva-aquarama2
DJW
« Reply #301 on: January 31, 2025, 05:06:26 pm »
Afternoon All
The aft hatch is pretty much done now, slipway is in place:
I used some epoxy with light glass cloth on the underside and the epoxy has seeped through the 2mm mahogany.  It wasn't thinned, so a bit surprised.  I don't think it's going to be an issue as the 'slipway' itself will be covered with cream faux leather and the sides will have some thinned epoxy to seal them anyway so I think the seeping marks will disappear.
Filled in the gap with 0.8mm mahogany...
I've created a recess between the slipway and the side panels that will take the edges of the faux leather, should give a sharper line I think.
I won't be adding the faux leather yet, but this is the look:
That's it for now.  A good weekend to all.
Best regards
David.
SailorGreg
« Reply #302 on: February 01, 2025, 02:03:09 pm »
Getting better and better David.  :-)) :-)) :-))
DJW
« Reply #303 on: February 10, 2025, 05:49:54 pm »
Thanks for that Greg, just realised I'm over 3 years into the build...  So much still to do..!
I've added a layer of glass cloth to the planing surface, starting with a thinned mix of epoxy to seal the wood:
Then laid on the 100gsm glass cloth while the first layer was just still tacky, just enough to hold the cloth in place, started at the stern and brought it forward as a roll to avoid ripples:
I was a bit unsure whether the cloth would be OK on the sharp inside radius of the chines near the bow, but with the tacky hull I was able to really get the cloth into the tight radius and it stayed there.
I added a length of glass tape to the sharp bow, it'll be hidden by the cutwater, so just for strength really.
I used disposable stippling brushes to apply and 2 inch foam roller to work the resin in and get an even resin load.
I then applied an unthinned layer of resin again with a roller to hide the weave of the cloth, then trimmed up the edges and this is current state:
That's also the template for the cutwater, so I can start sourcing the brass to create it.  I'm thinking to make it in 0.8mm brass because its easier to work and solder, then chrome it.  I'd have liked to make it out of stainless steel, but not too familiar working with stainless...
I've been using epoxy from 'Easy Composites', laminating resin matched with their 'slow' curing agent, that gives at least an hour of working time, a bit more when thinned.  I used about 15% of Isopropyl Alcohol by volume and it cured just fine.
Two items of other news...
1. What to do with the smallest servo I've ever seen...?  (It's 17.2 x 16.1 x 8.3mm..!  And weighs 11 grams...)
Well, I had to order a few more and make up a set of working speedo and tachos...
Here's the 3D printed R&D version, 20mm diameter, and 35mm deep, (which can be accommodated in the dashboard), white LEDs to be embedded, chrome bezels to be added:
2.  Had a great day out yesterday at the Midhurst Modellers Show with my 1/10th Aquarama polished up joining the impressive fleet and great people on the Portsmouth & District Model Boat Club stand..!  Maybe next year for the 1/5th...
Best regards to all.
David.
ChrisF
  • What's my favourite cake!
« Reply #304 on: February 10, 2025, 06:13:14 pm »
I've replaced my tablet and can now view your photos directly in your posts again.
Three years, you're joking, blimey! Fantastic workmanship as usual and love the working dials.
Chris
DJW
« Reply #305 on: February 24, 2025, 01:48:47 pm »
Hi Chris, pleased you can see the pics again..!  And thanks for the comments.
A few updates, and a bit of a close call to report...
1. Water Inlet has been fitted, I cut out the mahogany layer of planking to make the brass plate flush, and lined the cut out with epoxy to seal it. I think I'll use silicone sealant when the inlet is finally fitted to get a watertight seal... I've added a 2mm ply layer on the inside and glassed it in so it should be strong enough in the event the fitting takes any knocks.
2. Props have been drilled to take 3mm grub screws with conical ends, so they lock the props to the shafts, I'll keep the locknut too to make sure the props don't go anywhere..!  I drilled the props while on the shafts so the drill cut a 'cone' into the shaft threads for the grub screw to locate in.
3.  I've fixed the prop tubes and shafts into the hull...  The motors, mounts, thrust bocks and prop tube have been taken apart and put together at optimal alignment, so they become one piece of hardware.  The black shapes are 3d printed wedges that go under the mounts to get correct shaft angle.
I then fitted the motors to their mounted positions and enlarged the cut out where the tubes exit the hull, so there was no interference from the hull on the tubes, to keep alignment.  I then fitted the P brackets into their recesses and inserted the shafts.  Happily they all lined up as expected.
I poured epoxy with a syringe to fit the P brackets, they're also held by two 4mm SS bolts each.
So at this point all was well...  And I masked the tubes passing through the hull before adding epoxy resin and glass tape to seal the tubes in:
Maybe some explanation required for the tubes as they pass through the hull.  The main prop tubes are 9mm OD, there's a 40mm end piece of 10mm OD (9mm ID, silver soldered on) that provides a housing for the bearing at the end of the tube.  Then the brass you see in the above pic is 11mm OD (10mm ID), these are cut to provide a more aesthetic pass through of the tubes, also to reinforce the area of the cut out...  So all the brass tubes are an interference fit together and either silver soldered or epoxied together.
And now onto the problem.  I turned the hull over and started to add resin / tape around the tubes and into the slots.
The shafts, P brackets and rudders are held in those ply slots / cases (stringers..?) to I wanted resin above and below the tubes to seal and hold them firm, which I did.
And I left the boat overnight.
Next morning resin was well on it's way to being solid.  I'd left the shafts in place to ensure alignment wile the epoxy took hold...  I took one of the shafts out no trouble, but the second was absolutely solid. You know that feeling when you realise you've screwed up...  Resin had dripped onto the shaft past the masking tape, then run down the shaft, into the now firmly attached P bracket.  Not good, not good at all.
I ended up standing the hull on end and soaking the P bracket in acetone to soften the resin, then had to grip the shaft with a mole wrench and gently start to get some movement of the shaft...  Plenty of acetone and coaxing of the shaft later, I have got it out.  The P bracket bearing needs replacing, the shaft needed some attention to get rid of the grip marks.  So disaster avoided, and kicking myself for not masking properly.
I now need to trim up around the pass through area on the outside of the hull and will post some pics.
I've added some threaded inserts inside the hull that allow ply covers to be attached over the prop tubes, will retain the electronics boxes, and hold down the battery covers.
That's it for now.
David.
DJW
« Reply #306 on: February 26, 2025, 05:39:19 pm »
To follow on, here's the underside of the hull with tubes, shafts, P brackets and rudders in place. Props are 2.75 inch diameter, 3 inch pitch.
I do like a shallow shaft angle, tip clearance on the blades is 5mm.
Tube passthroughs now faired in, I used Milliput so it's pretty strong.  This section of the hull is going to have some general sanding, filler / primer and several top coats of white, so not too stressed about any current sanding marks.
And from the side, all the underwater hardware including the water inlet.
And this is one of the bearings, just about visible.  They're about 25mm long made from a low friction engineering plastic designed to be used as bearing material, same as in the P brackets.
My thought now is to carry on with fitting out the cabin at the bow so I can get to installing decking.  This means installing speakers and dock lights before they get more tricky to access.  They're already made up so I'm hoping no dramas...   :-))  We have to hope don't we...
Very best regards
David.
DJW
« Reply #307 on: March 05, 2025, 04:27:44 pm »
Afternoon All
Well I thought there was no reason I couldn't get on with the side decks while I get the bow closer to being able to add that deck, so that's what I've done.
And the birch ply layer in place:
Then cut some of the thin birch ply to seal the sundeck, and provide a base for the cushioning:
So pleased to see the shape of the boat coming through with the recent work...!
Also had the 3D printer busy with some better fitting Speaker tubes:
And in place:
That's it for now.
David.
DJW
« Reply #308 on: March 10, 2025, 01:00:21 pm »
Afternoon All
Progress made on the deck, now have the second layer of 0.8mm mahogany cut and ready to apply:
All of the decking so far has been made up in same way, 1mm birch ply then two layers of 0.8mm mahogany sheet.
And just wanted to say that the Proxxon 90 degree drill has been so useful, gets me out of trouble when I've forgotten to drill a hole and now have limited access...  Like here:
I'll post a quick update when the deck is complete.
David.
DJW
« Reply #309 on: March 17, 2025, 01:27:33 pm »
An update as the deck is pretty much in place:
I gave some thought to getting the deck curves correct around the sunbed and cockpit bench seat.  I ended up 3D printing an 80mm (to match the required radius) sanding drum / cylinder that attaches to my Proxxon polisher, The deck mahogany was then fitted oversized and sanded back to where it should be, and the drum approach has done a nice job:
I used the polishing machine as it runs a lot slower than the 90 degree drill, I tried that first and it was a bit frantic...
And while that deck was clamped up and drying...  I've been giving thought for a while about transporting the boat, it's getting some weight to it now and while it does just fit in the car, I need a plan for getting it from car to lake.  I decided to see if I could build a trailer out of some spare Aluminium extrusion (40mm or 4040), and while it's a work in progress, here's result so far:
I had a couple of spare trolly wheels / hubs.  I've used some spare thick walled 10mm Stainless tube with 3D printed sleeves to connect the wheel hubs to the extrusion.  Then printed some fittings that locate and hold the sled / stand on the trailer frame.  So the idea is that the boat on its stand can be placed on the trailer as is, or the boat can be lifted off the tailer and stand.  I'm thinking to use some straps / Velcro  / or bungies to keep everything in place.
I've realised I need a slightly longer handle to avoid me being bent double...  So need to get the mitre saw out again.  I tried 3D printing some 45 / 135 degree brackets, but I'm not sure they're going to be strong enough, so I've ordered a set of stronger aluminium brackets designed for 4040 extrusion from Amazon.  The shole handle will need to be removable I think for transportation.  It should come down to backing off two Allen bolts to allow removal.  Then the trailer will be no longer than the boat.  Each wheel is held by one Allen bolt, so if needed they could come off too.
A useful aspect of the extrusion is that once the boat is complete I can move where the axle is in order to get the balance of the boat correct, so a bit of weight on the 'nose' of the trailer, but keep most over the wheels.
Now I'd like to finish the trailer in its basic form and move on to fitting out the bow cabin.  But we shall see..!
David.
stuart22
« Reply #310 on: March 17, 2025, 08:26:33 pm »
Hi David, And I thought my Clyde was big, stunning work as usual.  :-)) hopefully we will be able to get too the lake soon. how do you plan to get the boat into the water?
DJW
« Reply #311 on: March 18, 2025, 12:19:21 pm »
Haha..!  Hi Stuart.  Well I reckon I might need a hand getting the boat into and out of the water...  Or a crane.   :-))
Best regards
David.
rhavrane
  • Steam passionate collector
« Reply #312 on: May 01, 2025, 10:57:10 am »
Bonjour,
For fun, a classic one and a 3D printed one : https://youtu.be/lEBofzMeaYE and https://youtube.com/shorts/7bvPnRJs7G8  :-)) ok2
Raphaël
DJW
« Reply #313 on: May 13, 2025, 05:05:11 pm »
Hi Raphael
Two beautiful Aquarama's there, very nice builds.
I've realised I've not posted an update in a few weeks.  I've been busy with a few other things, but the 1/5th has made some progress.  And it's had it's first road trip...!  Went down to the Popham Model Show at the weekend and the 1/5th saw a lot of interest even though (or maybe because) it's a part build at the moment.  I'm a member of the Portsmouth & District Model Boat Club so the Riva was on the club stand.  At least I know now for sure that I can fit it in the car..!
I've been working on a few of the fittings, including the crew...
I found male and female 3D printable figures (on Thingiverse), all very articulated so can be made to sit and so on.  Full size they are 18 inches tall, so I've printed at 72% to get to 1/5th scale, they seem just the job.  I like the idea of being able to reprint as required, to optimise for what I need, and giving me plenty of painting practice...  I can also choose which joints will be fixed and which will be articulated.
And for fun...  Because the limbs can articulate, how about a servo driven throttle control..?
And his right hand will be on the servo driven steering wheel...  And his head, well it's going to turn with the wheel in the direction of the turn.  Well it's all a bit of fun, and part of the reason for going big with the scale was to add some toys..!
Dock Lights are now ready too, some high powered 5mm LEDs into 3D printed lamps and reflectors.
And I've resumed sanding the hull.  I'm planning to take the boat to Wicksteed and am hoping to have the hull sanded and sealed at least.
David.
rhavrane
« Reply #314 on: May 13, 2025, 06:27:24 pm »
Bonjour David,
Glad to hear you enjoyed these boats, so here are some more  :-))
An Ariston: https://youtu.be/zXoaF2_14Ig
Another one with a sound module: https://youtu.be/PjmiYGKUqmU
And a "monster": https://youtu.be/pBMR0g-t8jw Unfortunately, thermal propulsion is banned on most of our waterways now...
Raphaël
DJW
« Reply #315 on: May 23, 2025, 03:40:33 pm »
Well, the week didn't go as planned...
I felt the stern needed a bit more sanding to get everything shaped and flush.  So I sanded, and then I sanded a bit more.  Right up to the point that I went through the mahogany to the birch ply.  The ironic thing is that's exactly what I did with my 1/10th too, same place. What can I say...  :((
So I'm now resigned to taking out the mahogany on both stern quarters, and will replace with 2mm mahogany rather than a laminate approach.
To be honest I'd not been that happy with the stern quarter panels anyway, they turned out a darker colour than the rest of the deck, so maybe it's the universe telling me just to get it right...   O0
I spoke to 'Hobbies' who'd supplied the Mahogany and asked them to ideally pick some redder tinted panels from their stock, and thats's what they did.  Have to say I was impressed by their delivery too.  Ordered 3.00pm Friday, opened the package 9.30am Saturday...
I have been busy progressing some parts of the cabin, getting some varnish coats on, some upholstery on the bunks.
Also been busy starting on the dashboard, I'm 3D printing some dials, thinking to see whether I can smooth the bezels enough to take some chrome paint...  If not I'll have to make them out of brass and get them chromed, we'll see.  Each will have a couple of LEDs installed for backlighting. Tacho's will be servo driven, maybe the speedo...
Instruments have an acetate face, then a spacer followed by a dial face, they'll have dayglo orange indicator.
And at the back a servo and holes for 3mm LEDs.
Planning to be at Wicksteed on Sunday, and will have the 1/5th in the car as a work in progress if anyone wants to see it.
David.
DJW
« Reply #316 on: June 03, 2025, 05:23:13 pm »
Afternoon All
Great to get back to Wicksteed and chat with you friendly folks..!
The 1/10th ran well, and the 1/5 got plenty of attention, I wonder whether it'll be a runner by next May...
I've set about the repair of the stern quarter deck sections where I'd sanded through, chiselling off the mahogany...
That wasn't fun...  And here with all the Mahogany off and sanded back:
And the new 1.5mm to bring up to correct height:
And the result, I think it's a lot better than the first attempt, so I'm pleased, and relieved...
And while the glue was drying, I've been busy with elements of the dashboard.  The dials, not 100% faithful to the original Aquarama, but a lot now seem have new instruments and some are white dials.  These are generic dials with the Riva Logo added.  Tachos are 25mm, the rest are 20mm:
And some Hi Vis needles...
Also cut out a new dashboard, some of the dimensions of the first one were wrong:
And the crew just watching and being no help at all...
I'm pleased the stern deck fix is behind me now.  Feels I can move the build forward again.
I tried some veneer for the cockpit sides, but not happy with it, I'll just use the veneer as a template to cut some 0.8mm mahogany and see if thats better,  the grain in the veneer just looks wrong. IMHO...
This is the veneer...
That's about it for now.
David.
ChrisF
« Reply #317 on: June 04, 2025, 10:40:23 pm »
Looking fantastic as usual, well after your rectification works! I bet your heart fell, but it's great the end result is better than the first. Funny how it works out sometimes.
That veneer does look pretty poor doesn't it. I've even had mahogany where the grain is unacceptable. That's the trouble with having to use scale 1:1 timber for 1:x model builds!
Chris
ChrisF
« Reply #318 on: June 06, 2025, 08:38:36 pm »
Hi David. This is the trouble with reading your posts!   {-)
DJW
« Reply #319 on: June 09, 2025, 01:14:37 pm »
Hi Chris..!  What can I say, I've spent so much more on the tools than the boats themselves. Here's the 90° drill drilling yet another impossible hole..!
The issue with sanding through the stern and the fact that the new solid mahogany looks so much better than the laminate I tried has brought me to another realisation.  I need to remove the rest of the laminate from the deck...  I've just received more 1.5mm mahogany and the colour match with the 'new' stern, and the planks is just so much better.  And it's the deck that is the main part of the build that will be seen.  The chisel will be sharpened and busy again.
In other news.  I've installed the dock lights. I need to be able to remove them for varnishing / or future maintenance, so I've printed a back plate with nuts embedded:
These plates are now epoxied to the inside of the hull, and allow the lights to be bolted in from the outside, bolts are M2.
I've added the wiring too, there are small connectors that allow full removal of the lights.
I'm trying to progress the 'cabin' so I can work on the deck, so after the dock lights I thought I'd look at the speakers, and a similar approach, a backing plate with captive nuts.
Mahogany side panels are now also fixed on place:
That's current state of play.
David.
DJW
« Reply #320 on: June 19, 2025, 03:40:40 pm »
Afternoon All
Lengthy update today...  Been busy.
The forward speakers have now got their final mounting rings that take nyloc nuts, nuts are an interference fit, and a little cyano to make sure.
And they're now mounted:
The speakers and tubes are mounted cabin side, but getting them out would not be easy once the deck is on.
And why stop at two speakers...  So there's another small speaker in the cabin:
Because an Aquarama needs a few tunes from time to time, so I found a small MP3 player that can be controlled by an Arduino, that can in turn be controlled by radio control.  I'm using the DFPlayer Mini, (£7.49 for 3 from Amazon) with an Arduino Pro Mini.  It's set to power up and random play from a selection of tracks on one channel, and volume on another channel, I'm thinking to assign that to a rotary know on the TX.
It's all working, but a bit messy at the moment:
The Futaba is just plugged in to check the volume control.  I now need to put the various modules together ready for installation.
And to finish on the subject of speakers, the two exciters are now mounted and will be fixed in place on the hull sides, I'm hoping they'll give off enough vibration to see on the waters surface, on a good day...
I've attached them to aluminium plates that are epoxied to some 2mm ply, then they'll be epoxied to the side planking:
Been looking at the dash too, I need more depth behind the dash so some of the support had to go, and a section behind the steering wheel stiffened.
(Electronics are in view above as I needed to test the wiring to the forward speakers...)
And as you can see in the pic above, I've started on the planking layer of the cabin.  It's a compound curve fore / aft and port / stbd, so planking is only way I think.  This is 2mm x 10mm bass as used for the main hull.
Also using the same clamps with elastic bands to keep the planks tight together. Plus the small spring clamps to keep the plank edges lined up.
And state of play as of 30m ago...
Laborious as always, but satisfying to see the deck curves materialise.
David.
T888
« Reply #321 on: June 19, 2025, 07:46:48 pm »
Hi David,
She coming along, very nice work :-)) :-))
Regards David
DJW
« Reply #322 on: June 24, 2025, 05:37:19 pm »
Hi David
Thanks for that, always appreciated..! Feels like progress is moving fast at the moment.
The forward deck is looking better.
I started at the middle and worked outward, numbering each plank.  I'm really pleased and more that a little relieved that the symmetry is perfect, I ended up with 29 planks on each side of centre with same overhang.  As that's the widest section of the beam, that's a beam of 580mm...   :-))
And here it is finished...
Edges trimmed with plane and sanding block, pencil scribble added...
And 20 minutes with the Proxxon belt sander later:
I'll be sanding a little further with a wide block to make sure any high spots get removed.  Then cutting the mahogany for the deck sides, and I still have to remove the current mahogany on the side decking to replace with matching colour wood... Once that lot's done, it'll be the forward deck inlay, really looking forward to that.
I've tried the sound system and am really pleased with the bass but slightly muffled sound. I've also played with the Frsky programming to mix the two sound systems when using the shafts for differential steering, so using the shafts in opposing directions for manoeuvring at low speed.  The two sound systems do indeed reflect the two 'V8s' running at different speeds.
That's it for now.
David.
DJW
« Reply #323 on: June 27, 2025, 11:27:02 am »
Morning All
I've shaped the forward deck a bit more and am happy with the result:
I think the forward deck and its inlay are one of the most visual parts of the Aquarama, so this first planking layer has to be right.
And I've cut the mahogany for the side of the forward deck.  In this pic you can really see how the colour of the centre mahogany is wrong, too red, big mistake.  It's days are now numbered before it meets my set of chisels...  The curved pieces are made up from three 100mm wide mahogany planks, for visual effect I'm trying to keep the grain running fore / aft, and hoping that after some sanding the glued joints will be less apparent.
Also made a start on creating the 'music player' that will find it's way to the boat, moving it from the development stage:
To a board that can be integrated:
That's a 12V down to 5V supply on the left, under it a capacitor to smooth the power supply, then the MP3 board in the middle and Arduino Pro Mini on the right.  Start / stop and volume controlled from the transmitter, track playing order is randomised by the Arduino from about 10 at the moment that are on a micro SD card.
That's all for now.
David.
DJW
« Reply #324 on: July 02, 2025, 03:58:59 pm »
Afternoon All
Well, the mahogany deck V1 is no more...
Had to use a couple of chisels, not a nice task...  But that thin mahogany just had to go.  I think it's also giving me the opportunity to blend the forward deck to the side decks a little better.  There's a small step in levels between the birch ply of the side decks and the lime / bass planks of the forward deck:
Next task is to cut new side panels and forward deck panels.
Also been playing with the Arduinos again.  :-)
The dashboard is now getting 2g servos behind all the dials not just the tachos as I originally planned. As the build is 1/5th the dash is about 35cm wide, the dials are 25mm and 20mm faces. The tachos will be driven by one Arduino that takes a PWM feed from port and stbd ESC channels, these servos / tachos will then show the power being applied through the motors.  I'm using an Arduino rather than a y lead for a few reasons.
1.  I want the tachos to operate correctly in forward and astern, to show the motors are operating independently when used for manoeuvring on shafts.
2.  I want the tacho dial pointers to do a full sweep on power up, then settle to an idle position and sync this to the sound system.
3.  I want the tacho pointers to display say 600rpm at idle, so when the sound system is active on tick over, but no throttle applied.
4.  I realised that I then need the system to be smart enough to understand when the sound system is powering down, and so to set the pointers to zero rather than just power off.
A second dashboard Arduino will control all the other dials except the speedometer.  I'm thinking that these just need to do a full sweep as they wake up, then rest at a set position (i.e. fuel level and so on), then on power down of the sound system, return to zero like the tachos.
A third Arduino... Will I think be needed for the Speedo as this will be driven by a GPS module, for providing speed across the water (SoG, Speed over Ground).  I'm using a GY-NEO6MV2 NEO-6M GPS Module (£7.59 from Amazon), SoG is then passed to the Arduino which deflects the Speedo dial pointer accordingly.  {-)
So far I have a testbed with couple of servos doing the startup and shutdown routines described above, that code will be needed on the three Arduinos and can be extended to more servos quite easily.  I also have the tacho code servos going to an idle position after startup, and then responding correctly to throttle input going ahead, but not yet astern.  Still a work in progress, but it's coming along.
And finally that GPS module, not started with that yet:
That's about it for now.  Off to do some sanding and cut some mahogany...
David.
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16   Go Up
Page created in 0.025 seconds with 22 queries.
