Pages: 1 2 [3] 4 5 6 7 8   Go Down
Author Topic: Celestine ( Deans Marine )  (Read 79672 times)
cos918
Re: celestine
« Reply #50 on: June 14, 2009, 09:43:16 pm »
Well a fair bit has happened.
Got the lights in on number 3 deck and made the lights up for number 2 deck.
well the frame/lift is made . Now I have to make a Linear actuator to push it. Once this has been made and tested and the whole thing works ,only then can I paint it and put the plastic card around it.
Sean
Re: celestine
« Reply #51 on: June 15, 2009, 03:20:22 am »
Hey John,
Great build. I have a concern on your build. I saw you used expanding foam in your hull. I have seen in a couple rc boat that used that foam explode when the sun hits the ship. That foam expands when the ship gets hot from warmer weather even if its dry. You might think about removing it from the bow section which is fully sealed. Its such a nice ship I would hate for something bad to happen. I know some of the warship in the US have tried expanding foam with damaging results. I just wanted to bring it to your attention. :-)
Best Regards,
Sean
cos918
Re: celestine
« Reply #52 on: June 15, 2009, 06:50:11 am »
Hi Sean. I have heard about this , So there is a 10mm  air cap between the top of the foam and the deck hope fully should be enough. She sit next to a window in the work shop and there has been no effect yet.
cos918
Re: celestine
« Reply #53 on: June 21, 2009, 10:23:59 pm »
Here's the actuator that will power the lift. Still have to connect the motor and set it up.
ZZ56
Re: celestine
« Reply #54 on: June 23, 2009, 12:21:16 am »
Outstanding work so far, working lights and ramps, the whole nine yards!
Are you gonna put in a working miniature bar for all those thirsty travellers?   ok2
cos918
Re: celestine
« Reply #55 on: June 23, 2009, 06:27:16 pm »
Hi  and thank you for the complements. There only one bar and that's mine for when this boat dose my head in which it does on regular basises.
cos918
Re: celestine
« Reply #56 on: June 19, 2011, 10:43:24 am »
I have restarted Celestine.
Glue the lift in and remade the actuator with a new motor and gearbox. Bench test ok. Hope fully will test it it the boat in a few days.
More Coffee
Re: celestine
« Reply #57 on: June 20, 2011, 12:30:05 am »
Stellar job on the lights and the lift. :-))
gibson
Re: celestine
« Reply #58 on: June 20, 2011, 12:15:15 pm »
Just found this build and read through it.....fantastic job you're making here and glad to see you've restarted work on her.
Good luck and look forward to seeing her progress :-))
Dale.
cos918
Re: celestine
« Reply #59 on: June 20, 2011, 03:51:03 pm »
Tryed the  motor gearbox in the hull. The snakes must be tighter due to bendsin the hull not incountered on the bench test. the motor did not move the lift at all, gutted after all the work. Never mide. I have ordered two bigger motors/gearboxs from china via ebay.
More coffee thanks she will have 100s of LED by the time I am finished with her.
Dale thanks for the kind words.
Lift on hold till motors turn up about 20 day from now.So have turned my atachion to her main crane. As it is a small crane I dont know if it is worth bothering with motors on it. I will build it so it can be adapitaed later ie it will turn and lift by hand.
Paularai
Re: celestine
« Reply #60 on: June 27, 2011, 08:52:59 pm »
Awesome work John, incidentally where did you get those railings?
cos918
Re: celestine
« Reply #61 on: June 28, 2011, 02:36:15 pm »
Hi Paul
The Railings came with the kit. Ron Dean will sell a set if you require some.
pugwash
Re: celestine
« Reply #62 on: June 28, 2011, 03:11:04 pm »
John I don't know how I managed to miss this build thread - very interesting and must say you are doing a
great job on what appears to be a complication with the stern ramps and lift.
Geoff
cos918
Re: celestine
« Reply #63 on: June 28, 2011, 03:18:26 pm »
Thanks Geoff
The ramp works fine ,its got a slight bow in it so I might rebuild it out of brass and copper clad pcb. The lift has hit a stop now untill I can try new more powerfull motors that are on there way.
Paularai
Re: celestine
« Reply #64 on: June 29, 2011, 09:42:27 pm »
Thanks John, when you bringing her to Bristol for a test?
More Coffee
Re: celestine
« Reply #65 on: June 30, 2011, 01:56:42 am »
Thanks Geoff
Are they gearheads John..
Theres alot of very reasonably priced gearheads on e-Bay..from 2-200+ rpm very high torque..
cos918
Re: celestine
« Reply #66 on: June 30, 2011, 07:39:33 pm »
Hi Paul
She will come down to Bristol when it done. Work just gone mad for the next 3 weeks so dought i will get any modeling done. Passing your place tomrow then passing back on sunday,got to go to wrigles.
Hi More Coffee
thanks for that. I have 2 1:100 motor gera boxs winging there way from china ,If i rember they were £10 each inc P/P
Subsonuc Mike
Re: celestine
« Reply #67 on: June 30, 2011, 11:11:23 pm »
i love this i want it
cos918
Re: celestine
« Reply #68 on: May 11, 2014, 11:48:04 am »
Hello all
work has re started. A new lift mech was made and works well.
john
midori gaoka
  • Location: On the french coast , in front of channel island
Re: celestine
« Reply #69 on: May 13, 2014, 09:14:02 pm »
Thank you to give us many photos and ideas. It's giving to me some ideas for my next ferry.
Well done again
cos918
Re: celestine
« Reply #70 on: May 13, 2014, 09:29:35 pm »
I hope to have severl working systems on board . Next up is a smoke system for the funnel. Do you have and ferries inmind.
john
ps you might find some more photos of her here
http://www.rcgroups.com/forums/showthread.php?t=817609&page=9
cos918
Re: celestine
« Reply #71 on: June 07, 2014, 11:04:43 pm »
Life is all done and painted with lights in .
 If the weather is good on sunday hope to do a quick sea trill to check stabilty , balast req , new motors, new rudders and second bow thruster. If all works as hope then I can crack full steam on with her build.
 john
hama
Re: celestine
« Reply #72 on: June 08, 2014, 09:12:43 am »
Pictures please if you go to the lake!!
Impressive boat this one.
Good luck on your trials!
Hama
cos918
Re: celestine
« Reply #73 on: June 08, 2014, 09:16:30 pm »
Hello
Sea trials happend to day.  The protec 720 motor worked perfectly . The beckker rudders make her swing  very tightly. The second bow thruster adds a hell of a lot more turn. She can now turn a full 360 in about 12 secs. I tryed her on both 12v and 6v. 12v is abit to powerfull especially in close quater manovering. 6V better for close quater manovering .
 There is a small water leak on the bow thruster some resin shold fix that. I need 12v for lights and smoke genrator and a max of 7.2v on the bow thruster . I am going to do another sea trial  with 7.2v on the main motors. I am looking at ditching the SLA as the are heavy 12V 3ah 1.3kg 11.1v lipo 4000mah 300 g big saving meaning i can but in more weight low down. She need  bilge keel fitted hopfull this will help redue the role.
 Going to have a rethink on other working feathers as they add weight.
 john
Re: celestine
« Reply #74 on: June 08, 2014, 10:53:21 pm »
John...your Celestine looks great on the water :-)).......and from the images it was a very clam day without much wind
You are certainly correct that repositioning the alternate batteries will lower the metre centric point of balance [lower pendulum effect] this will also reduce the speed of roll and visually improve stability...if I read correctly by going to lipo's you will actually increase your current capacity by 33% but reduce weight by a staggering 1000g :o
The above water hull is high in surface area so will be subject or sensitive to windage roll......post more images of her second sea trials.......Derek
Pages: 1 2 [3] 4 5 6 7 8   Go Up
