Pages: 1 2 3 4 [5]   Go Down
Author Topic: My First Build _ Model Slipway's AZIZ  (Read 47412 times)
crzydoyle11
Re: My First Build _ Model Slipway's AZIZ
« Reply #100 on: February 20, 2008, 01:54:10 am »
OK guys some one please do this and let me know if this works. Go to AOL.com and than go to AOL pictures and than click on Public Galleries and than go to the search bar called Tag search and type in RC boat Aziz. and should be able to see most of my build from the start and some of Master Chief as well so try that ok.
Proteus
crzydoyle11
« Reply #102 on: February 20, 2008, 08:51:27 am »
thank you very much Fredy for making into a web link..Again thnak you
    http://aolpictures.aol.co.uk/galleries/tags/RC%20boat%20Aziz
crzydoyle11
« Reply #103 on: April 08, 2008, 04:54:50 am »
here is My Aziz with working Doors and color
crzydoyle11
« Reply #104 on: April 08, 2008, 05:04:03 am »
here is some working Elec. I am putting into Boat
crzydoyle11
« Reply #105 on: April 08, 2008, 05:11:14 am »
Here is the Power Distribution Panel   center
« Reply #106 on: April 08, 2008, 06:53:16 am »
Hi  crazydoyle11,
Looks great!
How did you hinge the doors?
Martin
crzydoyle11
« Reply #107 on: April 08, 2008, 12:56:58 pm »
The hinge come from a train store.watch I found out" that there are really for a doll house. making them fit the boat was not! to bad. I just notch the door frame and jams out watch. and than glue them into place. I will get a closer picture of the Jams watch you cannot see in this picture. also about the doors  watch I made" into two halves and place a window in-between them. That is because, when adding door: the door would not meat even with outside molding. So added some more plastic to it, watch come from 1mm plastic sheet that I stall have some left over. Making the door was more work than adding the door hinges. Also adding the window in-between the two halves I also have to notch them out so the two halves mount together and the door would close flush" into the the door frame. In the end if some one would have made that door for the Aziz I would have oder them! because it was alot work the doors than the hinges. I have stay I did enjoy making them.
Master Chief
« Reply #108 on: April 08, 2008, 12:57:55 pm »
He used Brass Doll house Hinges Hes a picture Of his doors
crzydoyle11
« Reply #109 on: April 09, 2008, 01:44:14 am »
The hinge come from a train store.watch I found out" that there are really for a doll house. making them fit the boat was not! to bad. I just notch the door frame and jams out watch. and than glue them into place. I will get a closer picture of the Jams watch you cannot see in this picture. also about the doors  watch I made" into two halves and place a window in-between them. That is because, when adding door: the door would not meat even with outside molding. So added some more plastic to it, watch come from 1mm plastic sheet that I stall have some left over. Making the door was more work than I thought when adding the door hinges. Also adding the window in-between the two halves I also have to notch them out so the two halves mount together and the door would close flush" into the the door frame. In the end if some one would have made that door for the Aziz I would have oder them! because it was alot work the doors than the hinges. I have stay I did enjoy making them.
cos918
« Reply #110 on: April 09, 2008, 08:25:42 pm »
hi there I have seen these power panel in a few boats before. I was wondering what are like and how much do they cost. As in my boat I need 12v 6v 3v so I was thinking about 3 battery's but now seeing these they seam a better idea. Any thoughts or advice would be welcome.
john
crzydoyle11
« Reply #111 on: April 10, 2008, 01:55:20 am »
hey there John" First let me say I have not hook it up as you can see in the photo other than make sure the power switches work. But I do like it because it will cut down on more batt.. that you have to add to run your lights and every thing else you know. I cannot wait until I have everthing hook in and running with it. Hear is the web site that I order it from HarborModels.com  and The price in US money is $89.99 if nothing else just ck the web site and you can judge for your self. If you can buy do it. It would be money well spent.. PS. It also has circut breakers made in to it just case to much power\short so it will trip the breaker and saving your boat from melt down.
cos918
« Reply #112 on: April 10, 2008, 05:43:42 am »
thanks for the info il have a look at harbor models web site.
john
crzydoyle11
« Reply #113 on: April 17, 2008, 03:30:45 am »
here is some more picture of the Aziz
crzydoyle11
« Reply #114 on: April 17, 2008, 03:37:56 am »
Here is Hatch again
crzydoyle11
« Reply #115 on: April 17, 2008, 04:04:40 am »
One more time sorry  >>:-(
crzydoyle11
« Reply #116 on: April 17, 2008, 04:11:47 am »
here is two more  O0
« Reply #117 on: April 17, 2008, 08:28:05 am »
Photos a little bit dark maybe ?  :-\
crzydoyle11
« Reply #118 on: April 17, 2008, 12:01:06 pm »
Sorry man But the lighting in my home not very Good as you can see or Not see. ???
Pages: 1 2 3 4 [5]   Go Up
Page created in 0.342 seconds with 22 queries.
