John, thanks for taking the time to respond. It's a bit of a nutty project but I enjoy it. I'll definitely have to keep the revs down, in fact I wasn't anticipating over 20K, but I imagine that's where you get the power, low torque x many rpms. (the watt meters are fairly common now, gadget with 2 wires on each end and a LC screen, you just put it between your generator and load, it reads out volts, amps, watts, and records high point, sort of expensive, about 50$ US I think).
Yes the steam supply is one of the big concerns, and then matching it with the turbine consumption. I need to get out the old physics book and steam tables. One item I'm not sure about either is whether it's worth putting in a condensor to try to retain warm water for feeding the boiler, or if I should just use that space for a second boiler.
See attached "preliminary" drawing. That's just one version of the turbine, though you can't see much, it's goofy, with the exhaust ducts, would be difficult to build.
I think the propane tanks can put out 11000 btu's for 4 hours, so two tanks could put out as much as heat as needed if it can be accomodated, and then converted to steam. (Like 176000 btu's for a half hour heh, heh, that's 34 hp) at 1% effeciency that's 1/3 hp, but I'm afraid the thing would melt or explode.
What do you think? Cap
