Author Topic: Reuse, Repurpose, Recycle . . . . .  (Read 2679 times)
Mike S
« on: February 20, 2022, 09:12:57 pm »
Christmas seems a long time ago now, one of the pressies I received was a rather nice box of dark chocolate gingers from Waitrose, (aka 'Britain's Poshest Grocer'). Unusually the box was not cardboard or plastic, but 6mm ply, well constructed, if a little rough around the edges. After consuming the contents, (most important!), I was going to reuse the box for storing drill bits etc. but decided to 'pimp it up' a bit as a little side-project during the grim days of January.
First step was to rub everything down with 220 grit then 400 grit sandpaper. The box rim, exposed ply, was then covered with strips of 1mm obechi veneer. Next 3 coats of antique pine stain were applied, followed by 4 coats of Colron Danish Antique Wood Oil, (much easier to apply than varnish).
A razor saw and warding files were then deployed to add the brass strip detailing. Finally the base was lined with green felt, and hey presto, an 'antique' artisan trinket box!
Hopefully the before and after photos have come out below . . . . . . .
Cheers,
Mike S
Re: Reuse, Repurpose, Recycle . . . . .
« Reply #1 on: February 20, 2022, 09:22:00 pm »
Photos . . . .
Nordlys
« Reply #2 on: February 21, 2022, 09:03:23 am »
Mine has ended up as a dead battery box for recycling.
N
« Reply #3 on: February 21, 2022, 01:23:01 pm »
....... :o  as the brand sign says Simply
« Reply #4 on: February 21, 2022, 02:00:57 pm »
We usually get the biscuit tins each christmas from my sisters - its got a dark colour with a goldish B on the sides, so i have two in the cupboard with all the spice jars and gravy etc granules in one and the sauce tubs/packets from pizza companies, garlic bulbs and tomato paste tubes and stock cubes in the other, both fit side by side in a 600mm wide unit, others are used to store my model bits, though the last year or two no new tins as we are all shielders
« Reply #5 on: February 22, 2022, 06:43:14 pm »
I remember making little pop-pop and electric boats out of the xmas (only time they seemed to appear) date boxes, even the little fork made a good mast  :-))
Page created in 0.294 seconds with 21 queries.
