Author Topic: brushless esc size  (Read 2272 times)
madboats
brushless esc size
« on: May 25, 2022, 09:30:10 pm »
Good evening all
Looking for help on what size esc i would  require for a Turnigy brushless D3536/6 1250kv with regards to amps.
Thanking you all in advance.
Happy boating madboats
unbuiltnautilus
Re: brushless esc size
« Reply #1 on: May 25, 2022, 09:43:05 pm »
Overlanders 3536/05 (which is a slightly hotter motor) recommends a 30amp unit, mostly for flying use. Add ten amps to be on the safe side and don't overprop or over volt it and you should be fine.
tsenecal
« Reply #2 on: May 26, 2022, 02:45:47 am »
what kind of boat are you planning on putting it in, what size propeller, what size battery (how many volts)
a tugboat with a 3" prop on 6v is going to need a completely different esc than a v hull with a 40mm prop and 16 volts.
madboats
« Reply #3 on: May 26, 2022, 07:15:18 am »
Hi Tsenecal
They are for a Trent Class Life with 40mm props and 11.1 3s lipos
rnli12
« Reply #4 on: May 26, 2022, 07:52:13 am »
I used the HobbyKing 60Amp ESC watercooled [but didnt need the cooling] worked perfectly.
gantu
    • Modellbaudaten
« Reply #5 on: May 26, 2022, 10:50:46 am »
Turnigy D3536/6 1250KV Brushless Outrunner Motor
Spec.
Battery: 2~4 Cell /7.4~14.8V
RPM: 1250kv
Max current: 34A
No load current: 3A
Max power: 500W
Internal resistance: 0.034 ohm
Weight: 102g (including connectors)
Diameter of shaft: 5mm
Dimensions: 35x36m
Prop size: 7.4V/10x5  14.8V/9x4.7
Max thrust: 1270g
NickelBelter
« Reply #6 on: May 27, 2022, 04:02:05 am »
Hi Tsenecal
Have you tried 2S?  11v (nominal) x 1250kV is over 13000 RPM - quite a lot for a lifeboat, even a big Trent.
Page created in 0.33 seconds with 21 queries.
