Author Topic: Billing Boats Zwarte Zee 592  (Read 3366 times)
Phil22
  • Nothing is impossible to the willing mind.
« on: August 31, 2022, 11:19:15 am »
This week I received the Billing Boats Zwarte Zee (Black Sea) BB592 from Cornwall Model Boats. Really great service from CMB as per their usual standards. The 1:90 kit with fittings comes in at £285.
Included in the box:
- ABS hull
- ABS lifeboats x 3
- ABS funnel
- Laser cut decks and cabin structures
- Molded plastic details
- Propshaft setup, rudder and plastic props x 2
- Wood strips and dowls
- Brass details, stantions and metal wire
- Decals and canvas effect sheet
- Instructions
- Plan drawing
Dimensions:
- Length 90cm
- Width 15.5cm
- Height 37cm
Instruction Book (Download)
https://www.billingboats.com/components/com_redshop/assets/document/extrafields/1624432105_592-zwarte-zee-vejl-190619-lr.pdf
Plan drawing (Download)
https://www.billingboats.com/components/com_redshop/assets/document/extrafields/1582623353_1484740897-bb592-zwarte-zee-main-plan.pdf
Build blog to be posted in Tugs and Towing when I get going  {-)
Cheers!
Phil
Alan52
  • Model Boat Mayhem is Great.
Re: Billing Boats Zwarte Zee 592
« Reply #1 on: August 31, 2022, 06:45:02 pm »
Looking forward to the build Phil :-)) :-))
Alan
RST
« Reply #2 on: September 04, 2022, 02:25:16 am »
Thanks for adding to this part of the forum.
...I'm a quite impressed Billings give you the choice of left or right hand props in the box but at this price sadly no brass prop!  Out of interest, I tried seaching the instructions but it didn't come-up, is it a 3mm prop shaft or a more regular 4mm one in this kit please?
Cheers,
Phil22
« Reply #3 on: September 05, 2022, 05:38:56 am »
Thanks very much Alan, Rich  :D
@RST - It’s a 4mm prop shaft included (length 170mm). To add, the outer 6mm tube with the brass collars fitted is 126mm.
For the props, one is actually for use as a deck detail.
On the original vessel there looks to be some type of mount for transportation.
The location is likely the only place left away from all of the towing and mooring gear. I’m wondering if it’d be a replacement for the ZZ herself.
I’ll be ordering a brass prop and maintenance free shaft to go in the model.
Cheers,
Phil
Page created in 0.015 seconds with 20 queries.
