Pages: 1 2 3 4 5 6 [7] 8   Go Down
Author Topic: HMS Ocean Scratch Build  (Read 65138 times)
Dan
Re: HMS Ocean Scratch Build
« Reply #150 on: October 12, 2024, 10:58:00 am »
Thank you both. The mesh is a 40 wire per inch stainless steel insect mesh from eBay. Comes in a sheet about 6" square and I just cut it down to size with scissors.
Dan
« Reply #151 on: October 27, 2024, 07:26:08 pm »
It got a bit repetitive after a while, but the walkway (I'm sure there's a different name for it but I don't know) is basically complete. Finer detail will be added at a later date!
6705russell
« Reply #152 on: October 27, 2024, 08:13:59 pm »
Lovely work Dan.
Dan
« Reply #153 on: October 27, 2024, 09:09:55 pm »
Lovely work Dan.
Thank you very much  :-))
« Reply #154 on: November 10, 2024, 08:48:38 pm »
Wow! those cut outs in the hull side illuminated are fab! They remind me of the Death star hangars!
As previously said, don't rush it, you are doing fine, and remember what the famous craftsman Khrushchev (SIC) once said: 'Perfection is the enemy of good enough'. We are all our own worst enemis when it comes to knowing when to say that's enough  8)
Dan
« Reply #155 on: November 10, 2024, 09:17:52 pm »
They really do, I've heard it a few times  {-)
And thank you for the kind words. It'll never be perfect because it's me building it, but I'm happy with it so far.
I've just finished doing a bit on it for the weekend. It's been quite productive. I've started the super structure. The bridge will be a bit of a head ache because of the angles of it all. I'll let the photos do the talking.
Cheers,
Dan
captain_reg
« Reply #156 on: November 11, 2024, 08:04:15 am »
Looks fantastic. What thickness of plasticard is that and what do you use to cut it? I've been using scalpel blades and anything 1mm or more becomes a right chore especially for windows. What adhesive are you using and how long do you find you have to support a joint for it to set?
Really enjoying watching the build :-))
Dan
« Reply #157 on: November 11, 2024, 05:43:42 pm »
Thank you! The card is 1mm. It is tricky to cut, but if done slowly and with a few passes it does go. I have got impatient a few times and tired cutting it in one pass, but I usually end up going off course.
I don't use scaple blades or modelling knives , I use one of my Stanley knives. I find I get a better grip and it goes through the thicker card easier.
I used liquid poly cement for most of it, but if needed I'll use a blob of super glue (and sometimes a support made from scraps like in the last photo) just to quicky hold bits in place while the poly cement goes off. Hope that helps  :-))
« Reply #158 on: November 11, 2024, 05:59:52 pm »
Good point re the Stanley knife. Although not so precise as craft knives or scalpels it often gives a better result as it is more rigid and cuts where you want it to.
Dan
« Reply #159 on: November 11, 2024, 06:16:12 pm »
The only "issue" I've found with the Stanley knife is that the cut edge ends up with a slight chamfer so usually needs a light sanding to square it off.
6705russell
« Reply #160 on: November 11, 2024, 06:24:07 pm »
If you score and snap you will get a flat edge, just light sand to rid of any burrs.
« Reply #161 on: November 25, 2024, 11:37:57 am »
Great looking bridge!! Really crisp.
Some styrenes or maybe ABS can snap untidily leaving lots more fettling. It depends on each person's interpretation of score as some might use a blade or might use a scribing tool, or even an old style compass point (Used one recently to cut through 1.5mm plastic in an awkward place) I find the irregularity is worse the thicker the plastic, but have found differences between different makes of sheet styrene. I like the slightly warm white type that Amerang sells or used to sell.
I use a scalpel mainly but do use a Stanley for thicker plastic and chopping corners or carving etc.
It is refreshing to use thinner plastic for building as it is easier to cut and handle but masters usually require thicker plastic to withstand vulcanised moulding.
frogman3
« Reply #162 on: April 15, 2025, 11:42:42 am »
HI DAN whats happening on your carrier ? as you was doin so well on it
chrisb
Dan
« Reply #163 on: April 15, 2025, 09:07:30 pm »
Hi Chris, not much as far as updates go. The main superstructure is at a point where I can start adding detail but I'm going to move on to the main crane first and get to a point where I can prime everything and start looking at getting the first coats of paint on.
Cheers,
Dan
NickelBelter
« Reply #164 on: April 15, 2025, 09:29:27 pm »
For what it's worth, I purchased a small right-angle plane from Lee Valley and I use it to square the edges of scored styrene parts.  One or two passes leaves the edge 90 degrees and smooth.
Dan
« Reply #165 on: April 17, 2025, 07:18:17 pm »
Thanks for the tip, I've now ordered one for myself  :-))
frogman3
« Reply #166 on: April 24, 2025, 12:38:49 pm »
HI Dan wow you S/S looks brilliant are you goin to light up the bridge an hangars ? CANT WAIT TO SEE HER ON THE WET STUFF
chrisb :-))   an im goin to take my hms  norfolk up Norwich pond on sunday so hopein for nice wheather
Dan
« Reply #167 on: April 27, 2025, 12:37:45 pm »
Hi Chris,
Thanks, she will be lit up. I've already installed and had the landing craft bays lit up. I can't remember if I uploaded photos of it so here they are again.
Hopefully you had some decent weather to get to the lake this weekend  :-))
frogman3
« Reply #168 on: April 27, 2025, 08:08:08 pm »
HI DAN  yes them apertures look great all lit up just like the rea ship wow an yes been up norwich pond today an had a great days sail an there was a very good turn out on models which made the day an the wheather was fab nice an warm an sunny  an plenty of the general public walkin about an askin questions about my NORFOLK an wanting to see the eletrics inside her so YES A VERY GOOD DAYS SAILIN as she was on the water for 4 times sailin an i dint hit one boat but had a close one as some fast eletrics only just missed my norfolk but ok in the end an jen an i stayed right till 4 pm  an yes we both caught the sun as we both have bright red faces lol
ATB DAN an to your family
chris an jen  :-))
Dan
« Reply #169 on: June 17, 2025, 06:22:46 pm »
A small update. Nearing completion of the crane. Trying to include as much detail as reasonably possible at this scale.
Not sure what I'll move onto next. Maybe adding detail to the superstructure.
Also I've done a basic video on how I build the basic superstructure
https://youtu.be/Pt94sczUdMw?si=m6zkmHQ8DaK0zICc
« Reply #170 on: June 22, 2025, 10:43:32 pm »
Describing what you are doing while doing it is IMHO the best way of producing videos like these as some folk do waffle on and then we see ten minutes of not always well filmed work. I was there with you all the way and felt part of your video rather than a bored disengaged viewer looking at the time stamp because the video is boring. Please do some more Dan!
The crane looks great matey!
« Reply #171 on: June 23, 2025, 10:15:13 am »
Great so see how the build is going, and for me a great tutorial in using plasticard, more please  :-))
Dan
« Reply #172 on: June 23, 2025, 02:09:37 pm »
Thank you both. I'm well aware my voice isn't the most exciting to listen to and I'm by no means a film maker but I'm glad you thought it was useful!
T888
« Reply #173 on: June 23, 2025, 02:55:13 pm »
Hi Dan,
Thought the video was a good idea to show your progress, which is some time hard to post for every item built.
When I get get back to my Type 26 build , I’ll copy our great idea and post a progress video.
Regards David
Dan
« Reply #174 on: June 24, 2025, 08:08:01 pm »
Hi David,
Thanks for your kind words. I unintentional miss bits with the camera because on the rare occasion I do manage to sneak away from family life for 5 minutes, I get stuck in to whatever it is I'm doing and totally forgot about recording it.
But it'll be good to see yours on video. Keep us posted!
Cheers,
Dan
Pages: 1 2 3 4 5 6 [7] 8   Go Up
Page created in 0.018 seconds with 16 queries.
