I'm not sure about very high power but I've used the standard red Huco couplings in large models for many years without any problems. However I always use a double coupling., What a lot of people don't necessarily realise is that a single coupling really allows a little misalignment in one plane only so unless the other plane is perfect you will get vibration. A double coupling allows alignment in both planes which makes a huge difference both to vibration and noise.
However with the power you are looking to apply I suspect the Huco won't be strong enough, single or double.
Geoff
