Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12   Go Down
Author Topic: 1/96 Scale T26 HMS Belfast build  (Read 86169 times)
Re: 1/96 Scale T26 HMS Belfast build
« Reply #225 on: January 10, 2025, 08:14:38 pm »
Can I ask where you got the dis boards from ?
T888
« Reply #226 on: January 10, 2025, 09:07:32 pm »
Hi Phill,
They are prototypes from Scalewarships
Regards David
T888
« Reply #227 on: January 12, 2025, 11:45:51 am »
LED bus board installed just need to make and instal the LEDs and lighting housing
Regards David
« Reply #228 on: January 13, 2025, 12:09:44 am »
Hi David, that's a very neat looking electronics installation you've done so far -I like it a lot and thanks for the update.
Cheers,
T888
« Reply #229 on: January 13, 2025, 09:38:43 am »
Thanks Ray
I’ll end up having 16 LEDs for the heli deck landing lights plus another 12 for the landing aids lights.
A friend of mine is working on the mission bay crane control electronics as how I had its function working failed, <:( so he said he’d look at it.
Regards David
T888
« Reply #230 on: January 15, 2025, 04:32:40 pm »
I’ve just been told by Scalewarships the LED Bus board will be soon available on there web site
Regards David
« Reply #231 on: January 15, 2025, 06:58:19 pm »
Many thanks II will keep a look out, as I need 2 (diss boards that is chaps)  :-))
T888
« Reply #232 on: January 19, 2025, 05:53:47 pm »
Picked up these today from a friend that has just got a resin printer. The larger heli deck lights will go down the side of the flight deck, the smaller ones on the transom.
Regards David
T888
« Reply #233 on: January 19, 2025, 07:05:41 pm »
Housing after two coats of Matt black Thai is to stop light leak and one top coat once fully dried I’ll give them a light sand and final top coat.
Then the housing will have green lenses added, this will be done by painting green acrylic clear on some acetate.
Regards David
Detomo
  • Model Boat Mayhem Forum is Great!
« Reply #234 on: January 20, 2025, 12:06:15 pm »
Hi, Any chance of showing/telling me what eletric components you have used in the picture, cheers :o
T888
« Reply #235 on: January 20, 2025, 03:22:01 pm »
Hi Detomo,
The item mark in
Yellow ………..is two 12 way LED bus bar
Blue ……………is a 12v distribution board.
Green …………is a 8 way switching unit
All these electronic were purchased from Scalewarships
Hope this helps
Regards David
T888
« Reply #236 on: January 23, 2025, 04:19:20 pm »
Flight deck landing lights installed today, but had to order some more as I miss counted {:-{
Regards David
steve mahoney
« Reply #237 on: January 23, 2025, 07:33:35 pm »
Easily done. I built a huge tug and miscounted the railings – couldn't tell the difference between 2 and 3. Doh!
T888
« Reply #238 on: January 24, 2025, 07:34:45 pm »
My UK supplier is out of stock, so I’ve had to order from China  >>:-( the issue is they will not be delivered until Feb 10th.
Regards David
T888
« Reply #239 on: February 01, 2025, 09:44:49 am »
Progress pics
Lots and lots to still do.
Regards David
Detomo
« Reply #240 on: February 01, 2025, 11:05:13 am »
Cheers for the photo, it has helped me a lot on my set up . :-))
T888
« Reply #241 on: February 11, 2025, 11:21:27 am »
Completed all the wiring in the hull today. Every cable has its own cable ident this is to help track the cables when any repairs are required
I still have two spare ways on the 8way switcher and spare ways on the LED bus bars. Just need to move on to coupling up the superstructure electronics to the hull electronics.
Regards David
« Reply #242 on: February 11, 2025, 11:14:43 pm »
Very impressive cable work David, all very neat indeed  :-)
Cheers,
T888
« Reply #243 on: February 12, 2025, 07:20:44 am »
Thanks Ray,
Just now got to do the superstructure, but there is not a lot of info coming out at this time.
Regards David
« Reply #244 on: February 12, 2025, 01:08:01 pm »
Nice work Dave, you might even think an engineer fitted her out!!
T888
« Reply #245 on: February 12, 2025, 02:13:24 pm »
 {-) O0 O0 {-)
Thanks Bob,
Regards David
T888
« Reply #246 on: February 14, 2025, 03:15:57 pm »
Well Gents,
After spending time reviewing all the photos I decided too strip off all fittings apart from RAS fittings.
I incorrectly built the walkway as solid but it is meshed, doors incorrect locations and what I thought as weather strips above the doors are not incorrect. Two step forward one back.🤬
Regards David
T888
« Reply #247 on: February 18, 2025, 09:39:41 am »
Just a quick update on the funnel rebuild.
Regards David
T888
« Reply #248 on: February 21, 2025, 11:43:01 am »
Got a bit of new info re the RAS post so I’ve got to modify my first assumptions
Regards David
T888
« Reply #249 on: February 26, 2025, 10:55:46 am »
Been doing some fittings casting, but could not find my Phalanx CIWS mould I made when building USS Roosevelt , so I’ve had to make a new mould from the masters.
Regards David
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12   Go Up
Page created in 0.209 seconds with 22 queries.
