Pages: 1 2 3 4 5 [6] 7 8 9   Go Down
Author Topic: Club 500 Build, 2023  (Read 76979 times)
Tug Fanatic
Re: Club 500 Build, 2023
« Reply #125 on: May 24, 2023, 06:27:40 pm »
Is the UniBond Plastic Repair Power Epoxy in the picture a clue?.
« Reply #126 on: May 24, 2023, 07:12:08 pm »
Plumbers solvent, the MaxFix plastic ( probably poly cement) & UniBond Plastic  Epoxy
« Reply #127 on: May 24, 2023, 09:57:54 pm »
Drive-line installed, ( needs bedding in ).
Velcroed down the battery tray... so it's moveable for balancing the boat.
Picking out radio gear ...
« Reply #128 on: May 26, 2023, 06:40:21 pm »
Well, nearly got it finished for Wicksteed ... but, in the end, the fates conspired against me ....
But this happened:
ChrisF
  • What's my favourite cake!
« Reply #129 on: May 26, 2023, 08:47:38 pm »
You will have to explain that.
zooma
  • Never too old to learn !
« Reply #130 on: May 26, 2023, 11:48:19 pm »
So, which glue have you used then!    :-)
Chris
This getting to be a real cliff hanger  %%
Tug Fanatic
« Reply #131 on: May 27, 2023, 06:11:17 am »
But this happened:
Is that your version of  running in the brushes?!
« Reply #132 on: May 27, 2023, 10:21:10 am »
ChrisF, in a car it used to be called 'running in', surprising how much carbon can be 'Discarded' from the brushes converting them from flat ended to concave to fit the 'Comm'.
Stuw
  • slow motion modeller...
« Reply #133 on: May 27, 2023, 10:43:09 am »
Is this for real? I thought water and electricity shouldn’t mix!  :o
2 Lesro Javelins... and that’s it. Not even close to finished!
zooma
« Reply #134 on: May 27, 2023, 11:08:36 am »
They say that about mixing blue and green too - but that seems to work OK 🧐
Tug Fanatic
« Reply #135 on: May 27, 2023, 11:49:09 am »
At low voltages you can get away with it. Water actually isn't a very good conductor but the impurities in it can be. This is why saltwater is a much better conductor than fresh water.
For high current use, like a Club 500, we used to run the brushed motor in under water and with 2.4v for around 20 minutes. Not sure how much good it did but it was a routine that we all followed and it certainly made nice black water.
It looks like Martin has used washing up liquid, or something similar. We didn't do that!
ChrisF
« Reply #136 on: May 27, 2023, 11:50:45 am »
You learn something new every day!
Stu - with some models they actually have the motors with a prop attached running in the water.
Chris
zooma
« Reply #137 on: May 27, 2023, 01:45:05 pm »
Chris
Yes - but the motors are inside the boat  {-)
Big Ada
« Reply #138 on: May 27, 2023, 04:24:41 pm »
  Er, nope.
Tug Fanatic
« Reply #139 on: May 27, 2023, 04:29:18 pm »
Not uncommon to have brushless hanging out the bottom of the boat for fresh water use. Corrosion of the bearings is the only thing to deal with (blow out & dry + oil after use). Brushed motor immersed in water is less common other than small coreless motors in micro models.
« Reply #140 on: May 28, 2023, 10:59:23 am »
Just got back from Kirklees club 500 event, seems EVERYBODY has used a solvent cement to glue the lids on  %)
 Regards Ian.
« Reply #141 on: June 11, 2023, 09:34:34 pm »
Hey Andy, you thought I was obsessed with types of glue, looking for something else, I've found....
zooma
« Reply #142 on: June 11, 2023, 10:32:07 pm »
.........and you can’t use any of them in your Club 500  %%
Stuw
« Reply #143 on: June 12, 2023, 09:07:32 pm »
Chris
Didn’t realise that! Interesting
« Reply #144 on: June 18, 2023, 08:45:42 am »
Finally, the next video!
Round  8 -  Washing Machine Motor
https://youtu.be/WfNjF5_PFsQ
zooma
« Reply #145 on: June 18, 2023, 09:13:21 am »
Excellent video Martin - highly entertaining  :-))
« Reply #146 on: June 20, 2023, 09:11:03 pm »
About 40 years apart .....
1. This new lead free solder is rubbish
2. Copper mains wire has changed!
Andyn
« Reply #147 on: June 20, 2023, 10:39:21 pm »
Ready for Wings & Wheels?  ;)
« Reply #148 on: June 21, 2023, 10:08:14 am »
60/40 is still available Martin.
« Reply #149 on: June 21, 2023, 01:16:00 pm »
Yes, found it on Amazon in the end, as per photo below!   :-))
Pages: 1 2 3 4 5 [6] 7 8 9   Go Up
Page created in 0.021 seconds with 22 queries.
