Author Topic: Help identifying boat/design/plan?  (Read 4426 times)
JimG
Re: Help identifying boat/design/plan?
« Reply #25 on: September 10, 2023, 12:11:20 pm »
If the old shaft has been glued in then the best way to break it loose is to use heat. Ideally a small blowlamp would be best but dificult to use this without damaging the wood around the shaft. A soldering iron might do the job, put the end of the iron in the shaft tube from the outside of the hull and leave it for some time to heat up the shaft. Wiggle the shaft from the inside to see if it is loosening up, if it feels loose then use a wood block on the top of the shaft with a hammer and try and drift the shaft out while it is still hot.
Jim
Dundee Model Boat club
Waiting2Retire
« Reply #26 on: September 10, 2023, 06:24:36 pm »
Thanks Jim, I am going to have a go at repairing the original for now while I ponder the bigger problem of a replacement - its never really leaked so if I can repair the damage it will do for now and I can contemplate bigger surgery later!
The new plastic replacement does seem to have a reduced section somewhere in its length that will be good for waterproofing and longer term I think is better fitted.
I bought a heat tool for heat-shrink (nothing like as hot as a heat gun) I could also try.
Paul
