Author Topic: Graupner 500e motors  (Read 1744 times)
terry1956
« on: February 19, 2024, 02:54:38 pm »
Hi chaps. I am looking for motors that are a direct replacement for the graupner 500e motor. The replacement motor must also have the screw fitting locations as the graupner. Thanks michael
DocMartin
Re: Graupner 500e motors
« Reply #1 on: February 19, 2024, 03:06:23 pm »
There are two available here:
https://www.ebay.com/itm/235431977442
Auction ends in 2 hours.
FWIW
terry1956
« Reply #2 on: February 19, 2024, 03:09:38 pm »
Good find, but they are in America. Import duties etc will make these expense.
« Reply #3 on: February 19, 2024, 04:10:29 pm »
Hi there Terry
just looking at the specs for the 500E motor - it runs on 12volt - but its voltage range is: between 6 volt and 12 volt.
Its normal rpm at 12 volt is 12,000 rpm
Its no load amperage is about 0.4
Its stalled current is approx 10 amp
So, that is what is required for a direct replacement - and hows about an MFA Como Drills motor  -  an RE-540/1 3 pole - at 12 volt it will give you about 15,500 rpm - its no load amperage is about 0.5 amp.   Under load the rpm is 13,360 rpm
Its current draw is about 3 amps.
The location holes for mounting the motor in the can should be exactly the same.
At the moment that is the nearest I can find for a direct replacement.
terry1956
« Reply #4 on: February 19, 2024, 05:16:24 pm »
Thank you for taking the time.
