Author Topic: "Geraldine-R-III" Australian fish trawler  (Read 6452 times)
Re: "Geraldine-R-III" Australian fish trawler
« Reply #25 on: April 26, 2024, 06:18:26 pm »
Absolutely awesome work, and it as inspired me, mind you I am more a wood butcher........ :-))
B.B
  • B.B
« Reply #26 on: April 30, 2024, 09:42:34 am »
Hi there, thanks SteamboatPhil, some more of the build, the frame which stands behind the w-house for stabilizer arms ( I won't be putting those on) it also has the mast stays attached to it. The brass  hoarser pipes and plating for both anchors, the lift out mast and boom, and with the front rope hoarsers made those from .357 mag shells and copper plating,,,cheers. :-)) ......
Brian  B
B.B
  • B.B
« Reply #27 on: May 02, 2024, 10:37:43 am »
Hi there, Next the brass hand railing for the raise deck area and aft section of the w-house. The inside of the bulwarks , deck and outside of the vessel had 2 coats of gloss. The base for the stand is from a section of Camphor cut from a fallen limb, then she had her bottom sprayed in the climate controlled spraying booth  O0 . Showing the w-house all done and dusted, and the start of installing the running gear she will spin 2 x 90 mm 4 blade Roboesch props, cheers.... :-)) .
Brian  B
Mark T
« Reply #28 on: May 02, 2024, 04:35:42 pm »
Just stunning  :-))
B.B
  • B.B
« Reply #29 on: May 04, 2024, 03:50:38 am »
Hi There, Thanks Mark, It's always good to finish them, showing the tiller arms etc on the 3 rudder set up ( and surprised it actually worked  O0 ) a few photo's showing all the gear attached, cheers  :-)) .
Brian  B
mrzippy
« Reply #30 on: May 04, 2024, 08:14:28 am »
Another pleasure to watch progress Brian !  I learn so much from your builds, thank you for posting.
Mark T
« Reply #31 on: May 04, 2024, 05:03:57 pm »
And me 👍. The colours just make these boats jump out they look great
B.B
  • B.B
« Reply #32 on: May 05, 2024, 11:15:05 am »
Hi there, Thanks guys ,a  few more photo's of the finished product, Cheers  :-)) ......
Brian  B
MikeMcP
« Reply #33 on: May 05, 2024, 11:58:22 am »
that is just stunning - well done you
B.B
  • B.B
« Reply #34 on: June 16, 2024, 12:37:57 am »
Hi there ,well finally getting around to putting some photo's on of her launch  between re wiring new ESC 's (had a few drama's) and started another build ?. With the photo's , showing Joe McGettigan christening her (in his late wife's name)and having a nice little steam around before disaster struck again  :embarrassed: , not to worry ,I suppose that is why they are called she's  O0 ......Cheers  :-)) ....
Brian  B
Mark T
« Reply #35 on: June 16, 2024, 04:37:51 pm »
That looks fantastic - I always think your boats look so real on the water
steve mahoney
« Reply #36 on: June 19, 2024, 04:08:39 am »
Sits really well in the water. What does it weigh in at?
B.B
  • B.B
« Reply #37 on: June 24, 2024, 03:22:09 am »
Thanks guys  :-) , she weighs in at 27 Kg.
Brian  B
Page created in 0.029 seconds with 22 queries.
