Hi there
Depending on how you have the setup of the control of your propellers - it will affect the turning of the vessel one way or the other - depending on the way the propellers are rotating. In other words if the centre prop rotates in the same direction as the portside - it will have a better turning affect to the port rather than the starboard.
If you are going to use an ACTion mixer, the centre motor is controlled via your throttle stick and it isn't affected by the movement of your rudder. Now, if you are really really clever and you have a set of 'old' 'very very old' speed controllers, which contain the chip ZN409 in them, such as early Electronize and the early ACTion ones, you can put a switch in the central signal wire of the speed controller, which allows you to switch the speed controller on and off. Therefore if it is the centre motor that you have switched on and off, it allows you to tootle around the lake using the two outboard props and when you want that extra bit of speed, you switch in your third motor.
Sadly, with today's programmable speed controllers, you cannot do this, as the speed controller memorises the set position of your throttle stick - and therefore it won't work, unless we have a very clever person amongst us who can re-programme the modern day speed controllers.
Here is a link to when I built my RAF Launch which has 3 props - there is a also a photograph of the above layout where the centre motor is switched.
https://www.modelboatmayhem.co.uk/forum/index.php/topic,9758.msg90496.html#msg90496
