Hello and thanks for accepting me on the forum. This is the third time trying to write this post so hopefully I've solved it and can post no problem going forward.
Perhaps a little introduction.
I got into model boats about a year ago after visiting the tall ships event in Hartlepool, seeing those almighty and graceful ships and boats, set me on a course to have my own sailboat albeit much smaller. After finding my local club in Darlington. I bought an old nivarna sailboat that was going cheap and some older 27mhz radio equipment to install. The thing had big anodised turnbuckles and was painted bright purple. I set to respraying, and transformed it into something much nicer. Re-rigged with smaller .ore delicate looking swivels and quick release clips, the boat now sails beautifully.
My daughter decided that she wanted a sailboat too after finding it really relaxing by the water controlling a sailboat, so I looked on ebay for some plans and a magazine article. By chance the one I bought also had on the reverse side of the sailboat plan Steve Whitelock Sandy Bank. Inspecting the drawings it looked easy enough so why not. The daughter can wait a little longer lol.
So onto Sandy banks....
After buying the balsa required, I glued up the bottom from two pieces, glued the bulkheads in place, then set to arranging where the radio gear and battery ect was going to go. I made some retaining boxes for the electrics to stop them sliding around too much. Then the top decks were glued into place. And all sides sanded vertical.
Here's where I had my first mistake and knocked one of the supporting pieces out with the sanding block. Several cursing words later, and a bit of glue and time for it to set solved that issue. So finished sanding the sides a bit more carefully this time.
The propshaft and prop had arrived by this time, so I drilled through with good intentions to glue the prop into place. Here's where I made my second mistake. I drilled the hole through the angled sternpiece too high. This I've overcome by sanding the hole where the prop should have been. This will be filled with epoxy when set up, and the two pieces that support the extended propshaft will go some way to plugging the gap andstopping water ingress I hope.
I started on the combing on the top deck, while I rebuilt my pride, this was reinforced in the corners with 1/8" square balsa, then glued into the deck, which was sanded open for a good fit.
I then built up the wheelhouse and engine room from 1/16" ply. I could have just painted it but the more clyde puffers I looked at the more I thought need to do justice to that box, errr wheelhouse. So it has been covered with thin strips of wood. Just using normal wood glue. The windows been coloured in with a sharpie before the overlay of wood.
So far it's looking something like a boat, just need to buy some thinner ply for the sides,1/16" isn't going to go around that stern easily. Make up the rudder, and glue the prop in permanently.
Hope those pics have posted this time....
Jon
