Author Topic: syphon feed  (Read 1836 times)
Trucker
syphon feed
« on: May 21, 2024, 07:40:44 am »
Hi, All
ive recently tried my syphon feed cheapo air brush using rattle can paint, sprayed out into the smaller jar, after letting it settle and gases escape i started work, but nothing.. checked that every thing was clear with no blockages etc, SO, im beginning to wonder am i expecting too much from the syphon brush..
Trucker
Andyn
Re: syphon feed
« Reply #1 on: May 21, 2024, 09:56:53 am »
Did you thin the paint?
Trucker
Re: syphon feed
« Reply #2 on: May 21, 2024, 05:08:31 pm »
Hi, Andyn
No i didnt thin the paint it seemed quite thin enough, my thinking was its from a spray can, so should be fine, but may be not
Trucker
nemesis
Re: syphon feed
« Reply #3 on: May 25, 2024, 07:01:30 pm »
Trucker, Cellulose was thinned 50% and it appeared like water. Do not use decanted aerosol paint. Try 50/50 to start with and then you can add a little to one or the other. The pressure should be approx 25/25lb. This one of your constants as the others can be variable. Practice and practice. Nemesis.
